- Iron Toad
- loose driver side mirror
- How do i change the front blinker bulb?
- Front window rattle/shakes noise
- Headlight lenses? who sells them.
- Odd battery issue
- Parrot Bluetooth in a 2000 GS300
- R154 Conversion
- 1999 Lexus GS spectra blue mica on Petrol wheels!
- Electrical Schematic for Pioneer Audio System.
- Considering purchase of an 2000 GS 300
- 98 GS 400 vs 07 M45
- View under a British hood
- Is there a marketplace for retrofitted headlights?
- GS4 Ignition Installation
- Aristo headlight vs usdm gs headlight info
- Side Window Deflector
- Fuel Line upgrade help
- vsc and vsc off lights staying on.
- my steering wheel peeling off...need help plz
- Childs car seat
- Where to find interior paint for trim pieces?
- 1999 gs 300 starting issue
- Brake master cylinder questions
- GS400 ignition replacement
- 2jzgte Swapped Gs300
- Timing Belt Swap
- New stablemate for the GS4
- FL Window Testing
- GS400 Key Fob Replacement?
- Help on determining color
- Engine swap or procharger?
- Need a new radiator
- 2001 GS300 factory subwoofer is not working.
- Picked up a 99 GS300. Opinions and thoughts please.
- tail light indicator
- Rear deck speaker cover with third brake light from GS 400 fit a 2003 GS 430
- oil leak onto waterpump or coming from it>???
- 2Gen GS300 - 2Gen GS430 Engine/Tranny Swap
- Name a fun fact about your car!
- 2nd gear takeoff vs 3rd gear starts
- Door not locking with remote key
- ac issues please help
- Blower speed
- Mirror visor
- Can't find the 5th bolt on rear door panel.
- Gone but never forgotten........
- LED Lexus Symbol Courtesy Lights
- Is This A Good Deal?
- GS300/430's with other OEM wheels? Pictures please!
- I need help plugging back this hose "vacuum leaks"
- 00 gs400 battery replaced, horn going off? Help!
- A little shoot
- AC problems with passenger side
- 1998 GS300 Front Passenger Actuator
- Lexus GS300 Trunk
- Frame rumors/questions
- Got a CEL P0117
- Strange audio problem, is it unit failing?
- Clean '99 GS300 - What is it worth?
- 98 gs400 problem
- 2002 GS300 Catalytic and P0420
- Bad GS400 Gas Mileage
- Oxygen Sensor Part #
- 4 ohm Nakamichi speakers?
- Garaged lexus gs300
- New pics
- Chrome Peeling Off
- steering wheel swap-out possible???
- Putting a third brake light in a lexus GS430 after removing stock wing
- Darn it if I didn't break something... Timing Belt Swap
- Using the Stock Navigation Unit as a video and with ipod
- Help new starter
- headlight info about a swap
- Radiator Fan
- Mechanics Lien? Buy?
- Anyone decorate their interior?
- Need help with driver front door??
- Garage for DIYs in Chicagoland?
- GS400 engine swap into a GS300
- Question for those with hollowed cats
- 7" double din woodgrain dash trim?
- Noise at idle
- P1128 for a week now, Video inside
- fog light wattage question
- USPS Sucks..
- rear subwoofer not on at all.
- End of the road for my 2GS and I
- headlight wiring? quad projectors
- intake help! ran into a problem
- Inner tail light delete
- Why should I retrofit and not just get HID bulbs?
- Rwd + v8 + rain = drift yacht
- Help figuring out if I can install GROM audio in my 03 300
- Here's a few photo shoot shots for now...
- Radiator Cap: Type 1 or Type 2?
- Who's hit a dip and GS felt chippy after?
- Did My Steering Rack Bushings
- Torque Master Star Serie - or - Original
- It had to happen eventually
- Take a look
- GS300 Rear Tail light bulb question?
- HELP! Spare key Immobilized my car
- problem with heater
- Power steering fluid leaking on alternator
- Aftermarket style gauges?
- replaced alternator but ran into a problem
- Dtc p0125
- Who's rocking a bra on their Gs?
- oil leak after valve cover done.?
- Runs rough on initial start-up after resetting ECU
- Any good gs400 Valve cover gasket DIY's?
- strange clicking noise by center vents
- Won't stop starting!?
- Strange noise at startup on my '03 430
- Need an aristo gauage pod....
- Gs headlight retro, Dual Ls600 style projectors, LED turn signals, Bi-Xenon projector
- JP replica spoiler
- GS400 Steering wheel cable reel or???
- Yellow Check Oil Light Question
- GS400, noisy and clunky drivetrain.
- gs 300 mk2
- 1999 gs300 hvac blower problems I've tried it all
- what is the app name for android
- anybody with 20"x8.5 & 20"x10 rims
- Black interior, was it only available on silver and black vehicles?
- 99 GS400 fuel issue
- "Jobber" front bumper covers?
