- weird problem
- Any professional Installers/Fabricators??
- No sound from stock Headunit
- Need shop recomendations for San Mateo / 650
- NAKAMICHI AMP how powerful?
- Manual transmission with remote start????
- my carpc install
- Console Removal - Hazard Light Question
- 1992 SC400 12 disk CD player problem???
- Share your solutions to the AVIC-D3 and stock amp problem in the 2GS factory amp
- 86 the cd changer in my 99 SC400?
- Who upgraded to 6.5s in the front of their sc and who stayed the stock size.
- 07 ES350 with ML, playing voice command and bluetooth through all speakers
- iphone and 2007 es 350
- Need advice on CompuStar Pro P2W9000FMR
- 94 sc400 stereo help
- 1999 CD Player installed in a 1995
- My Bass has a mind of it's own! It's ALIVE!
- stereo replacement
- Radio question
- Replacing aftermarket with another aftermarket, some questions.
- I changed my Amp, stereo still soft in SC400
- SC300/400 Specific Stereo Install Kit
- Pre Amp Line Drivers
- 12 disc cd changer question
- Audio ?
- Toybluetooth
- LX470 Amplifier Problem
- Aftermarket Sounds where I can play MP3 CD's in my Sc400
- is250 subwoofer ideas
- Need audio advice for '99 SC3 with premium Pioneer
- Splicing question.
- OEM Integration for Sirius And iPod possible?
- Line Output Converter - 2IS
- is250 after market head unit help
- 20-Pin plug in GS300 '02'
- Will someone verify this for me please?
- SC400 Nakamichi Schematics etc
- Factory Amplifier
- Amp just goes into protect mode
- Carputer....which touchscreen to use?
- Heat/ac fan speed inop ?
- A CRAZY? idea for a rear deck subwoofer install (LS430)
- Question about 93 SC300 Alarm Install
- help with my sound system
- Can law enforcement locate me via my Factory Lexus Navigation System?
- Aftermarker Headunit
- Fiberglass sub enclosure sc300/400
- 2 in the trunk...
- Installing sound system
- Amplifier help (switching to Avic-Z2)
- SC430 amp/sub install - Electrical help
- media type for Navigation DVD Backup
- Post pictures of your systems
- Feedback on Factory Systems
- Weird problem with 99 gs400 nakamichi
- Questions about stereo installation
- Recent work done in my '96 Lex GS300
- Adding aftermarket rear DVD to GX470?
- GS400 Pioneer Question
- Need speakers recommendation non-ML
- Gas Tank Location Question
- 2002 IS300 audio buildup (540 Whp)
- Stereo Install
- Eclipse AVN 5495 and Ipod capability ?
- need help
- Sound deadening question.
- where can I get a preamp signal for an amp in a 2003 GS300?
- How to get keys made
- Screen question
- Anyone run Audison amps?
- New speaker system!!!!
- extra battery? 15 farad capacitor? both?
- GS400 Midrange Speaker Upgrade Question
- Video of my sub
- SC3/4 Bass transfer tricks?
- want to put in an aftermarket cd player....
- My magazine will not reject, HELP
- Pioneer guru's - need your help. N1 to D3 conversion
- Navigation system Map Datum
- I just scored 2 NEW Eclipse AVN Navs for under $1K
- Need Help Asap!!!!!
- Amp and sub install results (ML system)
- double din kit
- Removed stock radio and amp and the inputs don't look like the intellexual diagram
- Driver side door key hole tumbles missing
- Help Windown Goes Down but Wont Come back-up from Main Switch
- WTB Pioneer avh-p6800dvd (doubble din)
- Faceplate
- SoundLinQ2 (SL2Vi) Installed as a tester on my ES330 (06)
- LS430 2001 Subwoofer Replacement
- Need Help Finding the VSS wire AVIC-D3
- Custom stereo in a sc400
- Please share your Eclipse AVN Splash (startup) screen
- 1990 LS400 OEM subwoofer repaired
- My walkthrough of sound deadening my GS
- 08 IS350 Sub and Amp install
- ? HD Digital Radio
- XM sound topping sporadically
- HELP!! with oem alarm
- Why is it not recommended to connect dual voicecoils to seperate amp channels?
- Anyone knows how to adjust JL amp?
- CD to DVD Charger Swap
- Problem with stock radio.
- 2007 IS w/premium sound questions
- Nakamichi worth it if going aftermarket?
- Electrical problem...Help?
- Tweeters In a 95 Gs
- OEM Rear Sub powered with old skool rockford 200a2 amp
- Nak 12 Disc CD Changer problem
- Headunit suggestion: Flip up, Navigation, Bluetooth
- 04 LS430 factory back up camara repairable?
- Installing Harman Kardon Drive + Play 1 in SC400
- JL Audio Component Speakers. XR vs C5
- Fake Theft Deterrent
- BMW 3 series style door handles for 2GenGS
- 01 ls430 levinson subwoofer- what is the impedance ?
