- Need Help to make 17s look better
- My attempt using a Canon EOS 7D
- Lowest Offset
- sound with curve
- What is it worth?
- wheel and tire question?
- New wheels on the GS
- Sway Bar Bushings Question
- Post pics of your crazy offset and what tire size streched
- subwoofer enclosure
- RIP GS - You will be missed.
- New Starter will not start??
- New to CL, need opinion on wheels...
- Having such a hard time getting wheels
- Stanced Daily Driver?
- 2002 GS 300 What is code 505?
- Aftermarket OEM style headlights - which brand?
- Turbo
- alarm and dome light wont work!
- try this with your car
- Side mounted sub enclosure in a gs
- same aftermarket front bumper?
- New Wheels, Let me know what you think
- transmission woes....
- Question about spacers
- Lexus OEM wheels that fit supra brakes?
- Club Lexus badges
- Running bright yellow fogs?----->
- Blocked Oil Control Valve = Low Brak Pedal
- Would you buy this 03 gs300?
- need some assistance w/ timing belt change....cam gears moved after belt removed
- All FS and wtb go in the classifieds
- Replaced the GS with an AUDI STASIS
- 1999 gs 400 Platinum Series in junkyard
- front suspension parts
- Rotor UPgrade?
- finally found a mechanic to install my timing belt, are these all the parts I need?
- People Revving their crappy engines at me *revised
- lowering spring compatibility info needed
- Help. HID halo projector light conversion kit.
- Pls help review my alignment...*pics inside*
- Tire Size
- tire size 30 or 35 in the rear
- Full Tank= 429+miles GS400!!!!
- New Member from Memphis TN
- where can i find some cams ?
- any info on APEXI SAFC S-AFC >??
- GS300 280HP without turbo?
- My new wheels came!
- GS300 wiring harness for new Headunit
- Just got my Onyx Black GS4! Amazing story!
- Parking (wedge) light is out....which fuse?
- Wheel Guru's! Looking for flushed fitment.
- New GS430 Owner
- Interesting conversation about brakes?
- Falken Azenis PT-722 or General GMAX AS03?
- Post pics of your custom paint job on your GS300
- Anyone have 19x9.5 +25 in their front????
- custom cluster? tired of seeing that green color
- Wheel update pics.
- Steering Wheel Upgrade
- Oem HID Bulbs Upgrade Help
- Lighting Questions and help with US part numbers
- Stuck on 2 wheels, 1 rep, 1 orig.
- 2002 Lexus GS300 20inch Wheel Question
- door not working
- How much is too much?...
- cup holder divider with rubber modifications
- Fenders
- Supra TT Wheels on...
- What should I do?
- unbelievabe will have to sell if i cant fix leak
- What paint do y'all reccommend for brakes?
- Did a Little Debadging today
- Car Vandalized
- Spring + Strut Combo
- Quick Question about the Climate Control Unit
- Power steering pump replaced twice, still having issues Help!!!
- pics of the v1 kit from enjuku racing?
- 99 GS 400+Nak -- what are my stereo options....???
- Tomorrow is the big day
- Intro thread: 98 Cinnabar/Grey
- installing spc camber bolt need help dfw texas area
- Ksport coilovers?
- Benefits of TRD Strut Brace
- Intake options?
- Dont Shoot i searched P0441 cel and other prob
- Wheel help!!!!
- Finally......new wheels
- GS300 stalls / dies after filling up with gas (CEL P0441)
- TM Engineering
- ML stereo right side louder than left???
- Anyone use the Tomei LSD in their gs300/gs400 pumpkin/diff?
- 2005 GS300 starter melted
- anyone lexus thieves?
- same wheel locks? dfw texas area i need help
- Just purchased ebay strut bar....question for those that have one
- Are HIDs too hot for high beams?
- hid
- Does CEL turn off by itslef?
- Window problem... door problem..
- Refurbished my Wald D23 Wheels.
- 2nd gen led taillights?
- Looking for VVT-I O ring
- cup holder divider installation
- How much money have you saved because of Club Lexus?
- fog lights
- New engine harness?
- XXR 521s in 20s !
- does anyone have engine mounts for sale for a 2jzge motor ...
- Finally pics of my ride
- Some iteresting lexus rides
- PLEASE HELP supra tt pads
- trunk removal off 2gs
- Look at this ish...Codes
- Bad ecu question
- Is the hard to install
- Need timing belt replaced and door lock motors, where do i go?
- Post pics of youre Imperial Jade Mica GS!
- High amp alternator
- Name that front bumper:
- Need opinions!!!
- Stainless steel oil filter
- Ac ?
