issue with tire squealing and steering
Old Oct 14, 2013 | 03:54 PM
unreal1171's Avatar
unreal1171
Default issue with tire squealing and steering
After changing the tire rods and lower ball joints of the gs300 2nd gen, i accidental must have broken the abs sensor, cant find a break in the wire. changed tires and aligned, only recently i had the windows down and radio off and noticed that sometimes driving straight my wheels will sqeal like they are skidding. usually if it goes away and smooths out it will happen again when I hit a bump. But that isn't the only issue. the tires will also pull to either side and if i turn really sharp it will pull faster towards the end of the turn. I had the wheels off the ground and spun the front tires, it would make a small noise and seem to do it at the same point in the turn. I hope someone understands what i am saying, i can only assume it is 2 of the 3 probably issues.....
1. rotors are either warped or rusted
2. bearings are shot
3. cv joint messed up?
thx in advance.
Old Oct 14, 2013 | 05:15 PM
MasterKwan's Avatar
MasterKwan
You didn't mention getting an alignment after the install. If you didn't, it's probably off and you're eating your tires.
You have all the symptoms of a wrong alignment.
Old Oct 15, 2013 | 10:25 AM
unreal1171's Avatar
unreal1171
oh, i thought i did, after the lower ball joints and tire rods were replaced I got an alignment.
Old Oct 15, 2013 | 10:28 AM
MasterKwan's Avatar
MasterKwan
Ah missed it. You still have all the symptoms though. Might want to take it some place else and try again. 1/2 the alignment shops don't know what they're doing.
Old Oct 15, 2013 | 10:46 AM
unreal1171's Avatar
unreal1171
ugh, i was going to today take it back to midas, it bothered me with the printout i asked for that one
when relooked at it, the first set looked off, but i was tired and didnt question it, didnt know which went to what.
Old Oct 30, 2013 | 02:18 PM
unreal1171's Avatar
unreal1171
do these look right??
Jadenmart
IS F (2008-2014)
Jan 4, 2016 12:10 PM
P128sniper
Mar 27, 2015 06:01 PM
Toshihiro
IS - 1st Gen (2001-2005)
Sep 29, 2011 11:48 PM
pollvx
Feb 14, 2009 10:44 AM
dugong
Oct 28, 2006 04:27 AM
