- 2005 GX 470 Questions
- Peeling Paint and Cracking Speaker
- Mystery connector
- Curtain airbags & going off-road
- Aftermarket Height Control Sensors
- Rear Height Sensor Install Question
- TRD wheels or GX460 wheels
- Maintenance To-Do List
- 2003 GX470 Transmission Fluid/filter change suggestion needed
- Please use marketplace for FS and WTB
- Whining sound just appeared
- Rear Left Hand side height
- tire size
- Lower door molding
- No brakes after Battery Replacement ...
- Rebuilt Head????
- Would you pay a little more for KDSS?
- 2006 GX470 Camera not working
- Gx 470 2007 - Phoenix Android Radio Install?
- How do you know if '07 has KDSS?
- 05 GX470 VSC, Anti Skid, CEL, with codes?
- Help diagnose radio problems
- Locked crankshaft after timing belt change
- Iron remover on Pearl White GX470
- a tire skidding warning light
- Installing XM satellite antenna
- mud flap / runner fix help
- Any starter issues?
- 2008 GX 470 starts and then immediately stalls
- Gold GX 470 on 22 with vouges
- Help.. Hight control problem
- Cheap 8 ohm 6x9 speakers?
- After reverse reverts to gps
- SAIS Bypass Kit Experience/Questions
- Thumping Noise Related to Speed - Not Bearings?
- New Owner control arm
- Considering buying a GX
- Cracked dash on my 2004 GX-470
- Mark Levinson Amp Draining Battery
- Anyone selling a used passenger side shock?
- Ride height sensor bracket snapped
- How many converted to coil springs?
- hitch for 2006 GX 470
- Coolant Leak?
- Stiff Steering - Solution
- Fender well help
- Brown vent slider
- How to disconnect light console
- Problems with Mirrors, Dash Lit Up, and No Nav
- height control
- Flat Rear Suspension
- Bianca the GX Build (Blue Steel 2.0)
- Strange idle
- 2004 gx 470 tuner or chip
- Alternator/battery woes
- Electrical short?
- 03 470 replacement airbags and shocks
- Headunit install with OUT Nav & Mark Levinson
- 04 GX470 Trip resets with each start
- Rear entertainment system
- Auxillary Brakes for camper
- GX470 Suspension Air Compressor Removal
- Found some oil build up near the Intake Manifold.
- Plasti dip
- Possible exhaust leak. 03 gx470
- GX470 upper radiator hose came off while driving!?
- Issues to look for when buying used
- Garage door program
- Lexus newbie by accident
- 2005 GX470 height control stuck in HIGH
- Need Wheel/Rim and Tire size advice GX470
- Valve Cover Torque Specs
- Height control slot switch plate
- Replace stock shocks all around
- Nav Display Blows Fuse
- LX vs GX470
- Possible rear main seal leak
- Replacing evap core.
- 2nd 470 for me
- Parking Brake Issue
- DVD player removal and replacement options??
- 2003 gx470 front shock issue...
- Opinions on these for sale
- Shipping rims + tires - random question
- Navigation screen differences on 2006-2009
- $75 for a hood shock!?!? Any alternatives?
- Headlight restore to clear for $200? Worth it?
- 05’ shifter is not illuminating. (fuse or bulb?)
- Who has replaed with OEM shocks - experieince?
- Rear overhead DVD not playing
- GX470 miles till empty indicator, and other misc. concerns
- Passenger Side Rear Running Board Light
- Wet Sanding Hazy Headlights
- Worth buying post 2005 with the vvti?
- 05’ gx470
- Urgent need a response quick
- 2007 GX 470 smoke coming from alternator when battery attached, engine off.
- First gx470 buyer seeking advice
- Does this look like the transfer case actuator has been replaced?
- Need advise on buying my first GX470
- 2nd row seat latch hook stuck
- Blue Tooth help!
- 2007 GX470 w/ 227k miles advice
- 2005 Transfer case adapter
- Steering wheel shake
- My first GX
- About to buy a 2003 gx470, is this rust bad?
- Just Purchased 2004 GX470, Need Advice
- Texas shop for Suspension Conversion?
- 2003 gx470 height control
- After maintenance service lost navigation and auto door lock
- Potential new owner: how's your NAV and KDSS holding up?
- GX 470--Off Road Suspension?
- Vais Tech Sat Radio module install
- Sanding Chrome Wheels
- Planning ahead - rear suspension fixes
- How to remove trip info display
- Problem with adjusting mirrors.
- Power Steering Fluid color
- Where is the antenna and nav unit locate?
- 1up bike rack - solution found!
- Do you exercise your 4wd / locking diff? What about the air suspension?
- GX470 Overheating at stop
- 2004 gx470 blinking airbag light with code B0116
- Orange light
- Used 2008 RX 350, is this a good deal?
- Rear shock leaking newbie owner
- Is it worth it?
- Broke 2nd row seat lever (Driver Side)
- Dealer Parts Discount?
- Brakes
- Suspension problem???
