- Carpet mats, OEM front brakes, Oil filters.......
- Lighting Interior & Exterior
- Looking to Buy a GX before you Trade it in
- I think I broke a valve seat...
- What Is The Correct Instruction For Programming Key 2005 GX 470
- Install aftermarket 4-corner adjustable air strut system?
- Dome Light / Rear Heat
- Engine covers push pin size
- First New To Me Gx 470 Questions
- gas door opens itself
- Transfer case
- OFF button for height control
- Sadly, will be selling my GX
- Lifted with warning light problems
- New to GX Line
- Navigation gen4 to gen5 refresh
- Another Backup camera install
- "Rumble strip" sensation
- coil springs WILL NOT fit.
- Rear Wiper saga
- buying my first GX - rear ride quality question
- Front suspension actuator bolts?
- 08 GX470 Chrome lining accessory
- adding hitch and nav to 2004
- My first GX
- Would You Buy 2007 GX 470 with 115K Miles?
- Warranty on Used Car Purchase - Higher Mileage
- Securing valuables in the GX
- Help me take the plunge!
- Entire car turns off...
- Word of advice for deflating air springs...
- 3 small holes in air box....
- faint high pitch ring...
- Random cross country journey
- Desperate for Advice
- 07 GX 470 mirror control when in reverse
- how to tell if there is a coolant leak?
- 7-Point Trailer Harness Not Lighting Running Lights
- Engine stumble only at 1500rpms
- Backspacing to bring flush with fenders?
- Dash Camera
- faint high pitch ringing....
- New to Forum and new owner of a GX470!
- 2004 GX 470 4x4 High Low Selector stuck in Neutral
- Would you buy a GX 470 with 103k miles?
- Found large rust spot on body
- Transfer case internal lubrication
- Front suspension just above bump stops
- Cv boot clamp loose
- New GX470 owner suspension questions
- 07 GX 470 OEM TPMS SENSOR Part #
- GX470 throwing a bunch of codes
- Purchased an Indigo Blue GX470. Peeling rims. Help!
- if anyone is looking to get a set of sliders for their GX, heres a deal!
- Has anyone installed bluetooth for audio
- Finally got the OK from the wife to get the GX470
- Gx 470 year 2003
- Time to lift my GX
- 1st GX470
- Where to purchase LED headlights
- GX470-C1241 and C1223 codes
- Is drive belt same as serpentine belt?
- Tire rotation discussion
- Problems with Nav/Vais MML install
- Thinking of trading in GX470 for CLS55
- need quick help....my gx is at the dealership....
- 2008 GX470 Moldings Popping Out
- Just purchased a GX
- GX470 writeup
- Re-build front axle boots
- Dealer put 0W-20 oil in my 2005 GX470
- TPMS Sensors..
- Vibration issues at 1500 RPM at low speeds 08 GX470 NEED HELP
- Charging system light staying on after alternator swap out
- Maintenance reminder screen
- engine winding noise diagnosis
- 2004 Suspension Questions
- Navigation diagnositics
- Thinking of selling my GX
- Fog-Light HID Install
- Paint grille to match car color?
- 2005 GX-470 Hand Brake
- Getting 10 mpg!!! Yes, gas is cheap now, but...
- 2005 GX470, A/C Hot Air, Overheating, Antifreeze all over engine
- A/C Issue
- DVD Player - lost remote
- Navigation screen visibility
- Warranty dilemma
- DIY: Side Mirror Motor Rebuild
- Side mirrors won't move side to side
- Water in back seat, seatbelt wet
- Driver Side Rear Seatbelt Soaked!
- FN Wheels
- Chipping paint on rims
- Race Ramps
- Front Shocks
- Help! Why does my rotors warp in about a year?
- First Lexus: 07 GX470
- GX470 RES Screen Won't Fold Down
- Front replacement shocks/coils
- Diff lock flashing
- Factory navigation upgrade help!
- Just bought a 2007 GX
- Battery Question
- NEW navigation disc
- Disconnecting Air Line for Air Shock
- Quick Questions about "Clunk"
- Clicking noise when pressing the horn
- 2005 gx 470 trany/ Problems
- Brake Pedal Issue
- My turn to replace a 6x9 door speaker
- NavTool + Grom Audio for 2005 GX470
- OEM Rotors
- Rattle
- Can anyone comment on the Arnott Air Spring?
- Another Strange Suspention Problem 2005
- 2005 gx470 suspension Compressor wont kick on?
- Outside temp reading is wrong
- Tacoma Windshield Washer Nozzle Upgrade
- ReplaceŽ - Replacement Headlight Lens Housing
- Best options for satellite radio and bluetooth/aux?
- Power steering column - fix/replace?
- 07 GX 470 DENSO Spark Plug Wire Part #
- New Ride in The Garage!
- New wheels and tires on the GX
- Front diff. drain plug STUCK
- Question on handling...OEM performance
- Rusted-Out Undercarriage - Should I buy?
