That tricky C/OPN Relay
Old Oct 4, 2020 | 08:00 PM
Lexus4321's Avatar
Lexus4321
Default That tricky C/OPN Relay
Ah, finally found the description of how it works.
Here's a PDF of it.
https://f01.justanswer.com/El_Jared/...mp+circuit.pdf
Old Oct 5, 2020 | 05:08 PM
chiph9's Avatar
chiph9
EF-1 fuse would be where I start.
Chip H.
Old Oct 5, 2020 | 06:03 PM
Lexus4321's Avatar
Lexus4321
I did take spare fuse and did the swap this swap that attempt, All the fuses check out ok. The relays work w/ the ECM as described by the tech docs. Wild goose chase in this area.
If the crank or cam sensor went south the ECM should have logged a DTC.
My only concern now is, if the fuel pump is bad then why no DTC for low pressure? Does the ECM only check that when engine is running?
Old Oct 6, 2020 | 03:38 PM
chiph9's Avatar
chiph9
It's only half-bad.
Chip H.
tp4by3
25
Oct 9, 2020 02:10 PM
mtparker18
Jul 8, 2012 03:54 PM
Lexwang07
Aug 25, 2007 04:35 PM
scawacs
Aug 19, 2007 07:27 PM
nyARISTO
Northeast
Aug 28, 2005 01:05 PM
