- Bumper duct - i can haz? (Which is this?)
- Iphone/AUX install on GS300 - GROM review & tips & tricks
- Fender flares
- Trailer Hitch Wiring
- 2001 GS300 - Fixing my passenger side mirror
- Anyone remove there exhaust manifold
- Auto locking by speed
- Steering wheel cover?
- VIP Builds. Who says imports can't be classy?
- Got rear ended
- Audio Adjustment Missing
- Gs game is dead, says who...time to lift some spirits
- installing new rims - any tips to reduce scratch?
- Driveshaft/differential coupler question
- 99 GS4 when I give it gas in park, the rear end lifts a LOT
- 2001 Lexus gs430 charcoal evap fuel vapor canister??
- Need Help Buying Tires - 2002 GS300
- 2001 rx300 steering wheel fit 2001 gs430?
- New Wheels! New Kit! New widebody! (:
- Mini photoshoot, new look for 2014.
- Mounting fogs in a L-Sportline front bumper
- just picked up a completely stock 98 gs400, 87k, should I upgrade the suspension?
- Tapping noise coming from dash
- Which oil type? In Dubai 120 degrees .
- 1999 gs 300 starting problems
- Intermittent miss/bogged down
- OEM Crown Mirror Question
- 4th of July Weekend Blast
- Question on Tire size 2003 GS430
- oil leak causing miss. & timing question
- How much would you pay for this GS..
- Spacers?
- Gs300 motor mounts help
- Help Me
- 02' GS300 Passing Speed Questions (?)
- Rear Interior Dome Light
- Interior Door Handle Question
- Rim fitment question
- Antenna noise
- Doing Plugs, wires, and valve cover gaskets, any tips?
- Dash Removed ..Problem with re installing steering column
- A few questions about my new lovely Lexus
- Insane cracking/whining noise from all speakers
- New Member Needs Help w/ Door Actuators!
- Major cooling issue... someone help
- Airbag Question
- Help With Taillight!
- Transmission Fluid refill or drain?
- Retrofit OEM Fogs - Tips on removing Lens?
- Help telling if GS430 has been hit
- Motor swap 03 gs300 won't start.
- GS 430 Daylight Lamp Change Help
- REP 3 Piece JP Spoiler
- Landcruiser Dual Fogs
- Dusty Oil Film?
- Replacing Factory HID Ballast
- A/C blowing hot air!
- key or ecu poroblems
- Thoughts On Gates Timing Belts
- Transmission Fluid Change
- How would I reduce the temperature in my GS300?
- GS 400 throwing codes, very nervous
- lets see your guage set ups
- Plastidipped the GS
- Might be burning oil
- pulling motor and trans. gs300
- Has anyone had a dent pulled on their GS
- Mysterious loose hose in the engine bay
- What is your GS worth to you?
- why would you such a thing?
- 2000 gs400 starting/running issue...please help!!!
- Unusual transmission behavior plus general tips?
- AC Blower Motor Question
- GS400 Throttle Body Problem
- pattering noise?
- Need to get brakes done, any suggestions on pads?
- 2000 gs400 navi for sale/trade!
- New wheels and exhaust
- True Cost To Own?
- Front defroster 2000 gs300 not working
- bodykits.com Has anyone ordered from there?
- throttle body rebuilding
- VSC off , VSC and TRAC lights on after spirited driving?
- 1999 GS400. replaced alternator and battery.
- 2jzgte OBDII Emissions
- shifter console swap
- altenator install
- gx470 shifter?
- 01 GS300 Fog Light Smoking Hot
- Do I really need my parking brake?
- Anyone Remove Their 6 CD Changer?
- GS430 - weird noise/feeling during acceleration
- new guy having a few issues
- Wiring puddle lights to dome light, which wires?
- help please
- *** Fixing headlight condensation ***
- 1uzfe ECU Pinout
- Rear subframe question?? GS300 vs GS430
- wiring harness
- Dumb Question about City Lights 194
- First post! Advice on possible purchase
- Auto level headlight sensor
- Who would be interested in...
- Alignment Question - 2001 GS300
- 99 gs 300 amp question
- GS 2nd GEN VIP aftermarket top quality side views and wood grain console tables????
- Favor Needed - Sunroof dimensions
- Woohoo fresh off the Fedex truck!
- Shift Shaft Seal Leak
- Just got my new Eternity Key!
- Question on Emanage Ultimate
- Shifter knob compatibility
- Thermostat Housing Leak
- Headlight Specs
- Bosch o2 sensor a no go......
- Fan gs4 2000
- Extremely Newb Door lock actuator question. A-hole answers always welcome
- What are these PLEASE help
- Establishing a Baseline for new 2GS Purchase
- First Lexus, and it wont even be mine
- GS430 - Valve Cover Gasket
- Is this the steering rack?
