View Full Version : Suspension and Brakes
Pages :
13]
14
15
16
17
18
19
20
- Dealership Dustless Brake Pad TSIB
- Megan AWD coilover
- Brakes click when changing direction
- Preload adjusting question
- H&R or Roadmagnets?
- coilover help
- Anyone on ISF springs with 18" wheels?
- which brake rotors to get??
- resurface oem rotors
- Stock Shock ?
- 2010 IS250 Brake Dust
- changing brake pads...
- ABS off blinking after installing F-Sport Rear sway bar and F-Sport Lowering springs.
- Adjustable sway links. Only from think design?
- Are BC coilovers shorter than stock?
- F-sport sway bar: does it matter if it's up-side-down?
- Need help with rear brakes...
- Brakes squeal with 1-2 people riding but, not 3?
- Bang for Buck coilovers
- Help - Anyone got is350 calipers laying around?
- Caster problem?
- Front Height Sensor Link
- Installed BCR coilover!
- pics of car with fsport springs
- camber is not adjustable?
- Megan Coilover Replacement Shocks?
- Need New Brake Pad / Rotors
- brake pad advice needed????
- brake Pads online...
- Upper Strut braces,Lower braces,Chassis brace,Tunnel/Member braces
- They told me no camber?
- Air Suspension questions...
- Camber kits?
- Spring install PDF?
- What's wrong with my brakes?
- LMS rear strut bar
- What am I doing!?
- Difference between sport package springs and F-sport springs
- Looking to lower my 250...help!!!
- Bc coil over question
- shock/strut....
- Get Your F-Sport Springs Now!
- F Sport brake maintenance cost?
- Painting Stock Calipers need advice
- Drilled Rotors need advice
- AWD on H&R awd springs and F-sport awd shocks?
- need advice
- BC D1 Coilovers... $231??? lol whut?
- Two straight sets of front tires destroyed by negative camber
- Brake Dust on 2006 IS250 AWD
- Platinum VIP Coilovers
- i need help deciding on coilovers :)
- Any AWD owners with Megan Racing Coilovers?
- Pics of your cars lowered on springs
- Input Please
- Help with lowering springs!!!
- lowering spring question
- LS400 springs on Sc300
- IS350 Coilover help!
- BC Racing Coils
- Need new Brake Pads!
- Tanabe DF210 GS350 Springs on IS250 AWD??
- Switching from H&R to Eibach's
- Warranty Coverage? (Brake fluid)
- Need help confirming P/Ns for F-sport Shock Absorbers for 07 IS350
- Would the F rear sway bar (PTR02-53080) work with a RWD IS350?
- Lifespan of Zeal Coilovers
- Just a few upgrades
- Went from coilovers to stock setup... Questions please
- Need Your Input...Springs/Shocks or Coilovers
- Are these the oem front and rear brakes?
- what is the is350's brake fluid capacity?
- Question about IS300 Brake Pad.
- BC Racing Coil Noises
- Need help please... Front strut won't come out
- Hotchkis Lexus IS 250/350 Sport Coil Springs pic request
- Tein S-Tech's ?
- size of the spring silencers?
- settled f-sport pic request
- How much can you drop on coils before scraping?
- Help me choose the springs. (Tein S. Tech or H&R?)
- Help! Coilover adjustment!
- Which coilovers are the best.
- BC Racing Vs. Megan Coilovers
- Reseting bushing after coilover install?
- Tanabe DF210 or NF210 - need up to date figures
- shocks?
- Powdercoating Brake calipers
- Rotor Replacement
- BC Racing Coils
- Coilover Question
- Sports pkg Shocks vs F-sport shocks?
- How big can IS350 rotors be?
- Eibach Springs
- How much do you pay for Tein CS coilover?
- Do I need the shim kit for brake pad replacement?
- Those with Tein SS help!!!
- Where to install Coilovers??
- Camber kits?
- Spring Question
- Help! What do I do now? (aftermarket pads & rotors)
- 09 is250 needs new brake pads
- Coilover Help!
- So i installed BC Coilovers lastnight!!
- ?Install fsport springs at dealership or at a rim shop?
- BC Racing Coilovers Pillow Mounts or Rubber Mounts??
- 06 IS250 needs rear brakes - Advance Auto has spend $100 get $50
- Finally installed my IS350 brakes.
- Those who installed BC Coilovers
- Eibach pro kit questions
- Squeaky brakes when the car is not warmed up
- IS250 Mounts
- Advice pls....
- IS350 - brakes, help!
- Does the rear shocks take a while to settle back in?
- Fsport rear sway bar doesnt fit 2010 model???
- is250 Rotors serviceable?
- BC Coilovers
- Brake Rotors
- ??? F-Sport Lowering Spring Effects ????
- Idle Vibration with BC Coils on AWD ?
- I need a feedback on Tein CS.
- F-Sport Springs and Bilstein Shock Absorbers
- PIC REQUEST: IS250 AWD w/ BC Coilovers on Lowest setting.
- how do you adjust coils?
- TSIB for front brake squeak?
- Tein SS vs CS
- What would I gain/lose from changing to f-sport/bilstein from megans?
