is350 front brakes
Old Mar 29, 2012 | 03:41 PM
Magicks's Avatar
Magicks
Default is350 front brakes
I changed all 4 pads 10000 miles ago and the pads at the front passenger side is almost wore out(10%). My front driver side has at least 50-60% and both rear pads have about 80-85%.
Anyone has any idea why my pads are wearing out so unevenly?
Also, I might need to change my rotors since my mechanic said I only have 1mm more than the minimal requirement on the rotors. Should I stick to OEM or go for aftermarket? Thanks.
Old Mar 29, 2012 | 08:31 PM
Kurtz's Avatar
Kurtz
You can get centric premium blanks cheaper than OEM and they'll do the same job rotorwise
Maybe you've got a sticky caliper on the one pad that's wearing out unusually?
Old Mar 29, 2012 | 10:07 PM
Magicks's Avatar
Magicks
what do you mean by sticky caliper?
are these the centric premium blanks that you are talking about? I got this from rockauto.com
http://www.rockauto.com/catalog/moreinfo.php?pk=1279312
http://www.rockauto.com/catalog/moreinfo.php?pk=1280128
Old Mar 30, 2012 | 05:52 AM
Kurtz's Avatar
Kurtz
http://www.ehow.com/how_7764344_diag...-calipers.html
and yeah those look correct on the rotors...note the front left and right are a different part- rears are the same left and right.
Old Mar 30, 2012 | 09:07 AM
RocketGuy3's Avatar
RocketGuy3
The original thickness of the rotors is 30mm and the minimum thickness is 27mm. If you have 1mm left, that means you have 33% of the useful life of the rotors remaining. Way too early to replace them.
Out of curiosity, how many miles do you have on the rotors?
Old Mar 30, 2012 | 11:54 AM
Magicks's Avatar
Magicks
I am at 106000 miles and I've resurfaced them once.
nathantse
Aug 9, 2018 01:29 PM
Gerb
Nov 18, 2014 06:37 PM
taze
Maintenance
Dec 6, 2008 05:59 PM
