- Off Road accessories
- Affordable tire replacements in year round warm climate
- Looking to sell stock wheels with tires
- SSO rear bumper, returned
- Starting and Jumping
- Need Help! Chrome cover for mirrors
- GX470 DIY Channel
- Shock absorber leaking
- Code P0010
- My new 2004 GX470
- I'm getting a new bumper... and light... and...
- Bluetooth connection with kindle fire
- AC Problem = Dealer Problem - Help!
- Motive Power Bleeder for brake fluid flush
- Touchscreen not always working
- Projector Lamp issue
- Any interest in my factory 2003 non sport headlights?
- Height sensor bracket
- Why are more people not complaining?!
- 275x55x20, What Backspacing
- New hitch
- Windshield wipers go into intermittent mode when stopped?
- Battery Light on and Whining Noise
- A/C Problem - Driver's Side Not Cold but Passenger Side Is Cold
- My 2008 lexus GX470 will not go into gear
- Transmission Fluid Change Questions?
- radio cuts out at high volume
- Potential stereo upgrade strategy - remove Navigation
- 06 GX470 master window/door lock inop.
- GX470 manifold exhaust leak
- Getting rid of the GX
- GX 470 Sliders Colorado
- Vsc, skid and check engine lights came on
- Boat Towing
- Please help. Car won't run. P0118, P2111, P2119
- Rat ate my car!!! Help needed!!!
- Hitch Recomendation
- Would you buy this car? 04 GX 135k for $11500
- LED lamps
- Newbie (for a reason...)....
- Preventing Frozen/Rusted Calipers
- What did you pay for new brakes pads?
- Skid plate part number?
- Hub size confusion
- Intro\VSC
- Power Window Relay Location?
- OEM Suspension (swap?)
- Remove Transfer Case question
- Best replacement front rotors
- How to? Add XM Radio to 2005 GX 470?
- GX470/Denver, CO/GOBI Roof Rack
- Suspension Shop recommendation in Orange County CA
- Rancho Quicklift leveling Struts + Rear RS9000XL Shocks Kit - 03-14 Toyota 4Runner
- 2006 GX Rims and Tires
- 2004 dvd/nav wiring diagram?
- 2015 GX Rims and tires
- GX 470 Seat Covers
- Online or offline service guides -
- Almost set my truck on fire yesterday!
- GX production not affected by earthquake
- Who replaced Sewell for 25% factory parts
- Perplexing hard start issue
- What are my original wheels and tires worth?
- Would you Consider Buying this 470?
- Level 8 MK6 Wheels
- Magnefine tranny filter?
- Has anyone replaced original shocks with original shocks?
- 2004 Rear Brake Pad Wear on Rotor Question
- Driver door lock actuator
- Front Driver side Caliper Seased.
- deleted
- May have found my "rumble" sound. Shocks?
- Thinking of buying a used GX470, any guidance
- GX470 hitch instructions pt228-60540
- Stealing Noise
- E15 fuel
- Anyone put in 4runner rear cargo shelf?
- Aftermarket door speakers - what are you using?
- New to the club - needs some work
- Can't get license plate light to stay in
- Mysterious broken roof rack trim cover
- Broken Wipers
- Was the timing belt changed?
- Headliner / Antenna install question
- Adaptive Suspension question
- Anyone ever use AllDATA online repair manuals?
- Transfer case boo boo
- Reliability of off-road features?
- GX470 Transmission OIL replace
- License Plate Lights
- Front caliper piston won't retract
- replacing body panels
- Deciding Between 2004 and 2005 GX! HELP!
- LED headlight bulbs
- 2004 GX470 OEM Pads & Rotors
- Coolant leak under intake?
- Has Anyone Successfully Changed Passenger Seat To 8 Way?
- Wiper Not Working
- TPMS again
- Fitting 32.1x10" Tire.
- Front brake caliper bolts frozen
- 2005 GX470 offer questions
- New Member looking for new wheels
- My Build over at ih8mud.
- Navigation update
- Gx470 center bore questions
- No deceleration when letting off the gas
- Solid SUV
- Hi, cheapest bluetooth audio option on my 06 navi gx 470?
- White Lettered Tires
- Front License Plate Mod
- Haunted Car-Crazy Ghost Noise
- 2006 gx470 passenger leak & clicking noise
- How do you get the rear airbags out.
- Lets advertise for everything
- Adding a MP3 player has my head spinning.
- Climate Control Background Bulbs...
- Lexus Key Code inquiry
- Finally joined the club.
- Trailer hitch
- 1st gen QX56...thoughts?
- 2005 GX Production start date?
- Anyone used the Bilstein 5100 lift kit?
- Electrical Gremlin... windows, locks and mirrors
- ML radio won't power on : (
- Prepare to be impressed!
- Brake Bleed Problems, Bad Brake Booster?
- Fixed my rear Parking Brake.
- Still chasing obscure road rumble!
- Just finished my build
- NEW OEM Nav disc PT219-GEN5W-15
- Help Broken Rusted Rear License Plate Screw
- 2004 GX470 Cracked Dash replaced
- 2004 GX470 Roof Rack Kayak users?
