97 SC400 front door speakers
Old Oct 26, 2007 | 02:20 PM
BigD026's Avatar
BigD026
Default 97 SC400 front door speakers
I have a 97' SC400 and my front right door speaker is partial blown. I did 4 searches and found complex threads about upgrading and the quality could be less - due to the baffles.
I don't have a ton of time to research the pro's and con's different door speakers. This is my daily driver and I'm not planning on completely rebuilting the stereo system.
Should i Stick with finding OEM front door speakers from a recently newer SC and just replacing them?? OR do they make a Simple Aftermarket replacement that doesn't require major Baffle redesign work?..
I Just need a simple, low cost fix without too much work other than removing the old one and installing the new speaker.
Thanks,
BIGd
Old Oct 26, 2007 | 02:47 PM
mkorsu's Avatar
mkorsu
Zombie Slayer
More than enough options out there in upgraded speakers. I used MB Quart and used the original baffle. Sounds perfect.
Old Oct 26, 2007 | 09:00 PM
Teal Sc400's Avatar
Teal Sc400
Default Front Speakers
BigD026, Personally, I would never buy used oem used speakers. They will be old and could go at any time. I replaced my rear blown speakers with CDT Audio 4" Coaxial Speakers a nice priced speaker that sound and work great.
Old Oct 29, 2007 | 10:01 AM
UTSC300's Avatar
UTSC300
which mb quarts did you go with? my front right speaker is starting to get crackly, gonna have to change it soon.
Old Oct 29, 2007 | 07:07 PM
kratos's Avatar
kratos
I installed a set of Macrom 4" components in my buddies' SC400 and they sounded great! Just needed a little modification at the tweeter and addition of some wire to the crossover but otherwise quite easy. I have 4 sets of these Macroms at my shop. Looking at getting $140 a set for them.
Old Nov 2, 2007 | 04:14 PM
nicknace's Avatar
nicknace
You sure it's your speakers? Could be the amp.
Old Nov 6, 2007 | 05:55 PM
BigD026's Avatar
BigD026
Yeah...the amp works great in all speakers except front right(pass.) side. I just wanted a quick fix without redesigning my car's stereo design...but it sounds like i'm going to have to put some more time into it.
Thanks,
BIGd
DiabloX22
GX - 1st Gen (2003-2009)
Jul 23, 2017 11:29 AM
dphennis
May 1, 2016 01:17 PM
docdgt@com
Oct 10, 2007 12:53 PM
Whitmanpc1
24
Nov 12, 2005 03:25 PM
cjbdvm04
Feb 10, 2005 09:41 AM
