Urgent need a response quick
Old Jul 22, 2018 | 03:41 PM
Andy2675's Avatar
Andy2675
Default Urgent need a response quick
The coolant was low in my 2009 gx and I (not knowing the difference in Toyota “red” and normal green antifreeze) I refilled the overflow with about 2 cups at most of the green antifreeze. Theres forums saying that mixing is terrible and can cause all sorts of problems. Do I need to drain asap or is two cups not enough to cause any probelms. Thank you.
Old Jul 22, 2018 | 04:12 PM
Kelevra's Avatar
Kelevra
You mixed 2 different chemicals together? I would assume they would coagulate and form a "gel" in the system.
More important, why was in low? Check for leaks or seepage.
Old Jul 22, 2018 | 04:22 PM
Andy2675's Avatar
Andy2675
The radiator is leaking and I have a replacement on the way. It was prestone long life or something like that, It says works with any make, any model, any color. Is that BS or does that mean its not a chemical that reacts badly with the toyota red
Old Jul 22, 2018 | 04:37 PM
Kelevra's Avatar
Kelevra
It may work with any model but, not mixed together. Personally, I would flush it out ASAP to avoid it causing some issues. Also replace the hoses, clamps, cap, thermostat O ring and, thermostat. Also, check the fan clutch. Much is available on Amazon. Depending on the milage and duration, might be a good time to do the water pump and the timing belt?
Old Jul 22, 2018 | 05:00 PM
Andy2675's Avatar
Andy2675
It’s actually about 5k past a timing belt job so I guess I should just bring it to the Toyota dealer and have a belt/pump/rad/coolant job done
Old Jul 22, 2018 | 05:34 PM
Kelevra's Avatar
Kelevra
Might be best to do it all up and right, the first time.
Old Jul 22, 2018 | 05:54 PM
Kelevra's Avatar
Kelevra
Denso radiator?
Old Jul 22, 2018 | 07:11 PM
Andy2675's Avatar
Andy2675
Yup, they were cheaper than I thought on Amazon
Old Jul 22, 2018 | 08:54 PM
Kelevra's Avatar
Kelevra
Yes, Amazon is great.
Old Jul 23, 2018 | 06:57 AM
IanB2's Avatar
IanB2
Make sure it gets flushed and back flushed really well when you get the TB/WP service done, especially the heater cores as you don't want those getting jammed up with crud.
Kal333
Jul 23, 2018 07:34 PM
2ndGF
IS F (2008-2014)
Dec 15, 2016 09:37 AM
djspock303
GS - 1st Gen (1993-1997)
Jun 26, 2014 08:33 PM
phamxOC
Jan 14, 2012 08:13 PM
element51
Jan 3, 2006 01:19 PM
