- black wire latch for door handle locks
- HID Lights
- Need help please...trunk
- LSUGS430 Wreck
- Headlight refurb.
- Tranny and Engine mounts sheared off in accident
- back in a sedan
- Anyone got the Python auto smart start?
- interchangeable struts? gs to ls400?
- Advice needed: Dealer says new CATs and Master cylinder
- Bellezza Neck Pads???
- Invasion of the 2GS
- My 01 Gs430...
- My Cars Finally Somewhat Done
- Need help!! Coil pack clips
- pillar covers?
- Does anyone know what % my window tint is?
- New to the gs but not to CL
- Anyone?
- Wheel speed sensor question?
- New wheels...thoughts?
- Took a few photos of my car (Minty GS)
- Is my car worth anything?
- 2002 lexus gs430 check engine light help!
- Headgasket DIY?
- Crack navi LCD
- engine swap questions
- Jdm 2jz-ge vs usdm 2jz-ge
- where to buy decal?
- Need Help|Input
- How many resonators are on a gs430
- Crown Royal Shift Boot
- GS 300 o2 sensors
- New /old wheels on the Lex
- blower motor whining at low speed...
- 2001 GS300 overheating problems
- Did I screw up while changing timing belt?
- vsc limp mode
- How to diagnose a 2jz headgasket
- Took apart console to fix SHIFTER and now my KEY won't come out of ignition!
- Still getting vibration in my steering wheel
- Back from paint! Formula red.
- GS 400 YAY Ofcourse...
- Lamps getting stolen
- Help with Blitz Dual SBC Boost controller
- Looks like I will be saying goodbye to Lexus and hello to toyota
- Low-pitch creaking sound
- high idle, low stuttering idle, limp mode, than stall. gs300
- Window has a mind of its own!!
- Whining sound from power steering?
- Traction Control not working.
- The Noob
- Trying make decision on replacing engine / tranny
- Random Trip Pic of the Unicorn
- Noobie question about replacing stock stereo
- Another 2nd GS300
- Rear inner trunk lights to be used as rear fog lights?
- ABS Pic Needed
- What do I replace my GS with?
- gs400 died, tps app maf?
- Finally done!
- Lexus GS 300 Squeaking noise
- issue with tire squealing and steering
- Another exhaust question about drone.
- Ebay Wheel Spacers? Terrible Idea?...
- P0753 code Shift solenoid "a"
- Fog lights turn off and on
- Did alot of work today and added some goodies
- Slip indicator light keeps coming on
- '99 GS300 rear bumper removal
- Bye GS.
- ebay roof spoiler
- Motor Mounts GS400 vs. GS300
- GS400 - No Power-Battery Is Good
- Hey guys im back!!
- What power steering sensor is it?
- Master Cylinder - Sensor Swap?
- Sourcing AB-Flug carbon spoiler extension
- Bolt-in seats?
- My axel back EVO II exhaust replica!!
- Maintenance....decisions
- GS430 2007 ECB Control Module
- Has ANYONE passed emissions with a 2jzgte swap?
- GS 400 unreliable?
- Air Fuel Ratio Problem Running at 10.0
- Lexus GS300 1999 USB Changer
- WTB and FS goes in the classifieds
- Halo Headlights
- gs300 tranny and torque converter HELP!!!
- DIY: Installing an 01+ radio in a 98-00
- Rhd 2GS?
- Timing belt
- help on parking lights on 2000 gs 300
- The dreaded top end clicking noise
- Compiling parts for my aristo swap. I have a few questions
- Shaking around 55 to 65mphs fixed!!
- Feels like 2 chicks in my car
- constant shake after 50? PLEASE HELP!
- Sport Design Trunk Spoiler.
- Electric Motor Noise behind the dash
- Looking for the right HID Bulb for 2003 GS430 headlight
- Anyone from Europe, Asia or Oceania?
- Neojungle1 Aristo photo shoot part 2
- Buying JZS161 Aristo what to look for?
- GS 400 1998 Love this car but . . .
- PCV hose
- Anyone know where you can get halogen headlights??
- Updated: GS430
- Front passenger AC blows hot air??
- Newbie-First Post & Questions For You All!
- Street beat customs air bag kit?
- Steering wheel 90 degrees off
- Anyone know why this happens?
- PS Relocation parts with PN'S and tt throttle cable
- No sound/audio???
- Where to find Sport Design Grey trim
- 2000 gs400 power steering fluid leak any ideas
- Center Console removal-1999 GS300
- Gasket or Sealant for Water Pump to Engine
- Black tape weights?
- Engine light is on after front end accident should only Lexus only look at it?
- EFI Relay Clicking
- Fl2k13
- Door lock problem
- Looking to buy air ride...
- gte swap shifter problem
- Maintenance Advice - Struts, Airbag, ABS
- Exhaust Tip Question/Info
- The heat is on! + New JP Shade...
