- Financial benefits of owning a GS...
- How your GS handles the extreme cold?
- AutoStart installed major problems
- GS300 longevity
- Wheel makeover on my 14 year old GS :)
- If you only had $1000 for mods/maintenance, what would you start with?
- newbie
- no cabin air filter
- JDM Visor authenticity
- Back Again
- Thoughts on my new 1998 GS400
- 5th gear RPMs....
- Light Under Steering Wheel ?
- First one
- How much for an 02 Gs300 Sport Design?
- What's your opinion on stereo swap?
- abs sensor
- My First GS (Work in progress.)
- need help with setting a price for my 02 sport design
- are there more aero kits brands then this
- My First GS
- Late Intro
- Rebuilding Throttle control motor???
- Whistling noise in cabin, only when it's cold outside??
- Anyone know the wheel spec on this fatlace feature?
- Transmission Flush?
- gs 400 questions and opinions
- Started with a leak, an now......
- Rolling vs. Shaving Fenders (Pros/Cons)
- Motor mounts, anybody help me and chime in?
- RHD GS300 Project
- Aftermarket head unit
- Question for canadian-spec GS users about headlights
- eastcoast woesssss
- New serp belt broke?
- new gs300 owner, winter is killing my car
- 2002 GS430 issues
- Does anybody recognize his/her former car
- gs300 ignition coil
- Bring back the GS400?
- Please help passenger side door handle cable broke
- Broken sterio
- Last Pics for 2013 - NYC Stand Up!
- New wheels
- Looking to do my door lock actuators
- VSV hose diagram
- New member
- Pics of my new wheels at a garage meet!!
- New to CL, but not to Lexus....
- Please post all WTT threads in the classifieds.
- Blown gs400 engine need help
- GS400 Timing belt first time
- shifter cover slide GS400/GS300
- Techstream issues
- new wheels/tires= problems?
- new member
- WTB and FS posts go into classifieds forum once eligibility is reached.
- OEM Navi connector pinouts
- diy rear brakes and headlight bulb replacement
- New to me 02 GS430
- What wheels are these help
- GS rims
- HID Headlight assembly
- who all is going to texas 2k14?
- NEW MeMbEr!!!!
- Mods to increase reliability for a GS430?
- HELP! 2GS noise
- Evaporative sys incomplete! Pic Inside...
- Blower problem gs400
- Another new guy...
- New to Club Lexus
- non hid problems hid install headlights
- Help, please -- messed up timing belt job
- bad ignition coil? car wont crank or start
- New Member
- GS430 - 18x9.5 et30 Square setup Work Emotion CR Kai
- 01 gs430 Knock sensor
- Junction Produce Vendors?
- Rattling when accelerating?
- 1998 GS400 turning off when brake is pressed
- Does cleaning the throttle body make a noticeable difference?
- My recently purchased custom grille
- Will i be the first to attempt this on here..
- question bout mercedes benz front end conversions
- GS Carpet
- how do i fix this?
- Car drove and then died....help please
- Christmas came a little early for "Red Rocket" - Weds LXZ
- Fuel and brake line rust
- Valve Cover gasket replaced NOW bigger oil leak
- passenger side high-beam not working - checked all fuses
- Need help. I found the rim iv been wanting.
- Need one of these shifters....
- Whats The Cheapest Route To Fixing A Door Actuator?
- Good bye SC hello GS
- Need some help on deciding if I should be a lexus gs 300 sport design
- Power outlets
- Weird rear wheels shake when taking off?!?
- Pumping guards
- Good budget All Season Performance Tires for GS?
- Got rear ended last night
- blower control module question
- Fender pull ~ Fender flare pic request!
- Im no mechanic but i think i have a leak
- Toyota Aristo Master Cylinder on 98 GS300
- Anyone ever redyed their GS seats?
- Thinking about it
- I'm here for the cookies and milk
- New wheels!
- tires
- Zero Point Calibration
- Fuel Leveler Issues
- Climate Control Light Issue.
- What Is This!?? Resonator or Cat?
- Newbie here
- Crooked rear end (help)
- Help with YAW Sensor Please
- Which tire size and wheel offset/fit
- Xmas Gift for the car!! (Of course!) what's on your list this year?
- If i were to sell my engine&trans. What should i let em go for?
- Thank you Club Lexus for the motivation then the how to's with pics!
- My new GS430 (with some questions)
- ABS Brake
- Help
- No heat on driver's side
- '98-00 GS400 or '01+ GS300?
- Time to fix the missing climate lights. Anyone doing it as service?
- 99 gs 400
- 2GS Weight Distribution?
- Could use some advice on tire/wheel size and offset
- Basic oil change questions
- headunit help getting back on the road
- wtb and fs go in the classifieds only please
- Remote start?
