where to put anti squeal grease
02-23-12, 05:04 PM
which parts am I supposed to put the grease on when doing the brake pads? only the shims? which sides? back of the pad?
02-23-12, 05:09 PM
Between the shim and brake pads
02-23-12, 05:53 PM
02-23-12, 07:32 PM
and it should go without saying NOT on the rotor, and pad surface, but some people read these forums and don't get told where not to do something...
02-23-12, 07:55 PM
as said above on the pin and between the shim and back of the pad... no where else. haha
02-23-12, 08:13 PM
Fire Slayer
you can probably ask that same question on You Tube and have a video also.
02-23-12, 09:02 PM
Between the pad and the rotor, most of it on the rotor
Smoke is normal.
edit: j/k don't put any on the pad just on the rotor.
double edit: it help the pads slide more quietly on the rotors, fyi.
Diesel350
IS F (2008-2014)
13
04-11-20 08:02 AM
Revived
02-26-17 07:01 PM
jdm_altzza
IS F (2008-2014)
19
06-30-16 08:07 PM
hybridanim
Suspension and Brakes
04-05-11 05:22 PM
LexLS
Maintenance
10-23-03 12:46 PM
1995 ,
anti ,
antisqueal ,
brakes ,
car ,
end ,
front ,
grease ,
is300 ,
lexus ,
ls400 ,
put ,
shim ,
sqeaking ,
squeal ,
tire
