NEW RR-Racing GX470 Brake Kit!
Sponsor
After experiencing repeated caliper piston seizure on our shop Lexus GX470, we designed a new brake kit to improve brake performance and reliability. Unfortunately, the original calipers are notorious for experiencing piston seizure due to the fact that caliper is made from cast iron and the pistons are made from steel – materials that easily corrode. Rather than replace with remanufactured auto store calipers (which will typically fail within a year), or expensive new calipers from the dealer, owners of Lexus GX and Toyota 4Runners now have the option of upgrading to our new 6 piston performance brakes.
This product features include:
- Wilwood Forged Aluminum Aero 6 piston calipers. Forged aluminum construction with 6 differential bore pistons made from stainless steel that will never corrode or seize.
- Aero 6 calipers come with standard black anodized finish, but available custom powder coated as well.
- Standard rotor thickness is 27.5mm which we upgrade significantly to 32mm, resulting in longer brake rotor life, greater thermal capacity, and higher resistance to warpage.
- High temperature brake pads. Even the highest temperature pads for OEM calipers fade quickly beyond 800F. The BP20 compound is rated up to 1100F. This means that you will not fade these brakes, even when braking beyond 100mph, or towing heavy loads.
- Offered in optional powder coated paint colors with RR Racing logo (please specify in order notes if you prefer no logo)
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
Rafi, the website is confusing. Rotors are liste d as an option. Yet the product description lists them as part of the package and the picture shows them as part of, aside from the upgrade to slotted...
Sponsor
Rafi
You guys should make a brake kit for the 80 series Land Cruiser.... those really need it and are a very popular vehicle so there would be alot of demand. But it has to clear 16 and 17" wheels because I don't think they run anything bigger than that.
Make brackets for the LS400 calipers/rotors to work on those trucks and I guarantee you that will sell like hot cakes.
Hi Rafi,
Sounds like, if i have the GX460 rotors.,... they will work with the calipers you're selling, correct?
In other words, your kit comes with the SAME size/spec rotors as the OEM GX460?
The Stock GX460 caliper is 4 piston. The Wilwood caliper you're selling is 6-piston, correct? And it's made out of better material?
Any other advantages i am missing?
Thanks!
Thanks!
Sponsor
Hi Rafi,
Thanks!
Thanks!
Rafi
