Anyone have pictures of Bank 1 Sensor 1 replacement?
Hi CL, getting a p0420. I'm a dummy and changed out my bank 1 sensor 2 thinking it was b1s1. I have the correct part now but am looking for pictures of where I can change the bank 1 sensor 1 o2 sensor. There's a lot of info on it for 250/350 but I can't find any for ISF. I just know it's on the drivers side but where in the engine bay would I need to reach to get to it?
Scroll through here. https://www.clublexus.com/forums/is-...in-limits.html
They are directly on the manifold in front of the cats. I’ve never done this, but wager it would still be from under the car or maybe even through a wheel well.
Any body with experience?
It's very tight, probably need to drop subframe for any decent access. Assuming stock headers and original O2 sensors, it will most likely be seized in the manifold. FWIW, I was not able to remove my O2 sensors with the header off the car without damaging the threads.
I think it would be wise to go into the project with the plan of removing the header
Mike ES
05-13-09 11:36 AM
