View Full Version : Suspension and Brakes
- LS400 calipers missing bolts help!
- Stupid squirly car
- Odd Vibration From Rear Tires
- How I got a free LS4 BBK rebuild kit!
- Supra Suspension
- Inner Tie Rod Leakage?
- Urgent Suspension Question
- Front end Suspension!!!
- Upgrading SC400 front end/suspension to Supra TT spec. What is logical progression?
- Power steering help!!!
- Does anyone have the GTSPEC strut brace on their car?
- drifting ebrake shoes?
- Coilover guys, inside!!
- Hub help!
- Strut tower braces
- Best Handling/Looking suspension compromise for BAD roads (NYC)
- front end question
- MKIV Kei Office coilovers
- SC400, Late Understeering At High Speed Normal?
- 1997 sc300 Control arm help
- Problems with Espelir lowering springs
- Polyurethane lower control arm bushings.
- strut bar
- OEM caliper question...
- Looking for these
- Quick help needed with front caliper fitment!!
- Megan Racing or Battle Version ?
- sc300 rear suspension
- Stock supra vs soarer ride height
- droppin my sc
- Help Please! 92 sc400-lower control arms
- Suggestions for SC400 Rear Brake Upgrade
- Help on rear left wheel.
- notes from front strut repl. today and noise check
- Camber kit for Sc300??
- 92 SC400 clunk noise from front left when braking while backing
- TRD Door Stabilizers (for FRS)
- Brake Master Cylinder or Brake Booster?
- Bushings basics
- Problematic brackets
- BBK Prep. Opinions
- Coil overs for drag racing
- offset on sc300
- 10 Spoke GS300/350 wheels clearing LS400 brakes
- diy for sc300 brake boosters??
- Tein Coilovers for 95 SC300
- ride quality on heated springs??
- Please identify this hose/line by my steering rack...
- Bushing kits differences between different years?
- 1997 SC400 Supra TT springs and struts Alignment issue
- Will these struts fit my 1992 SC400? (newb question)
- Lowering springs help
- TEIN: Comfort Sport (CS) - Cruising Master's
- will a sc400 rear wheel hub fit the sc300?
- 1995 sc 400 brake issue
- Upper control arm bushings
- SC400/SC300 E-brake shoes
- I had an idea... do you think this would work?
- who's slammed on 20's with coilovers not bags!!!!
- Finally!! Found a proper fitting set of ls400 bbk decals!!!
- Help with rear rotor scraping!!!
- Rack and Pinion Transfer
- New suspension not lowering all the way, need help
- Rear Rotors Help
- Wisefab knuckle/uca/lca setup...
- how to get more neg camber???
- 1998 SC400 Differential bushings?
- new springs or cut coils???
- any 95 sc300 diy for brake boosters?
- Strange knocking
- Looking At Coilovers But ??? (Poll)
- quick rear brake sc3 to sc4
- Looking for the most comfortable coilovers!!!
- brakes not working, i hear air when i press down on the brakes
- Excessive Brake Pedal Travel
- aftermarket caliper replacements?
- not sure what it could be
- Why does it always have to be so hard????(Brakes issue)
- Major brake problem
- Look what I just got! =)
- does a jdm gs300 rear calipers fit on a 97 sc300?
- does a jdm gs300 rear calipers fit on 97 sc300!!
- Quick alignment question
- ls430 brake upgrade?
- SC400 Front Brake upgrade using LS400 Calipers - some issues
- 97+ Spoiler to older Low Pro Spoiler question
- Question on suspension for 95 sc400
- TRD stb fits directly on the sc400 w/pic
- Which Coilovers & Wheel/Tire Help
- Handbrake Replacement?
- Daizen Sway Bar Question?
- supra lcas on 97+ sc400... need to know if they fit
- TT rear calipers, rotors, and pads really worth the money?
- Front lower control arm bushing question
- Suspension arms.
- Brembo Evo 8 brakes?
- Has anyone tried KYB strut mounts?
- Inside edge of rear tires wearing quickly . . .
- SC wheel camber?
- Rear solid subframe bushing install vids
- LS400 bbk quiick question
- Rear Toe, camber, and tire wear
- buying wheel hub bearings
- Hwy wobbles shakes still UNSOLVED!!pls chime in
- bushings replacements where to start
- 92-96 vs 97-00 oem struts
- NA-T Strut Tower Brace
- Show me your Ls400 brake setup
- Replacing Front Subframe/crossmember
- Eibach question
- Eating rear tires way too fast
- tein hr coilovers
- which pads for ls400 brake setup?
- which braided brake lines kits for ls400 calipers and supra rear calipers?
- Tein Pillow Ball Upper Mount?
- lowering springs or coil overs?
- Diff hop
- Painted Calipers
- Camber Wear Pictures
- TME about kw v3's
- Recommend me some brake pads . . . .
- Front Lower Control ARM bushing install issues
- Still rides *ROUGH* need assistance plz.
