Swapping ML Sub for JL Sub - How Many Watts Can I Go?
i wanna replace the 10" ML Sub with a JL 10" Sub.
the ML is too weak and delicate, i wanna just swap them out. How many watts can I go up to without having to replace the stock amp?
thanks
thanks
As many as you want. Most quality aftermarket subs will have no problem handling the output of the factory amp. If you get a high excursion sub, then you won't be using it to the full potential.
Do you know the sensitivity of the ML factory sub? You should get an aftermarket sub that has at least the same sensitivity. If not, your sub will sound even weaker than it is now. That's because you can't adjust the gains on the factory amp to compensate for the difference in sensitivity.
-Robert
-Robert
Not only that u have to make sure it has the same impedance as the stock sub. If u get a subwoofer thats lower than u can mess up ur stock amplifier. And if the impedance is higher than the subwoofer will end up gettin less power.
Newegg has keyboards starting at $3.99 and I bet they have a working "Y" and "O" key.
-Robert
Closest they have is dual 6 ohm which if wired in a series would give u a 12 ohm load, but it's still lower than the stock. It'd probably would be alot easier to add a seperate subwoofer amplifier with the JL subwoofer. Thats of course if u have to stick to JL audio. There are other companies that make subwoofers that might drop right in.
this is all so subjective. i dont believe all jlIB subs are 4 ohm. i do know that if you are running this sub you pick on the factory amp then i cant fathom you will get good output from the amp if you somehow get to the right ohm load. i recomend a external amplifier and a jl or focal free air sub( also known as IB infinite baffle.....no box)
1supra
Nov 16, 2011 02:52 AM
