Hids for fog light question
Old Sep 19, 2013 | 11:51 AM
roccyGs400's Avatar
roccyGs400
Default Hids for fog light question
Hi all I've tried searching for this but I tried to install a set of Hids to my fogs but they won't power up its just the plug and play type of kit. Question is do I need to get a power wire and relay for the ballast to make it work or is there another way to make this plug and play work without that harness? Any help would be appreciated. Thanks
Old Sep 19, 2013 | 12:01 PM
rgarjr's Avatar
rgarjr
Should work without a relay harness. Make sure the polarity is correct when you plug it in.
Old Sep 19, 2013 | 12:37 PM
newgsman's Avatar
newgsman
Yup, it's plug and play. Usually its a polarity issue if they don't work. Just switch the plug around. It could also be a bad ballast or bulb.
Old Sep 19, 2013 | 01:36 PM
Advil4u's Avatar
Advil4u
If they dont turn on dissconect the plug and flip
Example----
Wire from hid red------------wire from car white
Wire from hid black------------wire from car blue
Flip to
Wire from hid red---------------wire from car blue
Wire from hid black-------------wire from car blue
Old Sep 19, 2013 | 01:37 PM
Advil4u's Avatar
Advil4u
Also try ur fog set up on ur head lights same plug
Old Sep 19, 2013 | 03:30 PM
roccyGs400's Avatar
roccyGs400
K thank you guys ill try that
Old Sep 19, 2013 | 06:02 PM
roccyGs400's Avatar
roccyGs400
It worked thank you guys
Old Sep 19, 2013 | 07:19 PM
GSTim's Avatar
GSTim
Good that you figured it out. Enjoy.
Old Sep 20, 2013 | 11:41 AM
XenonDepot's Avatar
XenonDepot
Former Sponsor
I wouldn't suggest just "flipping" the connector. You want to physically remove the terminals form the connector housing, and alter their position. This way ensures that the connector gets properly locked into place when you connect to your OEM wiring.
Steve
Old Sep 20, 2013 | 02:58 PM
Advil4u's Avatar
Advil4u
Steve
yes i agree the info i gave was just for testing puposes
jamesbao88
Jan 9, 2011 10:22 PM
shawnlexus
Lighting
Sep 1, 2010 05:54 AM
abounly
Mar 17, 2010 08:16 PM
ScTHREE
Lighting
Oct 27, 2007 03:04 PM
nyczdave
Lighting
27
Nov 21, 2003 07:26 AM
