GX470-C1241 and C1223 codes
Old Jul 19, 2015 | 12:37 PM
brich24's Avatar
brich24
Default GX470-C1241 and C1223 codes
C1241 is low voltage warning and C1223 is an ABS control system malfunction.
Are or could these be related? Where should I start to troubleshoot the issue?
Old Jul 19, 2015 | 02:24 PM
chiph9's Avatar
chiph9
How old is your battery? If you measure the voltage on the terminals while it's running, what do you read? And again with the engine stopped?
Chip H.
Old May 23, 2016 | 07:03 PM
KDAWG97M3's Avatar
KDAWG97M3
So I have the same codes...replaced my battery as it was the culprit...still have the codes, plus a new one.has to do with yaw rate and steering angle??! Any body have a clue? 2005 Gx470. Thanks
Old May 24, 2016 | 07:04 AM
chiph9's Avatar
chiph9
Check the condition of the ground straps.
Chip H.
Old May 24, 2016 | 09:32 AM
techrep's Avatar
techrep
could be the alt going out !!
Old May 27, 2016 | 06:36 AM
chitown40's Avatar
chitown40
I believe you may need to do a Zero Point Calibration.
http://www.toyota-4runner.org/5th-ge...libration.html
Old May 27, 2016 | 11:42 AM
sheikhmax's Avatar
sheikhmax
Default Repair Manuals for the Codes
While I am still searching for my P0010 i came across your DTC Codes. See the Toyota Factory repair manuals. They don't make sense to me but will to someone who is more knowledgeable in Car Tech.
Hope it helps some what.
File Type: pdf
File Type: pdf
Chief514
Dec 30, 2016 06:42 PM
HarrierRX300
RX - 1st Gen (1999-2003)
18
Apr 10, 2016 04:16 PM
kim0217
Oct 30, 2015 04:02 AM
elwags14
GX - 1st Gen (2003-2009)
13
Aug 5, 2015 06:08 AM
LiLS
IS F (2008-2014)
Sep 6, 2013 06:29 PM
