why would you such a thing?
Old Jun 26, 2014 | 09:14 PM
pinoiryder's Avatar
pinoiryder
Default why would you such a thing?
so i received error code for O2 Sensor.. I ordered the sensor and now trying to replace it.. In the process of removing the old sensor.. had a really hard time removing it and guess why?
Previous technician who replace the O2 Sensor welded:thumbed: the new one..
Attached Thumbnails why would you such a thing?-20140626_210842_w-215th-st.jpg
Old Jun 26, 2014 | 09:21 PM
monkey92's Avatar
monkey92
wow that really sucks, how did you end up getting it out?
Old Jun 26, 2014 | 09:30 PM
pinoiryder's Avatar
pinoiryder
I have to force it out.. took me more than an hour to remove it.. good thing is the grommet ( i think thats what its called) on the manifold is not damage..
Old Jun 26, 2014 | 10:22 PM
offbad's Avatar
offbad
jesus wtf, the inhumanity...
Old Jun 26, 2014 | 11:39 PM
Lutkis's Avatar
Lutkis
What indicates it was welded? I've changed two O2 sensors and they've both looked like that (the threads) after the removal.
Old Jun 27, 2014 | 01:30 AM
clos430's Avatar
clos430
Lol! That's the way they come out sometimes. It was not welded on. When it's a pain to get loose spray some wd40 and keep going back and forth meaning loosen sensor to it gets stuck and retighten.
Old Jun 27, 2014 | 05:29 AM
burny's Avatar
burny
^this is it
Old Jun 27, 2014 | 11:42 PM
pinoiryder's Avatar
pinoiryder
I check the other sensor and they all came out easy.. I don't think even if they have not been replace before it should not that hard to loosen it.. I soaked it overnight with some penetrating lubricant and still have a hard time to take it out..
Old Jun 29, 2014 | 10:45 PM
Lutkis's Avatar
Lutkis
They can be a PIA sometimes.
Heating with a blow torch is one way to try to get them out in good condition.
Old Jun 30, 2014 | 07:07 AM
TRDmkII's Avatar
TRDmkII
definitely not welded. Stupid heated oxygen sensors do that sometimes.....They can be a PIA.
Old Jun 30, 2014 | 08:19 PM
Lexusjg1's Avatar
Lexusjg1
Yeah I've had mine come out looking like that too. Make sure you use an anti-seize agent before you put on the new one. Never seize etc....
Old Jul 2, 2014 | 10:32 AM
czr73's Avatar
czr73
How often - or - at what mileage should I changed my O2 sensors out ??
I'd like to avoid the experience you had with it.
Thanks..
Old Jul 8, 2014 | 10:10 PM
pinoiryder's Avatar
pinoiryder
Only change the O2 Sensor because it was throwing codes.. as the saying goes.. "if its not broken don't fix it"
Thanks..
Lexmex
RX - 1st Gen (1999-2003)
184
Sep 18, 2025 02:50 PM
ISFLexy
Performance
Dec 6, 2017 07:00 PM
Iparkcars
Feb 24, 2017 06:27 AM
Eric00GS3
Mar 22, 2011 12:55 PM
Blaizze
Oct 3, 2008 12:37 AM
