Blinking Light Rear Suspension Conversion KIT
Old May 4, 2015 | 06:49 AM
angelslex's Avatar
angelslex
Default Blinking Light Rear Suspension Conversion KIT
For those that did the conversion kit... Were you able to turn off the blinking light in the dash? TIA
I followed the instruction that came with my kit. "Remove the fuse at engine bay." Maybe this is why is blinking (OFF) LO HIGH. Another member said that he didn't unplug anything but he hears his compressor going off .
Old May 5, 2015 | 02:34 AM
angelslex's Avatar
angelslex
Old May 18, 2015 | 11:12 AM
470reasons's Avatar
470reasons
Check my post at ih8mud.
In addition to the 50 amp fuse under the hood, pull the relay and the 20 amp TEMS fuse under the dash. (Your relay may be a different color than the one in the pic.)
http://forum.ih8mud.com/threads/wher...-relay.800441/
I did the front and rear suspension upgrades. Removing the fuses and relay listed above, should not effect the front suspension operation. If there is a problem put the TEMS fuse back in.
atc2152
Feb 6, 2015 01:54 PM
08lexus350
Dec 16, 2011 10:14 PM
DarKnight
Lighting
Oct 4, 2006 09:37 PM
LasVegasGS
Feb 21, 2005 12:01 AM
