Need Help to make 17s look better
Old Apr 1, 2012 | 01:18 AM
jessehu's Avatar
jessehu
Question Need Help to make 17s look better
hello every one, i recently bought my 1999 GS300 and put on 17 inch rims i got in past.
they are 17x7 with 235/45 tires, I'm on LIMITED BUDGET so i plan on keep these wheels for a while.
i am planing on getting Tanabe DF lowering springs, which should make this look better.
im also getting 2 25mm H&R spacers for rear wheels.
but, any other suggestions for how to make those wheels look nicer?
im not planing on getting coilovers because i still want the comfort, and i can't get airbags because the winter here will destroy them in couple years.
car in pictures is with my 17s, but not lowered and does not have spacers at back.
these wheels have same offset, but front wheels stick out a lot more then rear wheels does, that why i only got spacers for back.
any thoughts and suggestions will help!
thanks all!
Attached Thumbnails Need Help to make 17s look better-01294204-9ef2-4045-8645-0e81176fc623.png   Need Help to make 17s look better-f4c2d570-b96d-4862-9af6-66cc1db71c4e.png
Old Apr 1, 2012 | 01:42 AM
HangLoose's Avatar
HangLoose
Lower it some how, RCA's, drop, springs, or coilovers. Or have a combo? Coilovers don't necessarly mean you lose comfort. Depending on what you buy it can be better than stock.
Old Apr 1, 2012 | 02:03 AM
geeznuts's Avatar
geeznuts
Save your money for some coilovers. Most coilovers ride smooth anyways.
Old Apr 1, 2012 | 02:19 AM
istundra's Avatar
istundra
Work rezax?
Step lp it to 18"s.
But I would put some money in suspension first.
Old Apr 1, 2012 | 11:10 AM
jessehu's Avatar
jessehu
why is the spring not enough?
do i really need to go that low?
Originally Posted by istundra
Work rezax?
Step lp it to 18"s.
no, its just a konig le man style rim
I'm planning one upsizing to 18s, but thats gonna be about 6 month later.
Old Apr 1, 2012 | 11:31 AM
HangLoose's Avatar
HangLoose
Coilovers you always have the adjustablity. You don't have to think about it as "go low as it can go". Springs are a set drop. Coilovers will allow preference. The gap between the fender and the rims just looks hideous. Drop springs can do the work. But coilovers will always be the better choice.
Old Apr 1, 2012 | 11:36 AM
geeznuts's Avatar
geeznuts
[QUOTE=jessehu;7127783]why is the spring not enough?
Yes in the future you will wanna go lower. And IMO putting lowering springs on 12 yr old struts are not good. With coilovers you get new springs, struts, and top hats & 1 time labor. budget means you just gonna have to take longer to build. You save money at the end when you plan things out. Happy modding sir
Old Apr 1, 2012 | 12:52 PM
jessehu's Avatar
jessehu
[quote=geeznuts;7127843]
i searched around, and found that some coilovers make squeaking noise in cold weather, and here at where i live we have winter for 6 month.
is this true?
thanks!
Old Apr 1, 2012 | 07:59 PM
1sWt2GS's Avatar
1sWt2GS
lower them, itll make them look a lot better
Old Apr 1, 2012 | 08:42 PM
NEbiker10's Avatar
NEbiker10
Eibach sport springs and put 255's on the back
Old Apr 1, 2012 | 10:39 PM
laoboiGS3's Avatar
laoboiGS3
skip springs, go coils. youll eventually go with coils anyway, so just go with them first. i found out the hard way
try2fndmrk's Avatar
try2fndmrk
i would say step em to 18"s and drop ittt, would look reallll good
Willdb15
Apr 13, 2010 07:00 AM
baddis es
Dec 2, 2009 04:51 PM
LeXaNoMicS
Feb 18, 2009 10:57 AM
thirdmotio
40
Jun 16, 2005 05:07 PM
AlexR
GS - 1st Gen (1993-1997)
Dec 15, 2004 08:44 AM