- Please help identify this grease-fluid leak
- Sound From Under Hood After Sitting For Days
- bolts are breaking on transmission pan what to do?
- New-to-me 2005 GX470
- 2006 GX470 TDC Timing Belt Question
- Anybody have a grill they want to sell?
- 06 Diff Lock Light Flashing...low voltage?
- Has anyone experienced electrical issues due to welding exhaust?
- Best option for Android Auto and backup camera?
- 2007 GX470, cranks but won't turn over. Ideas?
- dash replacement
- Advice needed
- 2004 GX Newby, maintenance items?
- left rear sags when parked on a hill
- New member...... and a question
- Infamous front Strut question
- New to me GX470 - Best route for new Master Key
- New Owner 2006 GX 470 quick question
- Feels like "bump" while at a stop
- Can I use generic TPMS sensors on the GX470? Any recos?
- Q in Sports Pack/KDSS - does this make normal maintenance more expensive?
- Ac compressor
- Replace cargo window chrome molding
- best tires for gx 470
- 4runner struts on gx ?
- Tire Recommendation
- Lift Recommendations
- my 2002 lexus RX300 would not start.
- USB/ Bluetooth Audio
- Would you buy an 05 with KDSS or a 07 without?
- can some body help me to fix my bumpy ride, i need to fix it, it will blow and deflat
- Buying - old (03/04) low mileage 30-60k miles or newer (06/07) higher mileage 120k+?
- Wiring Harness Plugs Under Center Console
- Tire pressure sensors
- Price check - replacing all the CV boots
- Strut-right front broken, has anyone sean this before? GX never off road, 160,000 mi
- 2006 Steering Rack DIY help
- OEM Upper Ball Joint Part Number?
- O2 Sensor P2197 and P0158 Codes
- Quick favor - anybody in the Toms River, NJ area?
- Front Tires angled inward slightly should I be concerned??
- Exhaust Leak
- Differential Vibration
- Help 2003 or 2004
- Car alarm sounding for no reason
- Considering a used GX470 - questions
- New to me, 03 GX470 Is this back up camera ready?
- 2007 with 125k or 2004 with 90k
- Considering GX470 vs. GX460 for pre-owned purchase.
- Mild suspension lift
- replacing the transfer case seals
- Used GX470 timing belt unk
- DVD replacement/upgrade
- Dash Light help
- Jerk, pull, pop sound
- 2005 Lexus GX470 -- How to disconnect alternator wire connection?
- How to seperate trans dipstick line from pan?
- Help finding part number: Door Accent Light Clip
- HIDs
- IAT wiresc
- Air suspension problem
- Bilstein 5100s on rear GX...maybe?
- GX 470 vs GX 460 (power topic)
- 2007 Lexus ES intermittent wiper not working
- How to Repair/Replace Your AC Blower in Lexus GX, Toyota, more, Saving hundreds
- Brand for Trans and Diff Fluid Change
- Red light center of dash?
- To buy used or not - your opinions
- Water sloshing noise
- OEM front floor carpets
- Bent valves and dented pistons after shop botched timing belt change
- change gx trans fluid
- rear suspension
- rear hitch cover
- A/C leak solution- eliminate rear air?
- Water Pump Nightmare!!
- 05 GX470-Does anyone have OEM Windshield DOT # & Features
- Price difference worth it with KDSS and newer
- New Jersey Off Road Trails
- Seized Calipers
- New guy here
- A/C Clutch Relay Question
- Need some help, fellow GX 470 owners!
- NEW RR-Racing GX470 Brake Kit!
- Help with SRS Airbag light & B1100 Code
- GX Rear Shocks
- Joined the club! Got an 06, few questions for a new owner
- Fog Lamp (not the bulb) replacement GX 470 Gen 1 - 2007
- ECM pin out and O2 Sensors
- Newbie Tow Question
- Are these the right manifolds to order for my GX?
- Oxygen Sensor - Most update to date info for GX470
- interested in speaking to Lexus GX 470 owners with rusted frames
- Ceiling Mounted DVD Player - malfunction
- Trailer Package - Replace 7-Pin Wiring With Longer Cable
- New member from Southern Oregon
- New Guy
- OEM Body Parts Sourcing
- Help! Strange noise behind dash what could it be?
- DIY VL●OG: GX470 Front & Rear Differential and Transfer Case Flush
- Is there a DIY for lift install on a GX470 with KDSS
- 2006 GX470 ticking noise
- Best Aftermarket Air Springs and Shocks
- Detailed 165-70R17 Tire and Wheel Upgrade
- Nav Disc Player
- Help, Car starts, won't rev or go in gear
- DIY VL●OG: GX470 Air Injection Pump CEL P0418 & P2445
- Dilemma! What do I do?
- A little noisy coming off the ramps this morning
- GX470: No sound!
- Question on braking sensation
- Has anyone installed a push start or remote start system in a GX 470.
- 1999 lexus lx 470 rear door won't open
- Secondary air injection pump
- Bent Door check strap and bent window track
- 2005 gx470 H N L stick broke??
- Upgrade resolution of 2004 GX470 rear camera?
