PDA
View Full Version : Performance & Maintenance
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86
  1. Mass airflow delete? Possible?
  2. Hard Start, Speedometer & Tachometer Doesn't work
  3. Sc400 auto swap
  4. intercooler pipeing.... need opinions
  5. sc300 exhaust question
  6. Gas Gauge
  7. Nitrous and Fuel Line
  8. SC430 3.26 Diff??
  9. Anyplace sell 1jz gasket sets anymore?
  10. sc400 95year diagnostic
  11. Alternator question
  12. 2jz-ge q45 toyota tps adapter?
  13. Rear Bulb Out Indicator ON...
  14. HELP, I have high NOX and cant pass CA smog
  15. Sound Proofing?
  16. Bad Cats overheat 96 sc400 (168000 mi)?
  17. buckwheats sc 300
  18. 93 SC 400 running bad
  19. Hose off heater control valve
  20. 99 sc won't start.
  21. Engine Bay Harness
  22. Wastegate options on 2jzge turbo manifold?!
  23. JDM ECU Piggyback Setups - post them up
  24. car suddenly running bad
  25. has anyone used seafoam to lower NOX levels
  26. Powder coated the rear diff today!
  27. SC 400 '95 Transmission Front flange
  28. 92 sc300 hard start help
  29. Clutch, ebay vs. jcwhitney any good?? help
  30. O2 sensor question
  31. SC400 probs
  32. 1JZGTE IACV Bypass?
  33. A/c delete serpentine belt part number?
  34. Unusually High Idle After Driving
  35. Precision 6365H or Precision 7068
  36. Automatic Transmission Fluid
  37. 1993 Sc300 Build
  38. '00' SC400 code P0121 $1750 for repair?
  39. OBX Headers for SC400. Who's going to be the Guinea Pig?
  40. maintance: breaks and rotors... gas tank pressure?
  41. Can I use evo 8 560cc injectors?
  42. ENGINE BLOCK Bolt Ears (holes) for Trans broken off
  43. help me identify injectors
  44. PCV Valve Replacement
  45. Fuel pump problem
  46. 1995 sc400 crossed battery terminals no power
  47. O/D Flashing DTC89: Need help removing code
  48. help! rpm goes really high when i start my SC400
  49. 1jz aeromotive fpr install help!!!
  50. Na-T Crank Seal Issues
  51. 92 sc300 tons of white smoke and now motor wont turn over WTF!?!?
  52. 1992 sc400 lack of power
  53. FFIM on auto sc300
  54. 1UZ Vs 06 BMW M Roadster
  55. Help SC400 overheating and boiling coolant!!!
  56. 2jzge spark cutting off at high rpm
  57. Just started my 2jzgte swap!
  58. Trans and motor mounts question
  59. Need help with my na-t sc300!!
  60. Seized spark plug
  61. 1jz aluminium piping leak
  62. Short and Simple.
  63. 1jz hydro fan options
  64. sc400 spectre 10.5inch intake
  65. Intake resonance chamber
  66. Power steering completely dead
  67. Car wont start, thinking its the starter.
  68. Throw out bearing spacer.
  69. Removed resonators. i am dissapoint.
  70. any 1jz vvti running tomei arms m8280 turbo?
  71. 1jz and emissions!
  72. 2jzgte power fc guys!
  73. is it safe to buy a 1jzgte ??????? need advice
  74. 2JZGTE head and intake manifold
  75. 1999 sc300 CEL code P0155
  76. 1992 SC400 failed smog in CA
  77. Starter gone bad, can i get to it without lifting the car?
  78. Coolant bleeder valve 92 sc 400
  79. Hx35 Holset Help
  80. Turbo UZ guys simple question.
  81. Few questions I have about future mods
  82. sc300 project help please!!
  83. what tranny would you go with and why?
  84. Wants to turn off when I complete stop.
  85. Plugs / wires / oil weight
  86. rear diff...
  87. Coolant Tank Sensor / reserve tank assy
  88. Howe Throwout Failure?
  89. swap help - ECU???
  90. What would cause my Fuel Pump to stay ON after I turn off the car?
  91. Won't start
  92. complete NA
  93. 2jzgte vvti swap issues with speed sensor.
  94. Rear subframe 1993 sc300
  95. Sc300 turns off randomly
  96. engine oil leak-iuz-fe
  97. which tranny cooler?
  98. should i add a tranny cooler on single turbo 2jzgte
  99. 1997 sc300 ecu help
  100. car jerks forward and backward when driving
  101. Fuel Pump stays running (No 12V mod)
  102. Weard power steering problem
  103. injectors question
  104. Heat valve
  105. Tranny won't shift out of Park
  106. Fuel economy specifically with 1JZ VVT-i stock/BPU and R154 5-speed and LSD 4.083:1
  107. A/C Diagnostics
  108. Dash light problem
  109. is dark gunk/oil normal under valve covers of jdm aristo motorset?
  110. help with my exhaust leak
  111. Battery light on but alternator and Battery are ok...HELP???
  112. Need to get things cleared up! Help!
  113. 93 SC300 Aristo Swap No Temp Or Tach After Fix
  114. SC400 not starting, help plz
  115. Hesitation misfire during steady acceleration and when stopped with load on motor
  116. fuel symptoms
  117. 1jzgte downpipe options?
  118. need help please sc300 issue
  119. car problems
  120. fuel tank vent line in engine bay question.
  121. white smoke, power steering issue (acv)
  122. Problems with electrical and now ignition. Need help.
  123. DIY: Install Metal Interior Door Handles
  124. my exhaust
  125. Branch Resonator on SC300?
  126. Tail lights
  127. Ignition timing
  128. 1992 lexus SC300 2jzgte jzs147 (HELP ???)
