View Full Version : Suspension and Brakes
Pages :
9]
13
14
15
16
17
18
19
20
- Anyone running the SPC front camber kit?
- 09 Sport Package Shocks w/Revised F-Sport Springs
- Spongy brake help!
- F-sport shock collet ( spacer ) ?
- H&R w/ 17s
- Road Magnet spring
- What color should i paint my calipers?
- Opinions on Tein SS Coils?
- Need help with brakes on 250awd
- ISF Springs/shocks on IS350
- brake calibers
- LCA bolt
- AWD IS250 Front Brake Conversion to IS350 Help
- Need Help Verifying BC BR Coils Spring Rate
- Shipped wrong spring rate on BCR Coils?
- A question about stock 17" rims compatibility with akata spacers..
- Question about Brake Fluid Change - safe to drive?
- 19's Lowered on F-Sport Springs
- Wheel gap problem I can't figure out
- Anyone done this brake TSB yet?
- Best Shock with H&R setup?
- Centric Brake/Rotor install
- D2 racing coilovers or BCR coilovers
- Need help with a 2011 AWD F-Sport sway bar Part Number
- UAS/ksport/Accuair
- brake dust
- Need Help after Rotor and Brake Pad Install
- UAS with Megan EZ's. Questions!
- 09 2IS AWD Brakepad and Rotors?
- Road Magnets or eibach
- F-Sport Springs (revised)
- My Summer Setup
- Finally! Megan EZ Streets on IS250. (Pictures!!)
- Help: ABS BREAK check light on????
- Steering wheels vibrating and goin free dips, car moves a little, please help
- Best stock for stock replacement for leaking struts - '06 IS250
- 09 IS350 sport package
- Megan street Lp coilover good.
- 09' IS350 Front sway bar only
- QUESTION! Megan EZ Streets...
- Help weather coilover or springs on my awd is250 help!!!!!!!!!!!plssssss
- Planning on droppin my is250 awd and recommendation
- Sewell F-Sport Lowing Set
- Brakes service - what do I need?
- Lowest of the Low!!! Coilovers only please!!! IS Second Gen Edition
- Shaking after replacing rotors and pads
- Brake Noise
- Need Help Taking Rotors Off
- Megan EZ Street coils QUESTION
- Just got my alignment done
- Replacement shocks
- Megan Camber arms.
- 【IS250 AWD】 H&R vs. Road Magnet
- Replacement Shocks-Stock 07 IS 350
- brake light stays on
- ~.6 mm left on IS350 front rotors. Should I replace with pads?
- Cool
- I had a problem with H&R spring, can some1 please help?
- Low Dust Pads?
- internal ventilation points forward on is350 front rotors?
- wheel shaking
- Front brake job $895 @ Dealer
- machining 3mm off IS350 front calipers
- QUICK question for BC racing
- Quick help
- Soft Brakes on IS350
- is350 front brakes
- F-Sport Front Sway Bar-Sewell
- Is this sound my pad wear indicators?
- Opinions on F-Sport Sway Bars
- Front brake rotor ?
- Tein Comfort Sport
- springs or coilovers???
- IS250 - best brake upgrade?
- used springs and coils
- Lowered IS350 on F-sport shocks and H&R Springs
- Left & Right axles blown at 50k PLEASE HELP
- Need some brake help
- Shocks - Tokico HP or F-Sport?
- F Sport springs and wheel alignment
- F-sports with 20'' pics :D
- Dropped 20'' on f-sports scrapping HELPPPPP
- StopTech Front Rotors for IS350
- IS250 AWD Rear rotors and pad replacement
- ISF Brakes on IS350
- Pics of my Front Pads, Do I need replacements?
- Do HAWK HPS come with shims for is350?
- Bleeding brakes "Not Working"??????
- Fsport springs hitting on big bumps!
- Significant ride quality difference between 18 and 19"?
- Opinon Fsport Front Sway Bar vs Fsport Springs
- H&R Lowering springs
- f-sport shocks... where to buy?
- Just lowered with H&R Springs
- How low can I go w/o Rubbing or Fender Mods
- Opinions: F-Sport vs. H-Tech
- Need springs and camber kit!
- Tien High Tech Springs
- Springs starting to rattle after 6 months
- F-Sport spring alignment question
- Can Tein S-tech or H&R springs go on the 2011/12 IS350 F sport package?
- Recently Installed H&R's Now Have Alignment Issues
- Eibach, H&R or Tien Springs?
- Drop with spacers?
- Best brake and rotor combo?
- Isf suspension on is350/250
- Is250/350 brake question/help?
- Neeed a little explaining! [brake fluid dripping from resevoir after pad/rotor swap]
- Brake pads and Rotors
- Re: F Sport Springs on IS250
- Rear camber kit
- Drilled and slotted brake rotors pads front and rear
- most comfortable coilovers?????
- lowering and other up-grades
- new version F-sport spring.. clunk noise problem!!!
- Best Shocks
- Alignment Help
- Posi-quiet brake pads.
- IS350 Front sway bar
- Cross drilled/slotted r1 concepts!!
