View Full Version : Suspension and Brakes
- Outer Tie Rod Thread Size/Pitch?
- ls400 bbk help..
- Are new struts supposed come compressed?
- Rear brake noise help
- paint ls400 calipers
- Lowering Question for my SC400 Need help...
- anyone running bilstein shocks with H&R springs?
- Drifting and the ls400 Brakes
- Is this Important?
- camber correction kits necessary?
- SC400 Brake Upgrade... Need Suggestion
- I really need your help guys, Suspension issues...
- Front brakes on my 02 IS300
- 95 Supra TT Eibach Springs 92 SC400 fitment???
- clunking noise from rear suspension
- Tein Basic + what rim size?
- Ride Height
- Supra Bilstein ANd Supra Eibach Pro Kit Drop
- ball joint inspection
- Ebay Tie Rods?
- A whistle from where???
- Carbing strut tower bar
- tein flex coilovers or tein super street coilovers
- SC brake upgrades ... comparison??
- 20mm Wheel Spacers-- installation question
- **Volks, StopTech, BattleVersion, Daizen, Tanabe w/TEAS, Brembo lines, ARP soon**
- TT Brakes: Now I'm happy
- Right Front Caliper Problem
- What comes with the Daizen steering rack bushing kit?
- ALL Espilir spring users - please help
- Which coilovers?
- Сontrol the temperature of ATF Automatic A340e on the Lexus SC 300
- Suspension replacement parts and advice needed
- 92 lexus sc/400 looking for used parts ?
- SC400 Rear strut replacement
- LS400 brakes and wheel fitment
- Jumped in my car after work and no ps
- supra calipers for $100
- sc400 Last call.........
- rear end wobbles left to right please help
- need suggestions on a drop
- ~DIY for e-brake shoe installation request~
- can leaky shocks be offset by good coils
- Brake pedal feel (stiffness) keeps getting softer!
- Need wheel weight for 16" OEM 5 spoke wheels
- I hate GM even more now...
- Supra NA Kyb Struts and EIBACH Springs?
- **IMPORTANT** Brake Booster Vacuum Line
- supra mkiv struts vs sc300 struts?
- Supra struts + H&R+urethane = yuck. a noob perspective
- Damn rotors
- Prothane front control arm bushing , 53$
- My Ebay brake set up feedback
- Im done the first of many upgrades
- Front Brake Replacement
- Subtle changes make big differences...
- ls400 caliper question
- Damping vs. Dampening....Learn how and when to use each word
- metallic grinding sound?
- Vibration in Steering (Steering Rack?)
- Vibration problem fixed!
- Soarer brakes
- Steering Rack Replacement
- SC400 Stock Ride Quality
- In need of bushing, Would like OPINIONS of my fellow Sc'ers
- Will a knurl size of 0.509" work?
- whats the signs of a bad ball joint?
- need help with front LCA
- Weight comparision of Supra to SC...
- SC400+ Supra TT Bilsteins+ Tein "H" sport springs.
- Wheel spacers
- $300 for a full strut set and reccomendations?
- Opinions on these aftermarket Upper Control Arms...
- need help on new suspension on
- SC400 Brake Caliper - Help!
- SC400 Front Caliper problems..
- NA-T Clutch, Spec 3 or 3+
- A link to front ceramic pads plz
- finally got my suspension ordered..but
- 92 SC lowering questions
- Stance Coilovers
- BBK question
- too low is not good
- *Urgent* Rear Daizen Sway Bar install help
- Tein special order springs?
- D2 racing coilover yay or nay?
- Bilstien and Tein H combo on SC400
- New Rims Rubbing on the inner lip of rear end
- Decisions, LCAs, springs/shocks, tires...
- Stock Spring Rate SC300 SC400
- IS350 calipers on your SC
- Wilwood Brake System
- Recommended Tool for Removing Rear Control Arms
- LS400 Brake Swap
- TT sway bars
- factory Camber adjustment
- 2GS 300 Rear Brake conversion ???
- Delima...pease help
- Are Tokico the most comfortable
- LS steering rack on the SC
- BC racing Coilovers.
- 92-96 vs. 97-00 strut
- Need help with brakes
- Photos of SC Eibach springs?
- Front end slop... can't figure it out
- ABS + TRAC Finaly removed! *pics*(56K put the gun down)
- Race brakes lots of questions???
- Supra coilover
- Polished LS400 Calipers?
- reman. power steering pump?
- Stoppin power after supra tt brake install... help
- Ground Control Bilstein Coilover Kit
- 93 lexus Sc300 Lowering Springs Help
- whaaaa?? es300 calipers on my sc300!??!
- Steering Problem
- front suspension 1/2 an inch off the ground
- What's so great about them?
- I will be needing new rotors soon.... ebay?
- car came with tuner suspension, want better ride quality
- Sway Bar Worth It?
