Trans Question
Old Feb 9, 2015 | 11:22 AM
Jwild909's Avatar
Jwild909
Default Trans Question
Alright so I bought an 08 is250 a few months ago and I started to notice that if I get on it and then let off, it will hold that gear and the rpm's will stay up there until the car finally shifts into the next gear or down shifts. It usually holds that gear for 5-10 seconds. And if I start braking before it has shifted the car brakes even harder once it finally does shift. Is this common or should I take it in to get looked at?
Old Feb 9, 2015 | 11:53 AM
iRock's Avatar
iRock
I was going to answer your question, but you're so rude I would be shocked if anyone does.
Old Feb 9, 2015 | 12:00 PM
Jwild909's Avatar
Jwild909
iRock - didn't mean to be rude, just tired of immature remarks. If you could please respond that would be great. Thanks.
Gville350's Avatar
Gville350
I would start off by disconnecting the battery for 20 minutes to force the car to re-learn YOUR particular driving style. Also, are you in "normal" or "PWR" mode? In PWR mode, the car will tend to "hang" in the gears longer before shifting.
Old Feb 9, 2015 | 12:02 PM
Jwild909's Avatar
Jwild909
ive tired that, and im in normal mode
Old Feb 9, 2015 | 12:10 PM
Gville350's Avatar
Gville350
If that't the case, sounds like what others recently have experienced. Ends up being a solenoid inside of the trans itself.
Old Feb 9, 2015 | 12:47 PM
Jwild909's Avatar
Jwild909
do you happen to know what the cost of the repair is?
markrivers
RX - 3rd Gen (2010-2015)
Aug 25, 2021 11:52 AM
Sox575
RX - 4th Gen (2016-2022)
19
May 13, 2016 01:57 AM
elba123
21
Dec 14, 2015 12:52 PM
1SLOGS
Apr 2, 2012 11:32 PM
aznpapaya
Jun 21, 2007 08:34 AM
