- 05 timing belt & peeling wheel question
- Anybody running Nokian Rockproof tires?
- URGENT...Safe to drive on a blown airbag???
- Steering Rack Leak?
- Gx470 rear wiper not touching top of window
- air injection bypass
- Bilstein front strut install
- Remove lower driver's side outside door panel
- Wondering about price
- Tow Package on GX 470
- Buying 2006 with 200K miles
- New Radio Help
- She cleans up well.
- 08 GX470 Door Stuck Closed
- Goodbye my friend
- Car shakes/vibrates hard
- How to remove driver side lower dash panel?
- Windshield defrost/hot air vent not working (GX470 2006)
- Coil over suspension installed- now tires rub on skid plate?
- Elecrtronic problems
- Father Son GX Build
- Suspension Questions
- Gx470 Height Control and 2nd start
- 05 gx can you adjust headlights left and right?
- Wheel replacement update!
- Timing belt DIY RX300 compared to GX470
- Air Suspension Relay
- Cat back exhaust recommendations
- Move from 2014 RX 350 to much older GX (or LX)?
- Hot cupholder on drivers side - 2003 GX470
- gone too soon...
- 2003 GX Back up camera images fed to NAV screen?
- Is it worth it?
- Lexus Dual A/C Improvement/TSB
- Lexus Gx Grom Audio Installation Help
- Newbie Here. Purchasing soon. How do I tell if KDSS is on it.
- Rear lower shock bolt snapped off! Help with part # pelase!
- Navigation DVD
- Rear air ride not always working
- Vehicle power from drivers seat
- Timing belt Service Video(Not mine)
- bad airbags & struts - options?
- Secondary air pump failure P2240 and P1441 - help pls
- can anyone identify this plastic part?
- 210k Transmission Fluid Change?
- Cv axle Reboot
- Speedometer Off
- Clear oil leak passenger side
- High Mileage GX470 Questions.
- Will a 135 mm bolt pattern fit on my 139.7 mm bolt pattern?
- Rear cargo door switch
- OMG. Broken wheel hub bolt on a road trip. Any comments, please?
- 35" tires
- Rear Suspension Spacer Question
- Gx470 roof rail cover replacment
- New (for me) 2003GX
- Need help regarding OBD2 - communication unavailable
- How much rust is too much / unsafe?
- And another one gone, and another one gone, another sub bites the dust
- 2006 GX470 accelerates when stopped
- Wheels
- MAF and Codes P0101, P0172 and P0175
- all new suspension (Arnot Springs and shocks)
- Rear air springs - OEM vs aftermarket
- Air line Part number
- Ignition switch squeals when starting on a 2009 GX470
- Letter from Lexus Re: Paint Peeling on Vehicles with Blizzard Pearl Paint
- Will these fit my ‘05 Sport?
- 2006 gx470 not starting.. cranks but doesn’t stay on
- 2006 GX470, no hitch, truck rack Saris Bones EX 3
- Passenger side low beam not working...
- GX470 rear seat cup holder fixed
- Lift Kit for pavement pounders and occasional towing
- Gx470 Reliability
- Loud clicking from the wheels when driving slowly
- Drivers door problem
- Navigation Headunit compatibility between model years
- Bilstein 5100 front shock settings
- Price check 2006 GX 470
- Weird noise coming from behind the dash/center area.
- CV axle seal installation depth
- Rear Entertainment System
- Brakes
- Ride height sensor?
- Bypass Rear Level Switches/use Switch for Comp
- Removing battery 2008 gx470
- Fan stuck?
- Navigation CD
- G (Up&Down) Sensor
- Frame rust remediation shop in NYC ?
- Noise(not loud) but concerning.
- Passenger Side Front Speakers Aren't Working?
- Frame rust
- Car got raised on the left
- check your surroundings message
- 2009 Satellite OEM Installation
- Steering wheel shake/vibrate. Please, help!
- 2006 GX470 Steering(?) Issue
- Replaced my CV axle shafts-
- WTB Timing belt kit
- Had brake pads and front calipers replaced, now..
- Owner's manual
- exhaustion heated up in less then 5 mins
- 750lbs tongue weight, safe? need some opinions
- Thank you , Tesla !
- Too good MPG
- Changing brakes
- Coolant Leak from around a bolt under engine on a 470
- Changing brake rotors.
- Sharp buzzing behind dashboard and intermittent AC
- Rack and Pinion Replacement In Dallas Recommendation
- 05' gx auto/up down driver window
- AHC (Rear Suspension) Stuck on N?
- 2008 GX470 Bilstein 5100 Rear Shock Install
- just purchased 03' gx470 307k mi
- Gx470 ignition coil seal.
- Don’t buy these front blinkers!!!!
- GX470- Defective Rear Suspension Airbags- SOLUTION
- 2008 rear suspension (Arnott?)
- PO300 code
- 2003 gx towing
- Glove box light
- Any market for OEM Lexus wheels?
- Catalytic Converters
- New spark plugs
- Tranny drain tildes 3.5 quarts. Is that ok?