- Help deciding which wheels to get
- door lock actuator brass collar
- ECU help Please
- quick brake nub question
- Rear lower brace
- GS300 Knock Sensors Locataion (p0325)
- P0441 CEL Code; won't rev past 3800-4k; VVTI not engaging
- platinum gs300 on 22s. what say u?
- New to CL. 2000 gs300 platinum edition
- Would this be feasible?
- Weapon-R Secret SRI vs K&N CAI
- Spec-D LED Foglights with Daytime Running LED Strip
- Just picked up a gs300
- So it BEGINS!
- 01 Shift Assy GS3
- 3 PIECE TRUNK WING installed ??
- Question for all the slammed/flush fitment owners...?
- how do you remove the stock rotors off the gs?
- New to the club
- Opions on these wheels
- Finally found a GS430 but it might have issues...
- Removing Rear Deck Lid to repair subwoofer
- New kid on the block
- Can't close hood on 99 GS4 -- any help?
- Lexus Pedals
- HELP installing Ashtray
- car back from body shop !
- How to preserve the black onyx paint
- FX-R Retrofit
- 1999 GS400 Nakamichi CD changer notes
- Should I give up on this projector project?
- All Locks stopped Working? 2001 GS300
- Wheel help please
- Bad smell from the air vents
- Anyone With Photochopping skills Please Help!
- does lexus have a safety issue free replacement???
- How do you clean your WORK Wheels?
- Lt.Dan! New shoes!!!
- Starting Problems Intermittant...
- Help please!.!.!.
- Advice On Wheels
- Front side markers
- biggest subs in your trunk ?
- Ame cx
- Anyone manufacture a polished 19" LM rep (like a 1.1.2)?
- Calling all wheel gurus 20x9 et25 20x11 et33 fitment??!!
- need advice
- Need Some Advise on Supra calipers
- Getting SIDEWAYS!!!!
- Gs argument ?
- front suspension noise low speed
- HID Fog lights
- Reverse light went out after changing the ride height..
- Is this a 1 stage air bag on a 01-05 airbag??
- Removing studs????
- Well hello there.........
- Help! SRT GS430 instructions needed
- LED Interior Light Problems.. Help?
- In just a couple months....
- Need help with some wiring..
- Just put 3rd gen wheels on.. not sure if I should go back to stock
- What's wrong with my OEM HID? (PICS)
- replacing the parking light bulb (194)
- Interior and Exterior Color 2GS Production
- I want to paint my calipers but PROFESSIONALLY if possible.. please need suggestions.
- Night Pics, take a peep
- Red Brembo Brake Covers
- Need help please
- how can you tell if the mileage is not correct?
- Having fun with late night session of street drifting.
- Steering Wheel question UPGRADE!!
- So Cal Westminster Lexus
- A few progress pics of round 2
- What's wrong with this
- Took off my spoiler and now my trunks pops all the way open
- Awesome GS... Anyone have more info?
- Spacers are on....
- Soon replacing differential bushings, what else to do while differential is out?
- Can someone tell me where these FIGS Rear Pinion Mount Polyurethane Bushing goes?
- Will not shift into overdrive
- 65mph+ shake fix
- Found a unicorn 400 FS!
- hid kit
- Gave her a face lift... (Plasti Dip DIY)
- WTB: Retrofitted headlights
- Gauge Cluster
- Got my knock off Tsuna today
- Lips resizing need your input
- Wheels
- Advice for chrome rims
- diff swap compatiblity
- Bringing back the ABM.. 1.1.2 and Lp's
- Third Tail Light In Spoiler Out
- great deal on poineer double din nav, but does this seem sketchy?
- boring day so i decided to burn my springs !
- Need some expert service....
- What is this connector? Can someone help? ver.trunk?
- Proper Way Of Brake Bleeding GS400
- Spray paint?Single stage paint?
- Weird issue, harmonic balancer related.
- Ball joint replacement
- 20% or 5%???
- Revisiting Something wicked this way comes 98'
- Revisiting the GREATEST marketing campaign EVER
- Window Issue...has to be an answer!
- Updated her rear end...
- what kind of mpg's/miles per tank on gs430 only?
- Unbelievable car damaged at work
- Monitor Headrests
- 2000 gs300 passenger side mirror
- New Pics!!
- Upgrading OEM HID Bulbs
- New Stance :)
- Anyone running aftermarket Engine management?
- Full coilovers!!!!
- 3 piece trunk wing ??
- Rear Diffuser
- Stant Gas Cap, Anyone Ever Try It?
- Clear VVTi GTE spark plug cover
- Plasti dippin the kazz grill
- Another random question about ashtray???
- Yellow Fog Light Overlay
- Some pics of my 2GS drifting on CV3s
- first time doing timing belt/water pump
- how do these look
- Fresh Ride
