View Full Version : Suspension and Brakes
Pages :
8]
13
14
15
16
17
18
19
20
- 20's on eibach pro kit
- F-Sport rear sway bar part number question
- which sway bar brand? so many options
- where can i get front camber plates for 2is !???
- 225/45/18
- how long do F-Sport shocks last?
- ISCjonny finally got BBK...
- Two F-Sport BBK Questions in one post
- Replacement brake squeak
- Tighter Suspension
- looking to install air suspension in my 06 IS250 , any advice !??
- 2012 F-Sport Suspension Question
- brake and rotors question
- H&R Springs and my 350
- Got F-sport sway bar install in shop, torque not correct
- Tanabe coil on uas aero bag
- Coilovers for 2is AWD need help!
- DIY on UAS *The struts and mounting
- help
- rear camber kit question
- Rear brake pins completely LOOSE!!!
- Coils, Wheels, And Rotor's Suggestions?
- pillars are ceased?
- Great setup!
- Woot! New rotors/pads..
- F-sport Shocks
- Need help Adjust bc coilover
- Need advice with lowering is350 on 20's
- Can I use F-sport shocks with regular springs?
- Springs "Settling"
- what coiloverss??
- Upgrade front brake.
- Brake rotor and pad
- Getting Springs Y/N?
- Megan Coilovers with Tein silencer advice w/ pics
- Creaking F Sport Brakes
- BC racing with Swift springs owners, what is your damping setup?
- is250 i lowered it an cel an vsc on help
- StopTech Brake Pads?
- Best shocks for road magnets?
- Any one with Megan ez coilovers on AWD's??
- Lowest Coilovers?
- IS 300squealing brakes
- Ceramic Brakes
- F-sport lowering springs?
- Drop for springs
- Anyone ever have a caliper bolt fall out?
- Buying Stock Sport (not F-Sport) Springs
- Steering Damper Installed: DIY tips and review
- Megan LP Coilovers CLUNKING ISSUES
- Need some advise on OEM struts v.s Aftermarket.
- Groaning, Creaking brake noises after replacement on 2007 !S 250
- Difference between camber arms?
- Camber kit arrived today, it's HUGE compared to what I was expecting
- aftermarket struts/handling. A LOT of questions
- air ride what else do i need??? help!?!
- Another brake noise thread?
- How to stiff my Tein CST
- Any recommendations on brake pads with low dust for is350
- Desperately NEED YOUR HELP
- Searching for parts on the hotchkis website and found
- Akebono ACT908 brakes pads do not fit IS 250
- MEGAN EZ COil Overs on the way... QUESTIONS..??
- Best Coils for $1K?
- F-sport susp. vs F-sport sways on base susp.
- Best Camber Kit
- Ride Quality with Lowering Springs
- camber kit for 06 lexus is350
- IS350 Brake and rotors replacement
- The difference between the 250 and 350?
- H&R or Road Magnet springs?
- Can't decide between H&R Springs and MEgan EZ coils!
- lowering probelm
- Squeaky Suspension Question.....
- alcon rotor selection assistance
- Wheel spacers: safe or dangerous?
- Question for IS350 owners with an aftermarket rear sway bar
- Best way to lower my is250?????
- H&R Sport Springs
- What's a good brake pads
- Need a quick confirmation about SPC ball joint installation
- BBKs from other cars made to fit IS350?
- IS350 brakes on IS250
- F sport suspension with sports package
- abs help on is350,
- Yet another new BC owner with clunking
- How much do stock 2012 fsport wheels weigh?
- Coilovers...Spacers...Drivability
- Front lower ball joint replacement
- New to the forum. Comfort sport TEin
- IS350 Fsport brake on IS250awd
- Will 07 tein SS coilover fit 09 isx50???
- 08 IS F oem coilovers?
- adjusting stiffness on coilovers
- Modifying Car while taking health into consideration. suggestions?
- Camber Kit Info Needed.
- Road magnet springs
- IS350 leans to the left
- What spring rate do I need (BCR)??
- cup kits
- For those who installed fsport shocks after springs...
- 2007 IS 250 RWD - Locate front strut replacement part
- H&R Springs Wheel Gap Issue?
- FS and WTB posts go in the classified forums only
- BC owners, what dampening setting are you using?
- How to fix brake dust on IS 250?
- Ball joints and camber kit
- Coilover setup question to achieve my goals
- Tokico HP Blue or F-Sport bilstein?
- Vibration after H&r / f sport install. Help please
- Rear calipers painted & vinyl lettering applied...check!
- Can somebody guess what lowering springs this is has
- Front left suspension clunk on 2011 stock set up
- Bbk owners I have a question??
- Where to get f-sport springs
- Bbk opinings
- oem replacement pads and roters
- Lowering springs
- Average cost to install springs/shocks combo?
- Wheel Clearance for IS250 brakes vs IS350 brakes
- Help! Destroyed tires - IS250 AWD on F-Sport Combo
- F-Sport Rear Chassis Member Brace
- Rebuilding of Megan LP coilovers?
