Replacement brake squeak
Old Oct 16, 2012 | 02:57 PM
DaMitsuMan's Avatar
DaMitsuMan
Default Replacement brake squeak
I have an IS250 and I recently switched my front brakes with new rotors and lifetime ceramic pads from the local shop. They have had to replace the pads 4 times in the past two weeks because they do not stop squeaking. Anyone have any ideas? They were Bosch pads the last three times. I can't remember what they were the first time. Or am I stuck getting the Lexus OEM pads for double the price with no warranty?? Thanks.
Old Oct 16, 2012 | 03:53 PM
Denver's Avatar
Denver
OEM is the way to go and bosch is garbage
Old Oct 16, 2012 | 04:39 PM
Gville350's Avatar
Gville350
Lifetime pads are just about the worst pads you can get!
Old Oct 16, 2012 | 05:50 PM
sw2oboi's Avatar
sw2oboi
try giving it more time to break in, maybe 500 miles? if they dont go away it may be the pads. i personally use oem dustless and EBC Redstuff from england.
Old Oct 16, 2012 | 06:25 PM
CLIS250's Avatar
CLIS250
I have had issues with squeaking with OEM pads and brakes. Just decided to go with a whole aftermarket rotor setup and ceramic pads.
Old Oct 16, 2012 | 10:09 PM
whitebeast's Avatar
whitebeast
Did they re surface the rotor? Most of the time it solves squeaking problem due to an event surface,
Old Oct 16, 2012 | 11:37 PM
rookieIS's Avatar
rookieIS
i have Duralast life-time warranty pads (non-ceramic) on my IS250 brakes and no squeaks at all. i also resurfaced my OEM rotors when i changed the pads.
Ab423
Dec 12, 2015 11:50 PM
Bigrahizzl
Suspension and Brakes
Aug 26, 2010 04:11 AM
tgcLS430
Maintenance
Feb 1, 2010 06:35 PM
cpr greg
Dec 2, 2009 09:48 AM
ToothDoc
IS F (2008-2014)
Sep 19, 2009 10:27 PM
