Need Help|Input
Old Oct 21, 2013 | 07:09 AM
99gs713's Avatar
99gs713
Default Need Help|Input
Hello all I have a 99 gs300 just hit 217k I have had it for 4 years I got some horrible news I was coming home from a long trip and blew the head gasket I have called around and I have been told its better to just replace the engine, anyone know of some good info on this or if you would rather just drop a 2jzgte in it?
Old Oct 21, 2013 | 08:53 AM
2GSKaizen's Avatar
2GSKaizen
The GTE swap is relatively inexpensive, but after you add an A/F controller, wiring harness plus install you are going to spend 3-4 times what it would cost to go get a used GE motor from a junkyard. I bet you can find a low mileage one shipped for about $900-1200. I bet you would spend at least $800 for a head gasket, and that's assuming the cylinder head is ok and doesn't need any machining.. I would go the used engine route all day.
Old Oct 21, 2013 | 09:56 AM
99gs713's Avatar
99gs713
I got a quote of 900 and I have a gut feeling the heads are warped then more money I have some money but not a lot so the ge may be what im getting
Old Oct 21, 2013 | 09:59 AM
99gs713's Avatar
99gs713
I found a jdm one in Houston for 1300
Old Oct 26, 2013 | 12:46 PM
2GSKaizen's Avatar
2GSKaizen
1300 Wound be a good buy if it comes with the entire wiring harness and ECu
lequanus27
Sep 29, 2014 02:31 PM
JraztikGS
Feb 11, 2014 08:08 AM
AlphaMotor
Aug 13, 2011 09:44 AM
johnbot123
Dec 1, 2008 03:56 PM
93SC300.
Nov 3, 2006 09:00 AM
