IS350 - brakes, help!
Hi guys,
Newbie on the board. I apologize in advance if I am not using the correct technical terminology in describing my symptoms.
Background: 2007 IS350, 44K current miles, staggered fitment, still have the winter tires on the vehicle- they will be replaced next week with some Hankook's
I'm having problems with my brakes making a "humming / thrumming" noise when I'm braking. The steering wheel is not vibrating and I don't feel the brakes "skipping or jumping" when I apply them.
I had the front brakes replaced in Jun 09 with 34K miles (by the dealer- I know don't mention it); I'm now at 44K miles and I'm hearing this noise- almost as if the brakes were wearing out. So, perplexed that I'm hearing this noise I take off the two front tires and check out the pads- they look fine to me <attaching pictures- sorry for quality they were taken with my iPhone>.
I used some brake cleaner to clean the rotors off best I could while the tires were off- nothing jumped out at me to explain why the noise was being made.
Since the rotors were clean, I used my finger tip to feel them and see if I could detect any grooves on the meat part of them (I couldn't but I'm not an expert), but I did notice that the meat of the rotor on the driver side was lower/indented than the outer lip of the rotor. The passenger side was slightly less so. I do recall the dealer resurfacing the rotor's when they swapped out the original OEM brake pads, so that to me seems the logical explanation why.
I also tried looking at the rotors from the top and sides- I did not notice if they were warped or concave in shape. Would it be very obvious?
I also took a picture of one of the rotor's; if someone wants to see that I can post it; but again it was taken with my iPhone...
I'm hoping someone could help me out/shed some light as to why/point me in the right direction?
Thanks in advance for the help guys...
My apologies; yes I removed them to have a better look at the back part of the brake pads. I also want to point out these are the original vehicle rotors and the brake pads currently on there are the dealer recommended pads.
Sexis350
Jul 2, 2017 02:02 AM