- lets talk serious camber correction
- Anyone have JIC Coilovers? Review?
- SC300 brakes vs. NA Supra brakes, not the same?
- Suspension Issues with my SC... Can anyone help? :-(
- Shox.com promo?
- 1997 Toyota Supra TT Stock Suspension
- Kei Office Coil Over Question..
- Look what came in!!!
- Bumpsteering Myself Mad
- Tein Basic coilovers help
- MKIV Supra suspension
- HKS Hypermax III / STANCE GR+ / TEIN CST?
- Rack and pinon quest?
- Question about Lower control arms / alignment
- i was bored today ...
- im having to turn my steering wheel alot more
- Pictures of stock SC300 hub
- Which shocks for Universal Air Suspension???
- sc300 lowering spring for sale
- Sc300 coilovers
- IS300 springs on an SC300???
- I Lowered It .. Now Tell Me What You Think
- my soarer rides like a big pile of (blank)
- KAAZ 2 Way
- What should my first mod be?
- Rear Camber Adjustment
- Are fenders interchangeable
- ebay suspention setup
- control arm bushing install.....
- Lowering suspension
- Supra Megan Coilovers on an SC?
- MK3 supra lower control arms
- some one in the DFW
- removing front brakes on sc400. bolt wont come off(help)
- Air Force suspension owner/experienced...
- K-Sport Lowering Springs
- bad ride
- Lost both rear brakes
- Lowering Front Only ????
- Moaning/groaning when turning
- what kinda a wheels (size) i need to clear my ls400 4 piston calipers?
- Steering rack questions.
- Front and Rear Brake Calipers (92 SC300)
- tire life?
- SC400 Power Steering Whine / Need reliable mechanic in Philly area - 19066
- ls400 (99) calipers for my sc300 (94)
- 97 SC300 - But maybe not 97 Brakes?
- stance coilover owners I need some help
- ABS diagram
- coils on the sc400
- Upper Front Strut Mounts
- suspension question help!!
- big brakes and master cylinder
- question ! about coilovers
- Need a new Brake Master cylinder, which one to get??
- tranny mount question
- Price Check for Supra Bilstein SHocks
- Supra LCA Install
- difference between supra shocks/springs?
- Tanabe Sustec Pro Five first impressions
- lexus ls caliper 4 pistons.
- jus dropped my sc...heres some pics :D
- Do i have a camber prob ??? Pics!
- Camber bolts seized to the control arm bushings
- Lowering springs advice?
- Difference between - and + camber ???
- quick question about some coils
- Lower Control Arm Washer
- Rebuilding/Resealing Steering Rack
- tire size help
- 97 SC400 Lower control arm compatability
- Air Suspension Bracket QUESTION!! HELP**
- Something is wrong with my SC please help
- my suspension and ignition project
- Little project I have been working on... Master Cyl Brace.
- Some clunking going on
- Got Coilovers, what else should I replace while I'm in there
- four wheel steering?
- Anyone have a sustec strut bar?
- Air Force Air Suspension Group Buy Interest?!
- Carbing strut brace
- Remove rear brake calipers with a manuel tranny?
- Better steering angle?
- JIC FLT-A2 Adjustments
- High Pitched Sqeal from Rear Brakes
- hankook k104 how long do they last?
- Wheel pic request!
- brake pads
- SC400 rotors and brake pads should fit SC300?
- ? abt SC Brake options, Need expert Fact Help
- mk4 springs for a sc????
- Spring help
- Need wheel size experts. Likely different than what you are thinking...
- noise when turning right...
- endlinks the same on 300 as 400?
- Replacing Power Brake Booster...
- Soarer/SC300 Front Control Arm compatible ?
- Pic request
- This is what happens when you lower your car...
- thump sound after suspension changed
- Tom's Advox installed! sc300
- Caster adj for MITSUGUY
- Steering Problems
- camber kit
- Clarification for SC400 and SC300 rear brake fitment
- master cylinder
- Group Buy on Tanabe Springs
- tighter suspension
- pic request!!!
- TT shocks with SC top hats
- tanabe springs?
- clunking noise after daizen lca.uca install
- suspension issues on a '97 SC300
- ls caliper upgrade or not
- HELP!!! Finished LS400 brake calipers but..
- lots of coilover talk lately...here is some food for thought :)
- IS300 springs
- What about Cutting Springs
- HELP!!!! hub question
- Spacers and ls brakes
- 255/55R16 vs 215/60R16
- need new ball joints for my soarer TT
- Caliper Stickers/Where/who is the best place to buy them?
- SC300/400 Rear Shocks 92-96 vs. 97-2000
- coilovers for a slam?
- Good deal on coilovers?
- Cheapest place to buy suspension and exhaust?
- Help!!!
- SUPRA upper CA with camber adjustment fit sc300?