- help, piece of plastic inside the engine Gs400
- Transmission Pan Stripped
- Tan to black
- Just bought a 2005 GS330 but I have a key problem
- spark plugs for my 2000 gs300
- Master cylinder questions
- Trunk
- officially stumped
- Weird Steering Column Noise - Please Help!!
- P1346 and P1351 Code
- Flowmaster mufflers short lived.
- 98 Gs400 Factory radio cuts in and out.. HELP
- Removing alternator, move power steering pump or remove p.s. pulley?
- VVTi Solenoid bad?
- Door mirror switch panels
- tell me what you think
- 1998 (2nd generation) lexus gs300 won't start need help!!
- VSC VSC Off light on
- Need Advice On Maintenance Advice
- Calling all 2jzgte vvti experts. I'm stumped
- New Problems
- Good Price
- Got rear-ended on Saturday morning
- E-shift not working after GTE swap
- help: 2jzgte vvti injector question
- Getting ready to do the 120k service... Tips?
- My bagged daily
- Need a new ac controller unit
- P0420 & P0430 Help please
- car runs, steering dont tilt, can't shift in gear
- Opinions needed: I'd like to keep my GS4
- Where to buy new headlights..
- P1300 code
- Car died
- Different tail lights?
- please help! 98 gs300 dome fuse blowing
- Is the 01+ GS any quieter inside than the 98-00?
- +75 HP Chip, (yeah right)
- New 02 Leuxs GS300 owner!
- Rear Driveline bushing?
- 2000 gs400 with 63000 miles
- Intermittent Steering Wheel Vibration
- SRT intake
- Failed clear coat '00 GS400
- Need help!!!!!!!!
- New to the 2GS/Aristo swap game...questions
- Need help with an Ethic Problem please.
- New Member
- charcoal canister issue
- Average cost for tranny swap?
- Dealership wants $300 CDN for a new master key (not programmed)
- Bought a "salvage" auction GS...turned out surpising
- gs 400 spends a lot of gas , help
- (P0136) - Bank 1 Sensor 2 malfunction
- Keyfob Problem
- MAF Sensor
- Wheel/Tire Setup!!
- 2003 GS430 Navigation Question
- Steering pre-tentioner leaking???
- APP Sensor
- Oil Change
- One of my wipers stopped working! Help
- Hi Idle After Valve Cover Replacement -98 GS300
- Memorial Day mini shoot
- Squirrel nest in cabin air filter housing
- GS300 Transmission Magnets question
- Need Help
- Transmission issue?
- Newly installed Sub & Amp Audio Wont Go louder
- Clunking noise when braking
- Replacement Alternators
- Another Grill????? Have you seen this on a GS
- Abs, Vsc and VSC off , Lexus Gs400 2000
- Projector headlight swap help!!
- Drivers Door Lock Actuator
- straight pipe
- We all got (L)s but we ain't taking no losses
- Head Unit Going Bad... Suggestions?
- A/C doesn't blow in GS 400
- Help me diagnose Battery/Alternator problem (with voltage readings)?
- to shift or not to shift that is the question
- Tire size 01 GS300 18" wheels
- lexus gs400 2000
- How the hell do I change the home address in the GPS?
- over bump thumps
- Does anyone know what kind of vossen wheels these are?
- Here's my '98 GS400 timing belt with 120K miles (with pics)
- Strange startup noise
- JZS International wood steering wheel
- Abs Sensor Changed. Vsc,vsc off,abs light still on?
- Torque loss and CEL after resonator delete and cat change
- Differential issue?? on 2GS
- Please tell me someone else makes these
- Anyone know where to find the alternator wire color codes?
- Introducing: Lexi
- Transmission fluid change 88k miles
- I need opinions on aftermarket motor/tranny mounts
- ColorBond: change your interior color plastic/leather/headliner
- Thinking in having the windows and rear windshield tinted
- VSC / ABS issue
- Anyone know how to take the plug out of the alternator
- Backup Camera Installation
- Need new alternator, my chance to upgrade.
- Possibly heading to Japan Any items I should get??
- Tail light swap question
- skid plates?
- Need help diagnosing steering/possible suspension issue
- help! Broken oxygen sensor connector (female end, Bank 1 sensor 2)
- 1999 GS300 White
- rear axle shaft
- Car Audio Question and Climate Control Question
- Wheel stud length
- so my ac has a STANK to it now lol
- Engine knock
- Misfiring in cylinders 1, 3, 5
- Steering wheel is real tight and hard to turn!
- What would happen if you replace an incorrect 02 sensor?
- Questions about key replacement
- Radiator leak/overheat
- White smoke from gap in catalytic converter after plug change
- Lowering Lexus, any suggestions?
- Lexutron GS4 - What do you think?
- o2 sensor part number?
- For sale and want to buy (“WTB) posts are allowed only in the Club Lexus marketplace
- Yet another 55W HID headlight thread...
- GS400 motor mount removal
- HELP*throttle issue*
- Check engine light!
