Need shop recomendations for San Mateo / 650
Hi,
I think I blew out my Boston Acoustics C110 Subwoofer.
C110 enclosed 2ohm 10" woofer & passive radiator
It sounds like loose metal vibrating when the sub hits.
I need a recomendatoin on a shop that can test the sub and maybe do some other work that I have been putting off.
I'm not sure if i should replace this one. with somehting simmilar.
or Go to a free air 10" or 12"?
This is running of a good ADS amp
Need something close to fwy 92/101.
So maybe I can switch gears with you guys for a sec.
The sub is definetly bad.
I pluged in a 12" from a friend and it sounds fine.
What should i replace the sub with?
The problem.
I went and looked around and the enclosure I have is perfect for me. It's SMALL! 12x12.x12
Everything else I saw at the stores were to big or didn't fit on the shelf up in the GS.
I don't want to go free air for you are not going to get the same sound and I definetly like the enclosure sound.
So here is my problem.
http://www.dealtime.co.uk/xPF-Boston...ompetitor-C110
The C1000 2 ohm (Dual Coil) speaker is not exactly made anymore.
Should I buy anoter Boston Sub?
G510-44 ? 0.59 The total "Q" of the driver
G210-44 ? 0.47 The total "Q" of the driver
http://www.crutchfield.com/cgi-bin/P...tems=065G51044
Which one?
Should I stick another brand Sub that needs 0.579 ft3
I'm running this with a A/D/S P2110 mono at 2OHM
The problem.
Which one?
charmz
19
Apr 23, 2008 06:25 AM