- Throttle %
- Modball Rally
- Messed up my fogs! What to buy to make clear again?
- Does anybody know what kind of wheels these are?
- 245's?
- Randy Moss 99 GS400 for sale
- First GS in the snow experience....
- Stiff Steering
- quick question about 2jzgte swap
- Valve cover gasket replacement, easy or no?
- 120A fuse blown...any tips on how to get the fuse box out?
- delayed speedometer
- Faulty Tail Light
- Blank Navigation Screen
- JUST FOR REFERENCE ABS/VSC WIring Diagram for 2005 GS430 Owners!!
- brake fluid
- New member - New to me Gs300
- What is best to use to paint tailights red/is using the 1234 bad to change gears?
- bought my first lexus.....
- Rear Deck Rattle
- Anyone in Atlanta area willing to check out a GS400 for me?
- TSW or Privat Black Mesh Wheels. Looking for opinions.
- wtf just my luck..... 98 gs400 motor
- VSV Power/Fuse
- Doors wont lock unless i press window lock button.
- Greetings from Atlanta
- gs300 Idle/Start up problems
- DRL Lights
- Another TTE replica lip thread! woohoo!(need advice)
- oil control valve/ oil control valve solenoid??????
- VCS and VCS off Lights
- Lexus gs300 gas pedal acceleration issue
- New to GS300, few issues
- 19's or 20's for my GS400 and why?
- So who has the biggest tips?? I removed my rezies (not for weak stomachs)
- Alternator light ON good alternator
- weird rpm dependent hesitation problem
- New member: '02 GS300 with 80Mkm
- Which Gen looks best?
- 99 Gs300 Ignition Key Issue
- hey guys I need help on VSC and VSC off
- Crutchfield stereo compatibility list - accurate?
- Hids doesnt work with 2001+gs's?
- The Dreadful Moment has come... CA smog.
- anyone have matching 4300k headlights and fogs?
- leaving the family
- 99' GS300 not starting...
- Deal or No Deal (swapped gs300)
- Anyone wet sanded/ polished headlights?
- fender rolling tool
- Leo DiCaprio's Blue GS4
- Could a evap leak cause 7 mpg average
- anyone know how to read the tachometer to get the speed on a dead stock 99 GS300?...
- speedo died sliding on ice...fuse? Tranny mounted speed sensor?..
- please clarify diff between the two!
- steering column not reaching rack ???
- My LPG powered 2jz 2GS
- Cig lighter problems 99 Gs300
- fitting OEM fogs into JP front bumper
- Lexus GS300 Starter motor fault ? Please help
- 00 2GS odometer and speedometer stopped working same time?
- Brake master cylinder
- A thread not worth looking at, but if your bored..Why not?
- Immobilizer Question - 1999 GS300
- timing belt question..unique situation
- Starter issue, bite the bullet?
- Should i buy this?
- Brake light on plus chime
- Where to buy these parts (1 supplier)
- gs4 won't lock and unlock
- Rim advise please..
- Will isf brakes bolt onto gs300
- Where to advertise for sale?
- HELP on tire and wheel sizing
- LS and GS Seat Interchangeability?
- Carson L-tuned B-pipe gasket?
- Creaking passenger side wheel??? suspension? control arms?i
- My new (used) 98 GS300
- 1998 Lexus GS400 BAD OIL LEAK
- Problems with window regulator?
- car felt like it slipped out of gear or lost power during wot
- Tips Tricks On Replacing 2005 GS Parking Lights ?
- Removal of Driver Side Fuse Box HELP!!!
- Need opinion on wheels/fog
- Wing mirror glass replacement
- new shoes
- 2001 lexusgs430 knock sensor problem !!!help,!!!!
- 00 gs300 factory radio want to add ipad outlet
- Please help passenger side a c is not work
- Locked only key in trunk, doors unlocked, help??
- Dome Light/Key hole light/Foot well lights out
- Hello To all my Fellow Aristo Owners
- 3 Peice JP Spoiler Installed!! :)
- GS430 - remove catalyst
- clean 98-05 gs headlamp assembly
- Climate control, clock, and mirrors not working after radio install
- 2003 lexus gs models
- Painting center caps
- Looking for DIY thread- valve cover repl
- From Depo LEDs to oem 01+ on my 400
- upholstery repair
- 00' GS300 no start!?
- Coming back to the GS
- Is this a rare aristo grill? Authentic?
- Snow Mode
- FS and WTB threads go in the classifieds
- GS430 woes.... Replaced alternator, replaced battery and still...
- Opinion needed on wheels
- Jdm Aristo Power Folding Mirrors w/LS600 housing...
- What kind of oil and filter do you use?
- Can anyone tell what size piping this is?
- Fuel pump relay
- Sell GS300 for GS430?