- need some help with f-sport springs on '11 IS250 AWD
- Tein S tech ride height????
- BCR with Swift Springs
- Looking to lower car
- Fsport spring question.
- Need some feed back on coils
- OEM Undercarriage Brace?
- Sewell Front Fitting Kit and Front Shim Kit
- 2006 is250 struts
- BC vs Megan lp spring rate
- Need help with springs!!
- 2007 IS350 Sport... Lux + Mods? helppp
- How to install springs and shocks?
- Need help between Tein s and H&R Springs!!
- Camber Needed
- non OEM rotors
- Suspension/Undercarriage Noise
- HELP! Brembo rotors & OEM lexus pads installed. SO NOISY!!
- Front End Rattle
- ceramic pads on a 08 IS250 ?
- Need advice on Ceramic Brakes
- ISx50 Lowered on H&R Sport Springs
- Rear upper or lower control arm?
- H&R Springs + 20's = Rub?
- H&R with F-Sport shocks on 2006 IS 250 AWD
- clunking noise on megan coilovers
- Rattle Noise
- Almost got it for the Rear Sway - Advice Please
- Failed Rear Sway Install. Help! please
- H&R with stock shocks. Ride Quality?
- any other coilovers available for 2IS other than Megan, BC and KW?
- coilovers vs shocks/springs - which is more reliable?
- F Sport Springs
- Original Brakes Lasted How Long?
- How much of a drop from stock height until I scrape?
- Tein S tech owners???
- "chatter" from rear susp after lowering springs
- Need DIY for changeing coilover on is250awd...
- H&R springs + Chamber Kit?
- DIY for changing spring on IS250 AWD
- F-Sport rear sway question?
- Used good coils or new megan ez?
- Rear Calipers
- What brand are OEM brakes?
- Aligment issue, cant seem to find the problem.
- BC racing coilover very bouncy or jumpy?
- Hawk brake pad vs oem
- suspenion problem
- bc racing adjustment
- Opinion on Centric Rotors and Akebono pads
- brake pads too big?
- Need help from the Brake Pro's!
- Question about brake dust TSB
- *Pic Request* AWD with h&r and oem 18" spacers
- Help with endlinks
- Rear Brakes Seized
- No More 4x4
- Squeaking / Creaking coming from BC Coilovers
- Help on brake pads?
- Coilover confusion :/ plse help
- Bay Area alignment
- Time for new rotors?
- Lowenhart LT5 Wheels
- What is stock ride height?
- New H&Rs on my AWD
- springs w stock struts?
- BC racing rear clunking noise
- Just installed F-Sport springs on 19" Got a question though.
- looking for best no vibration lowering setup for awd
- What are some options for stainless steel brake lines...?
- H&R or Eibach Pro Kit
- For those riding low!
- Squeaking brakes when cold?
- Cheapest Place to purchase H&R springs?
- is350 suspension change
- Pedal play?!
- Anyone with Ceramic Hawk Brake Pads?
- 2006 250 SGM dropped on H&R
- F sport bushings
- Advice lowering springs vs. Coilover
- I think I am going to buy the sport package springs...need help!
- F-Sport BBK owers, share your thoughts
- Starting spring install tomorrow
- can I just buy the f-sport front calibers, not the entire BBK?
- Öhlins Road & Track
- F-Sport front sway bar, worth installing over stock , IS350?
- Lowest dust pads available?
- 2010 IS 250 AWD CLUNK noise
- CXRACING Coilovers?
- brake help and ?
- Lower Control Arm Bushing. Which offset?
- my is first upgrade h&r springs
- IS350 FSport Height Question
- SPC ball joints clunking!
- Rotor Replacment, Aftermarket the same?
- looking for camber kit
- Low Dust Pads TSB under Extended waranty?
- any reason for me to switch from f-sport setup to Megan EZ coilover?
- F-sport rear sway bar install
- Front upper control arm
- Did you reset your bushings after you lowered your car?
- Megan EZ Street
- Need new rotors
- Why are TANABE AWD Springs .4 shorter in rear?
- day ruined by messed up parts
- Did brake flush and still spongy.
- Front Camber Kit for 2IS Finally Released?
- Anyone running the SPC front camber kit?
- 09 Sport Package Shocks w/Revised F-Sport Springs
- Spongy brake help!
- F-sport shock collet ( spacer ) ?
- H&R w/ 17s
- Road Magnet spring
- What color should i paint my calipers?
- Opinions on Tein SS Coils?
- Need help with brakes on 250awd
- ISF Springs/shocks on IS350
- brake calibers
- LCA bolt
- AWD IS250 Front Brake Conversion to IS350 Help
- Need Help Verifying BC BR Coils Spring Rate
- Shipped wrong spring rate on BCR Coils?
- A question about stock 17" rims compatibility with akata spacers..
- Question about Brake Fluid Change - safe to drive?
- 19's Lowered on F-Sport Springs
- Wheel gap problem I can't figure out
- Anyone done this brake TSB yet?
