Stock front strut replacement question
Old Jun 20, 2019 | 10:50 AM
Ruppy's Avatar
Ruppy
Default Stock front strut replacement question
I need to change the front shocks on my 2004 GX470 with the kinetic suspension. If I am replacing just the shock are there any other parts to buy? Is this a crazy hard job??
Old Jun 21, 2019 | 06:48 AM
captainva's Avatar
captainva
Strut mounts for sure if you aren't buying them preassembled. Also get new rubber spring isolators. I didn't when I did suspension on my CR-V before I sold it and it started rattling after only a few thousand miles. To replace the isolators after the fact means redoing the entire job. Double check your front upper and lower ball joints as well for play and do those when you do the suspension
Old Oct 25, 2019 | 07:05 AM
tonyka's Avatar
tonyka
Default Rear
Same question, but for the rear. Any suggestions on additional parts to buy/replace? Planning going with the OEM shocks to keep the comfort/sport setting.
As for the front, do we need new coilovers? Or just reuse the existing coilover?
Old Oct 25, 2019 | 08:42 AM
IanB2's Avatar
IanB2
If things get rusty where you live/drive, swaybar endlinks often need to be cut off and would require replacement. Not sure how that works on a KDSS truck though.
TakaM
Suspension and Brakes
Mar 4, 2019 11:40 AM
olemanGS
Mar 14, 2010 06:22 PM
jcat_350
Oct 28, 2008 10:52 AM
e-man
Feb 6, 2006 09:25 PM
