Work Meister S1 3 Piece help
Old Aug 20, 2022 | 01:41 PM
leoc93's Avatar
leoc93
1st Gear
Default Work Meister S1 3 Piece help
Good afternoon,
sorry if this has been answered already but I’m new to wheels and have spend days trying to find an answer to this with nothing solid found.
Good afternoon,
I have a 2009 ISF & I am trying to order a set of
work meister s1 3 piece on vivid racing. I need helping confirming a width and offset that would fit my car. I would like the widest possible without the need to roll
fenders or use spacers. Someone suggested front 19x9.5 +30 R Disk/ rear 19x10.5 +35 O disk
The vehicle currently has stock suspension but I have ordered tein coilovers (flex z) and rear adjustable camber arms. I don’t want to have to run on negative camber to fit the wheels. I basically want plug and play for widest set up possible.
input from a wheel expert would be appreciated. As I said, I’ve referred to several threads but can’t find what I’m looking for.
Old Aug 22, 2022 | 11:25 AM
LexusfanVA's Avatar
LexusfanVA
Did you ask this on the FB groups? The offsets seem a little aggressive if you don't want to camber or run stretched tires. Sadly the ISF isn't a great car for wide deep dish wheels or concave ones either. Ideally setup is 9.5" wide with 40 offset square. Can do a bit thinner or wider and +-5 offsets, but anything more and you're putting less tire or adding camber.
Old Aug 22, 2022 | 08:22 PM
symatt's Avatar
symatt
Width and offset looks fine, at most u should roll rear fender, 255/35 front & 275/30 or 285/30 rear should be fine. Im not sure about the disks
Old Aug 22, 2022 | 10:39 PM
Meraki Autoworks's Avatar
Meraki Autoworks
Your #1 Lexus Vendor
We can help you order the Work Wheels, we're a dealer and can get the fitment locked in. Feel free to message us.
-Josh
__________________
Orange County, CA
Text/Call: 213 394 2886
Old Aug 23, 2022 | 06:28 AM
LexusfanVA's Avatar
LexusfanVA
Have you had a set like this onthis car? When I had my 19x9.5+35 245/35 F and 19x10.5+45 275/30 lowered on BC coils I definitely had rubbing front and rear, and as you can tell the tires were a bit stretched. I much preferred 19x9.5+45 square with 255/35 285/30 on my later ISF, no rolling or pulling needed and thicker tires all around.
ubersonic
IS F (2008-2014)
May 11, 2020 02:26 PM
I8ABMR
IS F (2008-2014)
Aug 3, 2014 08:51 PM
TRACKMKIII
GS - 1st Gen (1993-1997)
May 15, 2014 03:41 PM
Polkman
IS F (2008-2014)
12
Jan 3, 2014 12:57 PM
BIGGZ
Jun 1, 2007 12:48 PM