- Engine&Trans Swap 01 to 98??
- Another shake thread...my mechanic and I are stumped
- HALO HEADLIGHT - Good or Bad? Pro & Con?
- Bypass charcoal canister?
- FS and WTB threads go in the classifieds please
- Lock Actuator Cables
- Amazing front bumper on 2gs!
- Who's running high wattage HID lights
- 01 Steering wheel in a 98??
- AC Slide Guide/Servo Noise?
- Changed Starter, now car Cranks but wont start.
- Radiator Fans running 24/7?
- Just replaced my intermediate steering shaft...
- EU headlights, where to get them ?
- Stupid intake manifold question
- VAIS for 2001 GS430? Anyone?
- Weird suspension question
- The 2GS Throwback Thursday Thread
- 2002 lexus gs300 drl/high beam help
- jeez.........
- GS300 1998 A/C intermittant turn-on failure
- Parking Brake Light Not illuminating
- gs400 2jzgte swap
- 2002 GS430 turn signal sound
- Cargo net?
- Looking for some junction produce curtains
- No sound coming from speakers
- Ridin low ' Ding a rail?
- Help - 2gs steering rack pinion bushing kits
- Please help? TPS/APS ?
- 19"wheel fitment
- Please help me diagnose this engine noise!!
- When photographing your GS, what is the best stance?
- Check Engine light, puttering
- Another dash noise thread!
- Theft Deterrent Design
- Will similar yr SC/ES/RX airbag fit 02 steering wheel?
- Unlock Detection Switch Connector
- P0130, P0133, P0150, P0153, P0171 After TB Change
- Starting issue!! Help
- looking for obx or oem clear side markers
- One more steering shake thread
- Brake light out notification light came on...
- 02-03 Sports design vs regular
- Transmission Drain @300,000 miles..
- Lexus reliabilty downhill after 05-06?
- 1998 gs400 rear brake calipers not working...help plz
- GS400 Wiper Switch Intermittent Speed Not Working
- My brothers gs just stolen!!!!!!
- SOS! Please Help, GS400 running VERY ROUGH
- 01 Lexus GS 430 still thinks key is in ignition after removal
- "For sale" threads are only allowed in the classified section
- NEWBIE to the lexus game....
- Cel p0031
- Where did you mount your amp?
- 2001 GS300 ABS making squeaking noise
- Valve cover gaskets fail!
- 2002 Ls 430 alternator 2002 Gs430?
- First DIY oil change on my 2001 GS300, a few q's
- Need Help / Passenger side Fog light
- Help with 2001 Lexus Gs300
- D2R Hid Conversion Upgrade
- Should I buy this 2003 Lexus GS 300
- My 01 gs300 will hang between 2nd and 3rd gear
- Gs430 vs evo X gsr?
- Style 95
- whinnig noise! serpentine tensioner?
- BG 44K Fuel systems cleaner
- Need help identifying part
- Puddle Lights - Info Wanted
- Hub Rings... How Long They Last?
- Valve cover gasket and plugs
- Wheel offset?
- Weird lighting issue..
- Tail lights too bright?
- Weird Alarm Situation
- whats the best way to install a jp style spoiler??
- Anyone know what wheels these are?
- Differential bushings question
- New GS owner.
- Buying the car I have wanted since I was a teen
- Car not starting at random times
- My GS 3 Key Situation
- Low voltage to headlight
- Why No More E-Shift?
- [Help Request]2002 Lexus GS 300 - A/C Screen Doesn't Display Information & Mirrors
- Parking Car Outside...Need Advice
- Oil leak? Please help
- My GS at Wekfest Carshow 08.10.14
- Help my lic plate bulbs out!!!!
- Carpet Cleaning - bring out the big guns?
- Oil leak help!
- Aftermarket HID Halo Headlights for GS430
- New to 2GS, tackled the evaporator core thanks to this site
- Lexus traction control saved my life
- navigation face plate replacement
- Just ordered some parts/stance questions
- Thats all folks Bought a new car...
- Keep hood pins or not ????
- Aftermarket flip out key works great !!!!
- Thinking about getting a new grille...
- FUN FRIDAY: X-ray'd a GS key
- city light removal help please..
- Cam & Crank sensor locations? GS400
- To "Blow It Out" or not. That is the question
- Installing after market alarm, anyone??
- I broke my door and don't know how to fix it...
- I need help!!!
- Opinions on 01 GS430?
- Another P0420 & P0430 Question
- It's my 10th Anniversary!....
- Stock Headlight Replacement (HIDs)
- New to the forum
- How to remove glove compartment?
- This isn't the classifieds....
- New to the site
- 1999 gs400 in service need advice plz
- Gasoline difference?
- A/C- Driver side cold, passenger side hot
- 1999gs400 vs 2004gs430ride quality
- Gs300 Door Lock Actuator
- Headlights conversion ? UK to EU