- Premium Tire offerings....
- Trying to decide which 200K miles GX470 is right for me
- DIY Lower control arm removal and Whiteline bushing install (4 part video)
- Why Lexus GXs Are Becoming Big in the Off-Road Community
- Another air bag failure
- KDSS shutter valve
- Recording of Car Noise.. What is this?
- Rear ABS sensors have wear marks?? Bad bearings?
- Replaced 15 year old rear shocks
- OBDII Scanner No Link to ECU
- 2004 GX Found this part. No clue where it goes
- '05 100k mile maint
- Should I sell old and buy new
- Need a gold front bumper(stock)
- 2006 GX 470 Evaporator
- 2003-2005 Diff Support
- Best option for replacement rims - 2007
- Door panel removal video how to. 6x9 speaker install pics.
- Driveshaft CLUNK 07
- DIY glove box removal video and AC blend door (mode) motor replacement
- side view mirrors...now out of the blue
- 2006 in Ash Blue Mica over Gray
- Door ajar light stuck on.
- Gx470 2005 won't start
- Rebuild bs replace...(calipers)
- Headlight lenses for GX470 - where to buy?
- Engine coolant leak
- GX loses power at Moab
- Driver Seat Belt Light / Sensor
- Looking for GX470 Transmission Temp PID's for ODBII Scanners
- Rear Coils to Replace Air Bags???
- Grill Question...
- GX Review
- After bleeding caliper- ALL wheels locked up!
- Engine try to stall when sudden Brake applied and accelerated.
- 2006 GX470 With No Sound on Radio
- New GX owner!
- Phoenix Android installed!
- Rear Air bag Assembly... Please, help!
- Mystery issue with door locking/unlocking
- Installed LED bulbs with built-in load resistors...im still getting hyperflash
- Help me identify this rubber plug
- had the OEM shocks installed
- Replacing rear AC lines
- AC colder on passanger side
- Long distance tow !
- 2004 GX470 Front Strut Stuck!
- Issues with AC
- Weird Low Idle
- Need help changing lighter
- B series Code??? (B1252)
- Trailer light pin does not work
- My contribution to the main pulley/harmonic balancer nut removal
- [Solved] Buzzing HVAC mode servo in dash by glovebox
- Bought a GX470 and broke it - Help! Traction Control light and No Acceleration!
- Installed WeatherTech visors & AFE intake...
- Manual Foot Air Pump for tires.
- e.bay rear shocks bought for $210ea.
- Rear spring question
- Anyone use a Toyota Keymaker Tool to make spares?
- Wheel spacers 20mm pic
- Struggling to find some part numbers
- Fogs Fogs Fogs
- Stock front strut replacement question
- Can you jump from nav version 3.1 to current?
- 2004 GX470 parking brake question
- interchangeable parts GX470
- 2007 Gx Dash Crack Repair
- P0430 Bank 2
- Maybe the Drivers door lock actuator??
- New GX Owner
- Finally... 12v usb Qualcomm quick Charger/ always on!
- New GX470 Owner!
- Tachometer RPM not working- '04 GX
- 04 GX470 a/c passenger side only
- Brake Calipers advise, please.
- Around how many miles is the GX470 good for?
- Rear shocks
- Anyone use an aftermarket intake system?
- Noise when I stop on an incline and then give it gas
- New Proud Lexus owner
- Gx470 shift linkage connection issues
- TPMS won’t reset
- Towing travel trailer with 2005 GX470
- Shops in or around Chicago
- 2004 Gx470 Ac not working ! At all !!!
- 07 gx470 grill modifications?
- 06 GX470 with the stereo issue
- 04 GX470 New Owner - Audio upgrade questions
- Replacing AC lines
- Projector Retrofit!
- GX470 ac line replacement
- Squeaking Noise Below drivers seat
- Installed hidden winch, Finally!
- VSC Trac Off + 12 Codes
- AC Leak Somewhere
- Problems in the HOOD!!!
- My Plan.
- Removal of shift knob
- Any solid axle swap GX470 on here?
- Motorfansclub side window seals - review
- Axle boot kit and front wheel bearing with hub assembly. Please, help!!!
- Newly bought 2008! Joined the club
- 2004 GX470 Rotors.
- Valve cover gasket sweat/leak
- 06 acceleration problems
- weird noise only on turning ???
- New owner of 2004 GX470. Please, help the newbie!
- New Owner of GX470
- Help: "A Program Cannot Be Read.."
- Exhaust work question
- Confused about front suspension choices
- Lexus / Toyota Parts
- Volt/Watt/Ammeter in Center Console (for dual battery rig)
- LC2i and ML system/ adding an amplified sub.
- Thinking of buying a Gx470
- 05 GX is on the way. Want to do lift, rims and tires before Memorial Day
- GX 470 / Timing Belt Kit?
- front spacer lift - warning
- Cancel a route on navigation system - 2007 GX
- 05 GX w/ 75K Miles
- In need of rear factory shocks.
- F sport wheels on a 04 gx470. Will they fit.