- IS250 AWD - After lowering springs
- Duralast rotors for the IS250
- Custom BCR Spring Rates
- Tein S. Tech vs H&R springs.
- Removing Front Fender Lining
- Coilovers + winter = BAD?
- Help - Horrible Grinding Noise whenever I brake!
- Getting Brake Fade (AWD '08)
- Need Advice for Coilovers on AWD
- Springs, No More Saggy Butt!!!!
- anyone have megan coilover on IS350?
- Should I wait to install coils and rims at the same time?
- 50k km, replace front disc already?
- Oil (edit: brake dust) on wheels. Normal??
- Brake problem on my IS
- IS350 front sway to IS250
- '07 350 sway bar to fit '10 250?
- Got the F-Sport Spring TSIB Done - Pics Before and After
- 2007 IS250 Brakes
- Best bang for the buck coils for is250
- F-Sport to Tein S-Techs...
- SPC Front camber + Megan rear suspension rods install photos + results
- brakes always on?
- Coilovers or Tein S-Techs ??
- Clicking noise when braking, in reverse, and in drive
- Lowered My IS350 on H&Rs.
- I need new endlinks......sigh.
- Adjust Megan Coilover Damper Stiffness
- What springs to get??
- Do the rear brakes pads have an audible wear indicator?
- Driving your IS lowered During Winter
- New SPC/Eibach 2IS Front Camber Kit???
- Need Advice on Brake Pads
- F springs discontinued?
- Swap OEM Luxury Springs for Sport Springs?
- Question On Lowering My IS350
- Going Lower with F-Sport?
- Are coilovers worth it for a DD?
- Is anything else needed when changing brake pads
- Seriously, the brake dust is ridiculous.
- Do you have to roll fenders with Tein S techs?
- Can IS350 Rear Caliper be install on IS250 and direct bolt on?
- Lowering an IS250 AWD with springs, not coilovers
- BC Racing coilovers; pics/question
- lowering question
- brake advice.. Please help!!!
- GT Spec upper strut installed and then bolted down NICE!!!!
- How to be low?
- Torque VALUE HELP!!
- Any Special Tools needed for Spring Install?
- Need some help with Tein S-Techs
- Looking for this 2IS Ultra Racing front brace
- stoptech bbk for 350 on 250
- Removing Pistons from IS350 Calipers
- How does my alignment look for IS250 AWD?
- Which Torque Wrench?
- Doing the 250 to 350 BBK Upgrade - What else do I need?
- Changing rear brake pads (seized slide pin)
- suspension- Tanabe pro five coilover
- HKS Hipermax III CLX or BC Racing Coilovers
- Is Is350 rear caliper the same as Is250 rear caliper?
- Need advice on a rubbing issue
- Pls Help! Bc racing initial setup help
- POLL: How long did your IS350 OEM brakes last?
- Cquence Brakes
- torque specifications is350???
- Tein rubber sleeves
- upgrade is250 brakes to is350
- Bleeding brakes??
- Brembo Sport Cross-Drilled Rotors
- $650 for front pads and rotors
- sway bars...
- BCracing coilovers ???
- Aristo brakes
- Anybody have these pads?
- tein s and h tech springs
- F-sport BBK
- megan coilovers, knocking sound???
- All 250 AWD owners who lowered: PLEASE help explain vibration/spring setup
- Apexi Coilovers
- Best place to get poly bushings??
- Megan coilover install
- only 10k miles on my JIC's before they stink?
- Rear Brake Pads for IS250 AWD 06
- Stainless Steel Brake Lines
- Stock vs. Sport ride height
- F-Sport front brake kit - excessive brake dust?
- L.S.D (limited slip differential)
- Alignment/camber/tire wear blah blah blah....
- Noob Questions on F-Sport Springs and Shocks
- Anyone with Buddy Club Coils have issues?
- Shocks Refillable?
- thinking about putting my ride on bags.
- $600 for install? Is that right? (F sport springs)
- Tein S-tech quality Issues vs. Eibach Pro Kits
- Brake pads for 07 IS350
- Best place to buy front rotors for my IS250?
- Tanabe Sustec Pro 5 Vs BC Racing Coilovers
- F-Sport brake pads. Where to buy?
- Air Suspension Gauges/Switches
- what brand are these spacer?
- Brake Upgrade
- Have you heard of these? (Yonaka coil overs)
- would i need a camber kit if lower on springs?!
- Front rotors gone after 2 years normal?!
- Need help with camber/toe kit
- Coilovers
- ? about size of IS350 Brakes
- Can +35MM offset fit on a IS250C?
- *Now Available* KW Variant 3 Coilover for Lexus IS250/350
- Changing Rear Brake Pads
- Brake fluid low..
- Difference between Bush Dust Boot [OEM vs non-OEM]
- F-Sport Sway Bar - Bushing Noise?
- DIY brake flush?
- Replacing brake pads for IS350 which is best and give less brake dust?
- Compact Spare Questions with F-Sport brakes
- Megan Coilovers loud?
- Help - Seized slide pin
- BC Racing Coilover Question
- Questions about spring install, please help!
- Tein cs
