View Poll Results: Engine Stalls when Sudden Braking
2009
0%
gx470
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Engine try to stall when sudden Brake applied and accelerated.
Old Jul 13, 2019 | 11:28 PM
Randy777's Avatar
Randy777
Question Engine try to stall when sudden Brake applied and accelerated.
2009 Lexus GX470 - 1,05000 miles - Engine try to stall when sudden Braking applied, and as soon as the engine is accelerated I feel a Big Knock, it doesn't happen on a normal Braking situation, only on the freeway,. serviced transmission system No help.
problem started around 70,000 miles, now it is getting worse. dealer was unable to duplicate the problem.
Old Jul 14, 2019 | 10:16 AM
chiph9's Avatar
chiph9
Unlikely that it's the brake booster - it's electrically driven not a vacuum assist. So it should have negligible affect on the engine.
I would look at things like a stuck caliper, bad ABS sensor, bad ABS valve or pump.
Chip H.
Old Jul 15, 2019 | 05:39 AM
MrJason's Avatar
MrJason
Like what was said.. this vehicle doesn’t use a traditional vacuum booster... so you would get a massive vacuum loss on heavy stops.
Id lean more towards motor mounts causing a larger vacuum line to separate when you brake or accelerate abruptly.. due to the engine tilting forward or backwards.
This is easy to test... just pop the hood and let someone look at how far the engine tilts when you power brake in drive or reverse.. just be sure to do this in a safe open area, with the person watching standing next to the engine bay and not in front of it.
Old Jul 15, 2019 | 03:10 PM
chiph9's Avatar
chiph9
Motor mounts - good idea.
Chip H.
lymlyt
Dec 15, 2016 06:04 PM
Mehul1456
NX - 1st Gen (2015-2021)
19
Jun 25, 2016 02:59 PM
tom07es350
Dec 9, 2010 08:33 AM
niteflite
Oct 13, 2010 03:53 AM
elmagnus
Hybrid Technology
18
Mar 24, 2007 06:19 PM