- Help
- 285's on a stock GX
- CRC MAF sensor cleaner safe for us right???
- Lexus GX 470/460 Wheels
- GX470 Front Grill Paint
- GX470 '06 Rear Dome Light
- Help finding switched power for radar in overhead console
- Steering column squeak...
- GX470 Suspension Ride
- Air suspension replacement - labor cost?
- Gas Needle
- RSES Game Controller ?
- No AC or turn signals or fan or heated seats but hazards still working?
- 2 quick audio questions, iphone4 adapter and cd...
- reastork
- Rear Air Suspension
- 2004 Prado - Parts needed
- Japanese Air Bag Recall - 34 million vehicles
- Simple Lift Question (such a thing?)
- Rock Sliders KDSS GX470
- Transmission Issues?
- Suspension issue -on a road trip
- Looking at '06 GX 470
- GX470 - Pick up Monday - Mild Change ?s
- brake controller
- GX as beater utility vehicle???
- Prado kitty rescue
- New 09
- Brake Job Front. Parts help.
- Phone Book Transfer
- GX470 Rear Hatch Lock Problems
- Suspension Decision
- how to install chrome trim/rubber belt on door?
- Broken Rear Shock Absorber
- revisiting the infamous "clunk", permanent solution?
- 2007 GX470 window problems
- Custom lighting
- Maintenance baseline for new (used) GX470
- Help transmission vibration
- Loss of back-up cam while in reverse
- Blinking Light Rear Suspension Conversion KIT
- 04 TOYOTA Prado
- Exhaust Size?
- Tail light updated
- Another headlight bulb question
- Third Row Seats Too Low For Adults
- StopTech Slotted Rotors and EBC pads installed today - Let the experiment begin!
- Oxigen sensors: Upstream and downstream sensors differences
- gx470 broken front shock
- 100w 9005 bulbs for High Beam ?
- Should I buy a Lexus GX 470 '05 with 110K miles on it?
- Anyone use K&N Cabin Air Filter?
- GX470 Engine code help
- Drivers side master window control
- Lowering a 06, possible?
- Not entirely sure what it is
- Another Wheel Upgrade Thread
- Newbie with a few questions
- Trouble code P0430 (catalytic converter bank 2 below threshold).
- GX 470 2006 Rear Height Control Failure
- After Market Head Unit Thread
- Installing Backup Camera on 2003 OEM Navi
- new to this world
- 07 GX Blank NAV Screen
- WTB: Lexus branded license plate frame
- Aux input w/o Nav
- Some changes to my 03 GX. Pics included
- 05 gx470 sport ash blue mica
- Another newby & thank you's
- LED bar mounts, who makes them?
- GX has stopped honking when I lock with the key fob
- Gas cap seal replace. 06 GX
- No sound after battery replacement
- Question for those with 265/70-17 or Larger tires
- Anyone have pics of front fender liner area
- Test driving gx this weekend and need advise please!
- 12V Power outlet failure on 1st gen GX470
- Lifting the GX with Bilsteins 5100's
- Where are the drain holes for the sunroof?
- Lift and Tire Questions
- How many forum members does it take to change a lightbulb?
- New wheels on 07 GX - 20" LE with 275/55/20
- 100k miles service
- Looking For a Good Mech Shop in the DFW Area
- Removing the ML subwoofer
- Pandora + iPhone = Fun road trip
- TPMS compatibility?
- 05 GX470 engine running rough
- aFeŽ - Mach Force XP Cat-Back Exhaust
- NEW member first post on 07 GX 470
- New air springs are in and the great ride is back!
- LX & GX future in doubt
- Chasing some annoying rattles and squeals
- delayed start from stop
- Push Pins for front bumper and under hood plastics
- My new 06 GX470
- New Proud Owner of a 2009 GX470
- Fuel injector cleaning company recommendations
- Possible GX470 owner
- Uhaul Hitch Receiver Issue
- DRL, DTRL Disable
- DIY on how to trick the air bags for us, noobs...please
- First came the scary noise, the the scary lights.
- Possible to eliminate rake, but stay mostly stock?
- Some input needed on a minor lift...Please.
- Options to add Aux input to 06 w/ Nav
- Lexus Parts Suppliers?
- Centric Rotor & Akebono Pad issues
- traction control?
- Preparation for long trip?
- Supercharger thread
- Can't stand anymore, wrapped crazy
- Another Suspension strut- bags - HELP PLEASE
- Price Check on 06 with 145k
- New member, hope to contribute soon, looking for help on 1" rake fix
- Battery light on + whining noise
- Rear Carrier Assembly
- Anyone played with backspacing?
- Ali SC3's 2003 GX470 build thread
- Putting GX on a lift, does air suspension need to be turned off?
- GX470 Exhaust Rattle - Heat Insulator $5 Repair DIY
- Adjusting rear ride height - instructions?