- Will f-sports still go down 1'' if i have stock sport suspention?n inch like it says?
- Under chassis brace
- SPC front ball joints
- torque specs for the is350 brakes front and bac
- Brake Grinding after reinstall
- H&R or F-Sport springs ?
- IS350 brakes and rotors help
- Question about rear sway install
- FIGS Rear 2IS EE MEGA arm new weldment
- IS350 SPC adjustable ball joints...WIN!
- f sport springs
- car leaning to the right when driving straight line do i need a camber kit?
- Hard race rear : Camber arm, toe arm, thrust arm and lca (lower control arm)
- Who's blown a (Stock) shock? What suspension were you on?
- What is the best coilovers for RWD IS250?
- 2011 IS250 F Sport Suspension Coversion
- Will this cure Lexus Lean??
- Help: camber kit installation
- IS250 small brakes are weak
- 350 AWD F-Sport sway bars
- c8 sport ssd+ coilover
- F Sport Springs
- is250 AWD rotors and brakes
- Looking to replace rotors on an 07 IS250 AWD
- is anyone on the F-sport shock and springs??
- Spring recommendations??
- Rear caliper
- where to put anti squeal grease
- Need some advice and samples for is250 AWD - BC's VS F-Sport
- Missing Pieces
- Buddy Club D1 Spec Coilovers....anyone have a review?
- Break pads/Rotors Suggestions?
- Picture of IS on H&R Springs
- Alignment
- Front brake pads
- Question about Megan Springs vs Tein S-Tech
- best brake painting in socal?
- BCR coilovers install
- Springs
- Tire wear
- f-sport springs with 20's
- Inside rear tire lifting around corners on BCR Coils/F-Sport Sways
- Coilover suggestions
- 08 350: rotors or brake pads?
- Ceased Calipers
- new shim and fit kit necessary?
- lowered with 20s question
- F-Sport BBK: Same kit for IS350 and GS350?
- Questions about dropping my is250
- Megan racing camber kits
- alignment specs
- pic of my brake pads
- megan ez coilovers Damper Knob extensions
- Brakes too small
- IS250C F-Sport Spring compatible with IS250 Sedan?
- GOT Coils? Show us!
- Installed BC Racing coils over the weekend
- F-Sport Brace and Sway Bars
- ABout to buy bc coilovers, do i purchase the package with extenders?
- Need advice on turning or replacing rotors
- Midas for breaks?
- used coils question
- 2008 IS250 Harsh Stock Suspension
- F-sport springs or Road magnets for IS250 AWD?
- Where's a good place to buy coilovers?
- fsport springs on awd
- AIR Suspension
- What options are there for AWD Coilovers?
- Help!! Tokico shocks & h&r springs???
- BC Coilovers-how is the ride quality?
- What were your camber specs after your drop?
- Big Brake Kits.. $$$$!!!
- Megan LP vs BC BR Coilovers
- Pic Request: 225/40/18 on stock suspension
- Question About Brake Pads?
- new coils
- H&R Lowering springs ??
- Eibach lowering springs on an AWD
- Finally! No more squealing!
- Is250 sway bar upgrades
- 88 Rotors
- cutting rear fenders.
- Best Lowering Springs for IS350?
- Tein cs stance question
- Just have the Megan LP installed
- IS350 Dustless Brake Pads
- ~IS a camber kit made the car look lower more~
- F Sport Suspension: Old style VS. New Style?
- M7 super street performance damper!
- Tires
- Another New Tanabe Coilover
- Need Help Choosing: Springs or Coils
- What do you think this might be?
- I need help ASAP BCR Coilovers Uneven drop
- 250 oem rear sway will it fit on 350 oem rear ?
- 09 IS250 AWD brake pads
- F-Sport or H&R? Need opinions please
- Anyone seen this happen??
- is350 brake dust
- aftermarket springs with stock shocks
- Coilover Recommendations?
- How many miles on megan LP's??
- DIY Parking Brake Adjustment
- F-sport shocks with oem sports package springs
- F-Sport Calipers Locked Up
- lexus is 350 front brake pads/rotors
- How can I adjust this / \???
- F-sport springs from dealer
- Changing Brake Pads
- F Sport Springs on '06 IS350 (With Pics!)
- Is There A Difference Between 2008 & 2009 Brakes?
- NoOb question
- anyone slammed on megan lp coils?
- 2IS300 chassis compatibility with 2ISX50 (sway bars, springs, shocks, exhaust?)
- megan lp coils
- Hotchkis or FSport?
- Megan Racing LCA
- Caliper color advice on New IS350
- Sewell brake pads, low dust?
- 350 AWD & F-Sport Lowering Springs
- Rotor replacement required going from OEM to ceramic pads on IS 250?
- New Tanabe Z40 Coilovers
- Question re. IS250 suspension
- Rear Shocks need replacement on my 07 IS350
- After installing lower springs, is this normal?
- Fsport Front vs. Rear Sway Bar
- Road Magnets!! Wanna see Pictures!!
- IS 350 Brake squeaking
- IS 350 Break squeaking
- Splash guard is250
