Brakes
Old Aug 28, 2019 | 03:23 AM
Tflwolf3's Avatar
Tflwolf3
Default Brakes
I have an 04 in silver. (After wrecking a gold 03 model. Took a deer on a 2 lane blacktop.) Looking for a kit, if one exists, to use the front 4 piston calipers out back. Already found a nice looking 6 piston upgrade, with a 345mm rotor, for the front, so I wouldn't have to buy the oem calipers seperately.
Old Aug 28, 2019 | 03:25 AM
Tflwolf3's Avatar
Tflwolf3
Default Brakes, 2.0
To clarify, I want the brackets to adapt the rear axle to use the front calipers also.
Old Aug 29, 2019 | 05:56 PM
MrJason's Avatar
MrJason
You are looking at a big job their... with custom fabrication work.... I’m not even sure the fluid reservoir will hold the amount of brake fluid needed for 6 piston fronts and 4 piston rear fixed calipers.
Anything is possible. But this job just seems like it’s way more work than it’s worth. Just my opinion though.
Old Aug 29, 2019 | 06:01 PM
Rygar470's Avatar
Rygar470
Wouldn't the 150's brakes (F/R) be a decent upgrade without going above and beyond what you want to accomplish? Especially because you will always use 80% or so of the Front brakes, in any given situation. Because laws of Physics.
Old Aug 31, 2019 | 04:50 AM
chiph9's Avatar
chiph9
This will change the front/rear braking bias. You really don't want the rears having more braking force than the front (ask any motorcyclist)
Chip H.
Old Aug 31, 2019 | 06:06 PM
agent15's Avatar
agent15
...or racecar driver.
Old Aug 31, 2019 | 06:29 PM
Rygar470's Avatar
Rygar470
Yeah, at that point, no awd/4wd will save you.
Old Aug 31, 2019 | 06:40 PM
MrJason's Avatar
MrJason
Chip H.
Exactly... this could actually cause a safety issue.
05LSV
Suspension and Brakes
Nov 14, 2007 09:51 PM
rtk7
Nov 14, 2007 04:52 PM
GSing430
Aug 17, 2007 01:52 PM
HKGS300
Nov 24, 2003 01:00 AM