- AC compressor pulley not spinning??
- The.Start.
- bumper and lip bond question (fiberglass to plastic)
- FS and WTB threads go in the classifieds
- Engine light and vsc lights on code p1120 & p1121
- Accident crushed my front wrecked engine?
- 2000 gs300 stock radio
- 2000 GS300 A/c not blowing cold.
- lowered my car another inch..... (cont)
- Why is it so hard selling 2gs?
- 98 gs doors locking
- 10mm Spacers - noobish question
- any members here
- New to Club Lexus
- How Long Do GS 430’s Last?
- Y pipe exhaust leak
- Any double din kit that doesn't suck?
- Will a 2uz alternator work on a 1uz?
- Yay or nay???
- IS and GS Bumper Conversion
- '06 IS350 Front and Rear Bumper to '01 GS430 Bumper Conversion
- How to make these wheels hella flush?
- 98 GS300 won't start.
- 2001 gs430 on 2013 GS-F wheels
- 2001 GS300 totaled!
- 03 GS300: Buzzing sounds coming from behind/under dashboard
- The Million Mile Lexus GS
- lexus gs400 gauge cluster
- will this wheel set up fit? get your answers here
- Check engine light
- Led side mirrors from nigel
- 2000 gs 300 A/C has warm air blowing
- missed her
- Buying a GS300
- 98 Gs 400 Tire wear
- Getting conflicting advice on tire sizes for staggered setup
- Highway shots :)
- 1999 GS300 - CEL codes P1120 and P1121
- Any Opinions?
- Factory amp
- Small lights
- 2002 GS300 Heater Problem
- 2nd gen gs300
- Where is the ECU on this Jalopie
- help with gs300 codes
- which fogs are more rare or better? Clear or yellow
- Front Bumper?
- Did the maf clean today good results...
- Slight misfire sometimes at idle??
- aristo motor mount brackets
- Steering wheel removal question
- GS300 FM radio quality.
- Help with finding service manual
- GS400 Lighter and Power Plug fuse problem
- Rear light warning turned on
- First Time GS Owner
- $650 for this repair. Sounds reasonable?
- Leaking Coolant Reservoir
- 1st gen IS vs 2nd gen GS specs?
- Question-gaskets- prepping for boost
- Bad height control sensor?
- Poor Gas Mileage Black Soot
- Picking up my 2001 GS300 today
- Hids for fog light question
- 2013 gs430 wheels on 2002 gs300
- white seats on a toyota aristo
- MP PHANTOM version / JZS16# ARISTO
- looking for sponsers for mygs300 for sema
- Factory match possible with aftermarket headlight?
- Transmission swap
- Looking to buy a 1998 gs300 tomorrow what to look for
- How to prep the Ebay 3 peice jp rep spoiler?
- Does my 1999 GS300 have a Karman-Vortex air flow sensor? Is CRC safe to use?
- Stock side stripe....
- GS430 2003 Power door locks engage/disengage partially
- 2003 GS430 Navigation failure
- Every two years- starter burns out. Why?
- Photoshoot with my new Weds!!! :D
- Is the wheel supposed to spin like this?
- Car Pulls To Different Directions....
- Finally decided to mod the GS
- GPS Antenna Location ?
- error codes
- A/C repaired by dealer and check engine light stays on
- Who has custom bracket for centrifugal supercharger or secondary alternator?
- jacking up car
- New member questions
- Hacking (retrofitting) steering wheel audio controls for aftermarket headunit
- Looking for stock mid pipe for GS400
- New Member, 04 GS300 Hello All
- New here, saying hello. 99 GS400
- IS250/350 seats in GS3/400
- need help....diy fog light
- Pic of the car, only one :-/
- Jdm swap and fabrication in the orlando florida area ??
- Headlight swap.
- Key fob / remote malfunctioning
- Inner Depo LED Taillight Acting Up?
- Update update update!! Problem solved!
- Best gas mileage!!!!
- 99 gs3 with electric germlins
- Coolant hose
- So frustrated! First Lexus and horrible experience!!
- GS 400: 4th gear delays shifting into 5th - D mode
- 2000 Lexus GS300 error code P1120
- Black Chrome LP...
- Has anyone replaced their factory GS400 rear deck sub with a free air................
- GS400 buying advice for Lexus/CL n00b
- Toyota/Lexus Trouble Code List
- Really look for advice on what my car is worth...Super Clean 2000 GTE swap..
- speedo swap kph to mph?
- Fuse question
- What are the best spark plugs?
- Very sluggish but no codes please help
- how stretch can you go?
- Thoughts on 3m vinyl wrap?
- Brand spanking new to me '98 GS400
- alignment setting questions- how much camber is too much camber
- 01 GS430 Tanabe Medallion Exhaust Gasket question
- Gs headlight lens compadability between Xenon and Halogen
- Window trim