  129. 93 SC400 using coolant in overflow tank
  130. Installing Engine with transmission attached
  131. Hesitation and idle issues after Head Gasket install
  132. Gte guys what is this for?
  133. Help! How to install harmonic balancer?? Special tool?
  134. Where to get the rear crossmember/diff bushing?
  135. Where to get the rear crossmember/diff bushing?
  136. MAF adaptation for 98+ vvti sc300
  137. High pressure powersteering hose Where to buy?
  138. 1jz-gte vs. Turboed 2jz-ge
  139. Other Small Issues.
  140. Headlight Relay Issue + Wont Crank
  141. Clutch Return Spring Problem?
  142. sc400 pcm in a sc300
  143. 99 sc300 starter removal
  144. 1jzgte White smoke
  145. 95 SC 400 Blower moter going high then low Showing codes 21 and 43.
  146. Interference Engine
  147. Engine Trouble 92 SC400
  148. Starting problem please help!! Vids inside
  149. Turboing my sc300
  150. Need help with valve cover gasket!
  151. Who has done the vvti to non conversion???
  152. Map sensor wire diagram or colors heeeellllllpppp!!!!!!!
  153. Code 22 Engine Coolant Temp Circuit
  154. Looking for Bart???
  155. Supra Fuel Pump in Sc300
  156. trans code 42 and engine code 29 not revving past 4k in 1st
  157. Diagnosis Assistance Needed 92 SC400
  158. sc300 wont start ... some input/suggestions please
  159. Take off sucks!
  160. 1997 sc300 p0401 HELP
  161. Where does this intake vacuum line go??
  162. Anyone ever use the Transgo 340-HD2 shift kit? Just bought one going to install.
  163. pcm / ecu part number interchange
  164. speedometer subassembly gear
  165. Fluid leak. At a loss...
  166. 93 sc400 smog please help !!!!
  167. Bought the SupraStick; Need paddle shifters?
  168. car finaly gave up maybe?
  169. sc300 w58 vs mk3 w58 tail housing length.
  170. Chaser Auto tranny in SC300?
  171. 1997 sc300 P0171
  172. Better than BFI
  173. Want to know if 2001 m5 motor can fit
  174. precat worries
  175. Sc400 Warm Issues, and no spark (Sometimes)
  176. 1998 sc300 turbo help
  177. Need some Help, Engine Dies
  178. r154 slip yoke
  179. sc400 oil light on
  180. pros vs cons remote oil pan/pump for 1uz turbo
  181. When do we change our water pump?
  182. Tuning a 1jzgte single turbo with E-Manage...?
  183. Does anyone know what this exhaust is?
  184. Help on MSD 8920 Install *searched*
  185. Single turbo guys
  186. Need an estimate
  187. How can I verify That a Transmission is an R154?
  188. Burning up MAFs
  189. check engine & trac off lights on after mild tune up
  190. Exhaust leak help.
  191. Engine randomly shutting off while driving
  192. Brian Crower 1jz 264 camshaft results.
  193. High HC on smog SC300 - changed everything
  194. A new FFIM offering for the 2JZGE?
  195. have somebody experience with this upgrage ct15b
  196. injector and what?
  197. Heart Transplant
  198. some advice please? one of my turbos has an issue
  199. just wanted to share this video
  200. Custom Exhaust Front Pipe?
  201. P1121 code, tried a few things but nothing! Help!
  202. Brass radiator SC400: Prestone or Toyota Red?
  203. P0171- help
  204. SUUUPER frustrating Code 14(Ignition Signal) OBD1 issue.
  205. Overheating
  206. sc300 manual front driveshaft length
  207. HELP! Problem with Car..
  208. Best auto trans for sc300?
  209. 2000 SC300 with 2jzge vvti Timing belt and water pump?
  210. Diff Swap
  211. Alright guys why is it so hard to get a manual swap?
  212. GTE Head swap on GE Bottom or Just go 2jzge NA-T
  213. S2000 AP1 6-speed conversion?
  214. AC unit NEED HELP
  215. Help!!!! Grounds 2jzge
  216. Sc400 w58 Swap
  217. Urgent
  218. SC400 Air Suspension Creaks?
  219. Fuel Rail Question
  220. Wastegate question...tial or precision?
  221. fuel guage does not work
  222. Major mistake during the swap , don't make the same mistake I did !
  223. Vacuum Hose Placement
  224. 92 SC400 200k CEL Code 052
  225. leaking tranny fluid
  226. Slow cranking
  227. SC300 Burning to much gas
  228. Fujitsubo Exhaust Clip
  229. is300 valve covers on sc300?
  230. Fender exit downpipe
  231. Injen intake on a 97 SC300
  232. Bleeding new clutch mc? Special procedure?
  233. This is all I really need to do the gte wiring merge correct?
  234. Widow question!!!
  235. Coolant loss
  236. Exhaust resonator questions
  237. Going rich but only at 2K? SC4
  238. Alternator..rebuild, replace, upgrade?
  239. harmonic balancer help
  240. Fuel pump not working
  241. SC 12V fuel pump mod- 1JZ
  242. Throttle Body Issues?
  243. Where to buy Motor Mounts
  244. Lots of oil from pcv
  245. Where do i find a 1/8th BSPT to -3 AN fitting?
  246. 1JZ Alternator will not carge battery
  247. HKS FCD explination?
  248. Ac light flashes on sc400 with 2jzgte swap
  249. bad starter... how to get car started
  250. 92 sc400 transmission type A340 or A341?
