Blank Navigation Screen
Old Dec 7, 2013 | 06:11 PM
GS400NYC's Avatar
GS400NYC
Default Blank Navigation Screen
Hello All,
My navigation screen is now totally blank 90% of the time. When I'm lucky and turn on the car the navigation screen turns on just fine and after driving for a few minutes it just turns ALL WHITE and I cannot see a thing. The touch pad still works so I can still change radio stations, climate controls, etc. It is just a nuisance to memorize where each button is located and whatnot. Any advice on what it can be? Would the entire screen need to be replaced or can it be fixed? I would certainly appreciate any info!!
Old Dec 7, 2013 | 06:38 PM
gsean400's Avatar
gsean400
Chances are you will need a whole new navi. Unless you open it up yourself and look for loose wires.
Old Dec 7, 2013 | 06:48 PM
GS400NYC's Avatar
GS400NYC
if i do need a whole new navi, any recommendations which are the best fit for our particular make/model?
Old Dec 7, 2013 | 06:53 PM
iToaster's Avatar
iToaster
CL Folding 1,000,000
Buy a replacement factory unit on eBay. Nobody wants them, so they're usually pretty cheap.
Old Dec 7, 2013 | 07:00 PM
GS400NYC's Avatar
GS400NYC
iToaster,
Unless i'm looking at the wrong products, these units are going for $500+… am i missing something here?
Old Dec 7, 2013 | 07:01 PM
GS400NYC's Avatar
GS400NYC
if i'm going to spend $500+ I'd rather buy something newer and updated.
Old Dec 7, 2013 | 08:34 PM
DosyBoy's Avatar
DosyBoy
Yea unfortunately their actually boo-koo bucks on ebay unfortunately, I've never seen one under $500
Old Dec 7, 2013 | 08:51 PM
iToaster's Avatar
iToaster
I'm assuming you've got a GS 400 with the early style navigation, http://www.ebay.com/itm/98-05-lexus-GS300-Gs400-navi-navigation-screen-player-unit-88650-3A230-/121151868606?pt=Car_Audio_Video&hash=item1c3536cebe&vxp=mtr. If you go aftermarket you're going to have to buy a climate control panel and rewire the stereo system, so buying a plug and play unit is going to save you a lot of trouble.
Old Feb 4, 2023 | 02:50 AM
AaronH8236's Avatar
AaronH8236
1st Gear
Default Solution found
Hello all. I had the same issue with my 1998 Lexus Gs400 Navigation. When I’d start up my car the screen would turn white as well. I realized my only couple of options were to deal with it , buy a factory used replacement but those run $500+ or buy a climate control unit and then another headunit and deal with the hassle of rewiring everything. i really didn’t want to do any of those. but i figured out that if you can just keep putting your car in and out of accessory mode until the lexus logo pops up like normal and not the white screen , then you can start up your car and it’ll be just fine. but obviously you don’t wanna keep having to do this. but i figured out. if you press “screen off” button before you turn off your car , once you turn it on again it’ll still be off. then you can press menu to open it back up to normal which completely bypasses the logo load up which is the problem and where the white screen occurs. just gotta make sure everytime u turn off the car to hit screen off. yeah it’s kinda annoying but way better than having a white screen all the time and easier than buying a expensive replacement or rewiring something else in. lmk if that helps anyone!
eugenez
NX - 1st Gen (2015-2021)
Oct 19, 2015 08:15 PM
teamcalvin
IS F (2008-2014)
Oct 6, 2014 10:40 AM
Asiatic
Dec 8, 2012 07:37 PM
RGAltman
Sep 3, 2009 05:09 AM
slowmotion
Sep 23, 2003 11:44 AM
