I read the manual but not sure if I understand, what is the point of the OFF button?
I interpretation is you press OFF it will stay at the raised or lowered height even when you turn off the car? But it will still return to "N" anyway once you drive pass a certain speed, just like if you have left it high or low
My understanding is it's mainly for situations where you have the truck jacked up and supported by the frame, so the axle is hanging, and the ignition in the acc or on positions, so the air ride isn't trying to achieve the desired ride height and overextending the airbags, or something along those lines. It's not really something you'll use in your day to day.
If you jack it up by the axle so the weight of the truck is still on the suspension, this isn't an issue.
yeah its for working on the vehicle, though I still dont really use it I just put the key somewhere far away, as long as you don't put the key in it wont try and auto level. there are some jobs where hitting the off button would be a good idea, like suspension work, its even a step in the manual set active suspension to off position or something like that.
I lower my truck to the low setting then turn it off pull in my garage [ Tight area for the roof ] Then when I start car in garage the suspension will not raise until I back out then turn it back on and let it work.
So if I go to the Toyota dealer or generic shop and I don't press OFF, they lift the car am I going to get a suspension error code?
If they lift the truck from the frame and let the suspension droop, and then turn the ignition on, then you'll get whatever consequences flow from doing this wrong.
I'm not honestly sure it will throw a code, or what the results are to be honest, just don't do it that way, lol.
If you go to a shop and the vehicle is supported by the frame, I.E. Wheels are not in contact with the ground or any surface, and the vehicle is running the bags will inflate and possibly blow. This has been my understanding of the consequences. I always make sure I instruct the shop doing work that they need to turn the the suspension "off" if they intend to put the vehicle on a lift and require it to be running. Most shops are fully aware of the need to turn this off, so it has never been a surprise to any shop / tech I have worked with.
The compressor runs based off height sensors, not pressure sensors, so supporting the truck by the frame should not cause the airbags to over-inflate. The sensors will tell the compressor the truck is too high, so the response should be to deflate the bags rather than inflate them.
My guess is that the more likely reasons to turn off the RAS when using a lift, jack, or flatbed are:
If on a lift supported by the frame, the airbags may deflate. Once off the lift, the truck will be sitting on the rear bump stops temporarily.
If jacked up under one side of the axle (eg, roadside flat repair), the truck may try to inflate the airbag on the compressed side - causing the truck to shift.
If strapped down to a flatbed, compressing the suspension, the truck may try to inflate the bags.