- Ticking noise coming from my glove box.
- Refreshing the Entire Front Suspension.
- Timing Belt and Camshaft/Crankshft Seal replacement??
- 06 GX470: Keep or lose?
- New 2008 gx470 owner
- Possible to use onboard air compressor for air horn?
- OME 884 vs 885
- FINALLY found one I like. I belong now. :)
- Please help!
- A/c compressor?
- Transmission Filter/Strainer - replace or no?
- Old Man Emu Prado 120 vs 4Runner Shocks and Struts.
- power steering fluid leak
- Howto: Replace the headlights
- 05 GX470 Sitting
- Lexus gx470 (Facebook Group)
- If change shocks and springs is there a check light?
- Buy '03 LX470 or '08 GX470 ?
- Looking at an 08 GX470 - Question about a concern
- Rumbling noise? Is that driveshaft clunk?
- GX470 vs 460
- Wheel Bearing Assembly Options on Ebay - KOYO
- Loud roar on left side of GX470
- 2004 Front & Rear Shocks
- 04 vs. 05
- Fluids changed 😃
- GX470 Rear Shocks
- Will 275/70/18 fit?
- Forum Suggestion
- Radiators: Koyo-vs-Koyorad-vs-TYC-vs-Denso
- 2005 gx 470 rear suspension leak down
- Engaging L for DAC
- Aux input for non-nav radio?
- Air Suspension disables in Freezing Temps
- XM/sirrus and loose sand capabilities?
- Raising and lowering the heat
- Re-discovering the GX
- At last, 6x9 8 Ohm speakers that work great and are cheap
- Coolant leak, not radiator, water bypass joint? Help please
- Lexus of Maplewood in St.Paul MN
- stock fj 8 hole wheels
- New owner Control arm advice
- Timing belt replacement parts?
- How to replace timing belt water pump GX470 2007
- What are my options for front shocks
- HELP - Height Control Switch not Responding
- Lexus GX470 2007
- Radiator- Timing Belt Kit- changing fluids??
- Odd stereo issue..
- Diagnose faulty backup camera?
- Finding a Good GX at a good dealer.
- 1" Lift??? Dont want to give up too much ride quality.
- Remove the rear Hatch inside panel to replace back door lock assemblythe
- Rack assembly leaking
- 2008 GX 470 I have a new on on the way!!!!
- KDSS Light Illuminated on Dash
- Brand new owner! Struggling with aftermarket wheel choice.
- Looking for a replacement GX470 Mud Flap
- Timing Belt DIY
- Sleeper GX Build
- Torque Specifications
- Intermittent Engine Whirring/Zinging Sound
- Side airbag recall 2004-2006
- Early GX470 as a comfortable bad weather "beater"?
- Brake bleed
- Considering buying used GX 470
- Long term fuel trims really high and P0430 code
- Possibly sticking Caliper 04 gx470
- Bent Suspension Mount on Rear Axle
- New to us owner...
- Suggestions for a smooth ride
- Trying my BEST to avoid the minivan
- Oil pan replacement
- GX Wiring Diagram Wiper Washer System with Rain Sensor
- GX Wiring Diagram Starting & Charging
- GX Wiring Diagram for Sound Systems with Rear Entertainment
- GX Wiring Diagram for Sound Systems W/O Rear Entertainment
- GX Wiring Diagram Power Distribution / Power Windows
- GX Wiring Diagram Interior Lamps incl Horn / Rear Wiper
- GX Wiring Diagram Exterior Lamps incl Tow
- GX Wiring Diagram Engine Control
- GX Wiring Diagram Door Lock
- GX Wiring Diagram Air Condition
- Oil Analysis report
- Do you have any nominations for links for the 1GX FAQ & DIY Thread? Your help needed!
- VSC TRAC, VSC OFF and Check Engine lights with code P0057
- Help - cannot open passenger door after changing actuator motor
- My interior redo madness.......
- Looking at buying 2004
- Sewellparts.com
- 2016 Navigation Map DVD Gen 5 U40 15.1
- New GX470 Owner
- ML stereo volume briefly stopped working
- Keys please
- 2005 GX470 Aftermarket Radio and Rear Seat Entertainment
- Just bought my gateway GX! A few questions
- GX470 Rear Door Gas Strut / Spring Mod
- Timing belt 2007 Lexus GX470.
- GX 470 Seatbelt / Seat belt assembly malfunction
- 2004 GX470 heater blower
- kdss failure
- Need help replacing on replacing Windshield Washer pump
- VaisTech MML Quick Review
- GX470 Intermittent Start Problems
- Wiring Diagram? Reverse Light Wire in Cab?
- Window issue, binding
- power steering issue
- front & rear shocks
- K&N air filter damage?! Please help
- Suspension issues
- Spark Plugs From China
- Anyone buy a remanuf Denso alternator?
- gx470 2007 dash dimentions
- Range indicator won't reset after fill-up
