found a harness for sc300
Old Sep 24, 2007 | 12:15 AM
tuterz's Avatar
tuterz
Default found a harness for sc300
im using this harness.. it turns on.. sound comes through but alot of feedback.. anyone using this one with the same problem? and the sub isnt working...
Old Sep 24, 2007 | 04:58 AM
dentpusher's Avatar
dentpusher
Those harnesses work well but if you have a cheaper head unit they seem to always be noisy. Either backround noise or engine whine. To get the sub to work you need to wire a RCA end on the correct wires. You could try a inline noise filter which will kill some of the level going to the factory amp. May clear up the problem your having with the noise.
Otherwise its amp bypass time.
Old Sep 28, 2007 | 10:17 PM
JesLet's Avatar
JesLet
tuterz:What kind of harness is that? Metra?
dentpusher: Newb question here, I'm trying to install a Panasonic Nav. What do you mean "wire the RCA end".
Old Sep 29, 2007 | 09:35 AM
dentpusher's Avatar
dentpusher
You wire in a male rca end to the sub signal wire. This will allow you to hook you rca sub out from the radio to the dedicated sub input to the factory amp. This will allow you to keep the factory sub and have control over the level.
That harness doesnt look like a Metra one. Metra uses different colors on the rca ends and they are shorter too unless they have changed it.
dieselpb
Oct 19, 2016 10:31 AM
cormier88
May 4, 2011 08:00 PM
02msmg3
Feb 20, 2011 12:46 AM
FASTEDDY
Aug 19, 2009 01:33 PM
SC4BILLS
Dec 7, 2008 05:28 PM