- Suggestions for 6.5" Speakers
- Voice Tags, Speed Dial, Voicemail
- Installing Alarm
- hvac problem...SC300
- Viper 790xv problem on sc300!
- Viper 790xv woes...
- Anyone renewed Sirius for a reasonable price?
- HELP...Stock Nakamichi Rear Speaker Issue
- 97 SC400 front door speakers
- Pioneer Radio
- 2000 GS pioneer wiring diagram
- Radio
- Why no iPhone compatibility listed?
- Sub with factory NON ML radio in 07 IS250?
- Pioneer radio
- navigation dvd help
- Anyone Runnin Kicker L7s?
- Can someone enlighten me?
- avic d3 instalation
- OEM Navigation System
- Not all power wires are made the same even at the same wire size
- Left front speaker failing - amp problem?
- 12-Disc Changer on SC400 died... any tips?
- How big a load can the stock alternator take on ES330?
- No Power To Radio
- Playing MP3 CD's
- Opinions of Boston Acoustics S50
- remote start help
- Pioneer, No Power 93
- How do you remove the antenna?
- Navigation update suggestions for 2004 RX 330?
- Stock Nacamichi lost all sound
- 96 es 300 aftermarket radio install please help
- Need help with GS400 Stereo Upgrade
- Double DIN dash kit?
- 2 Infinity Basslinks
- Electrical Wiring Question
- Radio Dash kit
- need help with after market headunit
- OEM Navi (Hard Drive) Lighting Question
- alarm doesnt chirp, evrything else works
- System For A Gs350 O7
- A few issues with the factory alarm on my SC
- New to CL, problem with Factory alarm
- Need help with Line Output Converter
- sc300 seat wiring diagram
- HELP! stock alarm going off for no reason?
- Stock alarm going off crazy
- factory alarm
- install iPod adapter in console
- nav override impossible v06.1?
- Is it ok to replace my stock amp with this?
- Any way to replace Nak Amp with aftermarket amp?
- Karnig Devices Melville - Vaistech - Any experiences?
- need help with sound system
- 2006 RX330 stereo help!
- need help with install
- In-Dash GPS Unit (Yeah Right!!!)
- help everything is messed up
- Need power inside cabin
- Good midrange speakers to get for the 2nd gen GS
- 02 sc430 mileage
- Car alarm going crazy?
- Aftermarket radio
- ES250 Antenna Problem
- looking to put sounds in my sc, few questions
- Tool to "release" pins/ pinning tool?
- Subs "popping" when driven hard
- Replaced factory head unit, now no lights on radio or a/c
- Kicker KX400.1 Amp - NYC
- 1GEN GS300 stereo guru’s needed (Badly)
- lexus factory beep w/ aftermarket alarm?
- Radio keeps going on and off
- Pioneer Radio
- Pioneer AVIC-Z2 nav
- i just put in new alpine deck but now gap
- just aquired a new security system
- need help on my aftermarket radio
- help with sc 400 aftermarket headunit/ aftermarket amps
- Navigation system
- Navigation System
- Youtube SC400 Autostart
- advice about replacement keys?
- CD Changer Skips.. Help!
- Remove rear deck of 2001 GS430??
- those complaining about rattle on your aftermarket infinite baffle sub
- Post pics of you headunits.
- Sc300 dilemma (audio)
- 93 Sc300 5 speed need help locating VSS wire and reverse wire!!
- 2nd Gen Trunk rattle
- SC300/400 Retractable Stereo Cover?
- Q: How to install my dvd player?
- ??trim Rear Deck Sub Mount To Mount 12" Sub??
- Component Speakers Or Regular Speakers??
- Navigation DVD 7.1 in hand - First impressions
- can you
- Sat radio in a GS 01-05
- Viper Alarm system- Top Of THE Line!
- Took off SC Radio, found something- What is it?
- Aftermarket Navi
- Stealthy IS300 install w/lots of gear & HUGE PG Octane Ltd amp: Part III
- Factory Cell Phone Ant.
- After Market Audio System and NAV
- Suggestions on new amps and sub
- JL Audio W3V3 subwoofer
- Ls 460 Dvd
- What are the pro's and con's of a full range Class D amplifier?
- Re doing set-up
- Valentine false alarms only @ night
- DIY: Pioneer Amp Replacement
- Swapping ML Sub for JL Sub - How Many Watts Can I Go?
- Can you retrofit a 8 ohm driver to act as 16 ohm?
- Mount 12" Sub In Gs 300/400/430
- is this possible for us sc300/400's?
- Sub fades in and out while driving
- What aftermarket alarm system?
- found a harness for sc300
- Sirius Radio and the GS2
- need help with sc300 wiring harness..
- sub removal asap
- New SC300 - Radio won't turn on...
- Running a 12" and 15" sub off of the stock 8" sub.
- Factory XM instructions
- new head unit
- ML amp Vs. Stock
- After market HU with factory amp?
- lenght of rca cables for aftermarket install.
- 70-8112 harness discrepancy?
- Aftermarket nav suggestions