- 95 sc4 brake noise
- how do u check abs codes on 98 Sc300?
- Ksport Kontrol Coilover HELP
- Best Place to buy Espelir springs?
- Spacer question
- gs300 front suspension noise
- Dorman upper front arms: $142.24, pair! Delivered!
- LCA Rear Bolt Seized
- What are some good coilovers for an sc?
- UAS - Airride brackets
- Are the Ebay bushings the right ones for my SC??
- Titan Sway Bars & Megan EZ Coilovers Installed on 99 SC400
- want to raise SC300
- popping when braking
- brake pedal randomly goes to floor?
- Help please!!
- Coilovers advice
- supra lower control arms
- Help with Trac/ABS delete
- Rear Klunck Noise
- what is a z30? oh and a suspension question
- Cut springs vs. Lowering Springs
- Recommended Camber Kits?
- Just thought I'd share
- Rear caliper stuck??
- Anyone used RHD Japan before?
- Inner and outer tie rods - ok to go with eBay ones?
- Front end vibration
- Picture Request of 2.25" drop on 18's...
- need some help with the SC maintenance
- TT and LS Brake Guys, can you do me a quick simple favor?
- SC300 Camber kit
- Getting Ready to lower and have a question
- coilover help
- Opinions Needed!!
- Bad vibration at 65mph(It's not the balance)
- helpp calipers dont clear wheels
- Rear Control Arms
- Made my own rack and pinion bushings, put it steering rack gromet. :)
- 94 sc400 compatible with 97 sc400 abs speed sensor?
- Common Problem - ABS Light after 1jz/r154 swap. How 2 Fix??
- 1993 sc300 abs system
- strut insulators
- Few questions about BBK
- working on an install vid, subframe spacers
- Having some issues with my coilovers
- Battle Version Tie rods
- i cant feel the road???
- oem rear camber adjustment
- FINALLY! '92-'96 LCA Bushings on '97+
- Silver Mine Motors Big Brake Kit
- suspension question
- Rear lower control arm bushing for SC430
- 92 lexus sc400 strut boot question
- sc4 calipers on back?
- SC400 Brakes
- Suspension Techniques Springs??????
- BC racing coilovers installed...pics inside
- Rear caliper upgrade besides TT
- Blox lowering springs
- Falken TT Springs/TT Struts
- Brake line thread and pitch size
- What happened to all of the generic BBKs?
- spring compressors for coilover install?
- Relocate Wirring Harness if dropped on MKIV TT Springs
- Stance SS or Fortune Auto ??
- Help camber kit
- suspension guys need help
- Suspension and wheel guru's where are you guys at?
- Coilover help suggestions...JIC Magic vs. HKS Hypermax 2 vs. Cusco Vs. Toms Advox
- What pads do i buy for upgraded rotors and calipers
- Need help, Brakes
- bilstien coilovers
- megan/bc racing/pbm coilvers
- Anyone using K-Sport coilovers
- I want a lexus ride
- Need advice for coilovers
- poor mans supra..
- what is the best choice in suspensions
- eBay/cheap suspension arms... experience?
- Strut Assembly Replacement
- type of springs
- Corvette Brakes on SC300
- Struts/Springs and Bushings Recommendations needed
- replacing front struts, what about bearing plates
- Suspension Upgrade: Best comfort with performance
- Evo components on steering rack?
- LS400 BBK question?
- Yellowspeed coilovers??
- HELP with control arm bushings
- HKS Hiper-D coilovers
- Road Race
- with 18" rims best coil spring and heights of drop???
- Wheels/ Calipers fitment question (I've searched)
- 1995 SC300 control arms interchangable?
- Front lower control arms
- Different clearance driver/passanger side
- Megan Racing tie rod ends... :dunno:
- Coilover Advice / "What's this bumer?"
- Manufacturer camber specs
- SC 400 shocks and supra springs?
- Wheel stud length?
- Rear Camber Kit suggestions?
- RANDOM BREAK ISSUE 92 SC 400. Need help asap.
- sorry
- Cheap way out?
- In need of brake help please...
- steering wheel turns on its own
- What size BMC does the Supra TT and LS400 use?
- passenger side steering rack grommet
- Sourcing Brake lines for ABS removal
- Quick help on coilover spring removal. STANCE Coilovers
- Which Rotors for ls400 upgrade
- will stock 97 supra springs and struts work on a 92 sc 400
- Are the 92-96 SC control arms bushings different from the 97-00?
- Steering rack bushings review
- So I dropped the back of the car yesterday
- LCA bushing inserts
- Ksport Version RR anyone??
- Rear stance issues
- what should i replace?
- ABS Light -> 1JZ Swap
- Where do you get your Balljoint boots?
- Anybody have a link on where to buy ls4 bbk decals at?
- LS400 caliper upgrade & rebuild
- steering rack - variable valve questions
- na vs turbo exhaust manifold design question?
