Brakes click when changing direction
Old Jul 12, 2010 | 04:28 PM
509IS350's Avatar
509IS350
Default Brakes click when changing direction
I got this from my.is/
http://my.is/forums/f157/brakes-clic...ection-415455/
Mine does the same thing also an 06. It just recently did it. Less than 2 months of getting it. Any would help. I think time for an upgrade. just pads and rotors for now...maybe
Old Jul 13, 2010 | 01:19 PM
Ramjet44's Avatar
Ramjet44
Default Brake click
I had this problem with my 07, IS350 last August. The dealer said it had somethingt to do with the pads sliding back and forth when the direction changed. They said there was a TSB but didn't give the number. They replaced the front pads with 04465-30400 pad kit. They also show #473301. This fixed the clicking noise and also these pads make almost no dust.
Old Jul 14, 2010 | 06:53 AM
509IS350's Avatar
509IS350
Thx I thought there was something serious wrong with my brakes or even tranny. New pads then.
Old Jul 14, 2010 | 11:32 AM
RangerJoe's Avatar
RangerJoe
I was just coming here to cross post since I hadn't gotten any results on the other board.
Old Oct 21, 2010 | 08:30 AM
RangerJoe's Avatar
RangerJoe
I just picked my car up from the dealer getting the valve spring service done, and had them check out out as well. They say there is nothing wrong with the brakes, and the noise is normal. If anything, the noise is worse now that it was before, and it drive me crazy. Any idea on how to fix it, since the dealer doesn't want to? Should I just look into get new pads or something?
Old Nov 3, 2010 | 09:19 AM
06isDriver's Avatar
06isDriver
I get a single pop noise only when going into reverse. It sounds like its coming from the rear....
Old Nov 3, 2010 | 03:46 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Mine do it all the time. It's normal.
Old Nov 3, 2010 | 05:11 PM
MIA_LEX's Avatar
MIA_LEX
Mine pops but it sounds like the transmission.. I made a thread about this months ago but no one responded. Glad to see its not in my head though..
Old Nov 3, 2010 | 10:29 PM
XhyDra's Avatar
XhyDra
It's all in the brake calipers / pads. Nothing to be alarmed about.
A good ol' rebuild and lubricating the sliding pins will fix any issues as well.
Old Apr 3, 2014 | 09:59 AM
JohnLX300's Avatar
JohnLX300
Had this same clicking from the front brakes, yesterday I re-lubed both side, glide bolts and where this brake pad mover in the caliper bracket. Smooth as butter no noise!
Old Apr 3, 2014 | 06:31 PM
Gville350's Avatar
Gville350
A new hardware kit might also help those having this problem.
Old Apr 3, 2014 | 09:46 PM
FSportIS's Avatar
FSportIS
This seems to happen right after painting the brake calipers. When I back up my car, I hear a pop sound, and when i make turn and brake at the same time, i hear the noise too. Then it disappear. It reoccurs again the next day.
I actually took my car to dealer. They said the caliper paint somehow stick to the shim or something and when the pads move, it slides and creates the noise. What they did was they sand down the paint in the inside of the brake calipers, and added some grease on the shims or something and the noise is gone. They advise not to paint the inside of the brake calipers as a prevention.
Old Feb 8, 2017 | 11:31 AM
Sconnie's Avatar
Sconnie
I want to try this... Any pictures? I think I follow your lube points, but want to double check before I mess up and get grease all over my pads...
Old Feb 21, 2017 | 08:01 PM
bazzle01's Avatar
bazzle01
Quite normal on all disk braked cars going from forward to reverse and back.
There will always be alittle bit of play on the pins. Some absorb the noise more than others.
If an inspection doesn't show anything untoward learn to live with it.
GreyGS350
Mar 29, 2023 06:04 PM
vedder
Suspension and Brakes
Apr 12, 2010 04:44 PM
Skyhigh82
RX - 1st Gen (1999-2003)
14
Jul 23, 2009 10:38 AM
Lilflip#2
37
Mar 12, 2009 02:15 PM
jimmyjazz
18
Jun 10, 2007 10:07 AM
