Changing Brake Pads
Old Jan 1, 2012 | 02:08 PM
Nanosuke's Avatar
Nanosuke
Default Changing Brake Pads
I have a 2007 IS250 AWD and I'm thinking of switching the brake pads. Would I need to switch the rotor along with it or can I just switch the pads?
Old Jan 1, 2012 | 04:24 PM
Kurtz's Avatar
Kurtz
If you mean you plan to put on new pads of the same kind because the old ones are worn out, as long as there's nothing wrong with the rotor/braking now, just put on new pads, bed them properly, and go.
If you mean you plan to switch to some other different pad I suppose my question would be why?
Old Jan 1, 2012 | 04:55 PM
CarbonDtls's Avatar
CarbonDtls
Put the new pads in and your good to go.
But if you feel your rotors are uneven you should get them resurfaced. Its unlikely they are but check to see if the rotor surface is smooth and even on both sides.
Old Jan 2, 2012 | 05:43 AM
jbjones85's Avatar
jbjones85
No need to do anything to the rotors other than check to see that they are still within the thickness spec.
-Install new pads; bed them; and go.
Old Jan 2, 2012 | 10:38 AM
VIS250P's Avatar
VIS250P
Are they have minimum or deep groove rotor?? Yep get the thickness spec on the rotor to make sure nothing under 26mm.. If u feel vibrate, yeah had to replace rotors or machine rotors.. Depend
LexusLadi
Apr 2, 2015 11:49 AM
hybridanim
Suspension and Brakes
Apr 5, 2011 05:22 PM
MidnightGS
Dec 19, 2010 05:25 AM
LexLS
Maintenance
Oct 23, 2003 12:46 PM
tocoolexus
Nov 28, 2001 08:23 AM
