View Full Version : Suspension and Brakes
- SC300 Front calipers... Rear
- Supra tt rotors and pad choice
- Aftermarket Springs on Stock Shocks?
- SC400 Brake Disc fit on SC300?
- JDM Supra RZ TT shock/spring: drop not found
- steering lock to lock clunking when turning wheel
- Emergency Brake Shoe Replacement?
- ~~("THE BACHSTEIN") by JJsc3 in adition to the "GIXXER_DREW" suspension~~
- Tire Size for the Supra Wheels on SC
- Alignment problems
- Sway Bar bushing and steering
- Bilstein shocks (~50.000 miles) still good?
- Rack/Pinion Any ideas guys?
- Where To Get LS400 Brakes For A Decent Price
- BEWARE of 88Rotors.com!!! :mad: Please read...
- Valve stem hitting supra tt calipers
- Suspension Inquiry
- Tanabe NF210 springs anybody?
- Differential Mounts
- Tokico Part numbers ?
- ANOTHER MKIV Suspension Question
- SC300 to LS400 brake upgrade
- Rack bushings changed.. Results?
- carbing strut tower brace
- Abs?
- Anything else I should do while installing Tein SS?
- Solution to Creaking Front End Problem W/ Pics
- Rear Suspension Body Bushings
- whats the best?
- Rear Swaying on my 97 SC
- Leaking fluid after TT brake install
- TEIN and JIC Spanner wrenches the same?
- where to get supra calipers rebuilt?
- part number questino
- Where's this thread?
- Supra TT Rear Sway Install DIY?
- Brake light short = no cruise control
- SC300 coilovers. DO I need something for camber adjustment?
- need some help
- supra n/a calipers
- 96 SC300 PICTURES!! coilover and suspension suggestions...
- ls400 brake install
- sever rear tire wear on inside?? 1 side only
- lowering spring help (sits crocked)
- Do 16" Wheels from a 95-00 LS400 fit over LS brake upgrade when installed on SC?
- New suspension design help
- Need help with lower control arm bushings!!
- Got some Silk Road custom coilovers
- Coil overs INSTALLED!
- TRD or Cusco?
- weight diff. between TT or Supra LCAs ?
- Rear Swaybar Binding up.....
- Will '87-'92 Supra rotors fit on a '95 SC?...
- SC400 Brake Pads
- Need Info
- Gold Brake Rotors?????Stock Size!!!
- I cant find this thread
- sc300/400 steering rack
- Power Steering ECU
- Strut Tower Brace
- Rear Rotor & Pads Change
- Alignment issue/Inner Tie Rod?
- How much brake fluid is needed for a flush?
- Springs
- Rear bushings
- Brake Master Cylinder upgrade?
- trd strut bar
- got an alignment but...
- 95 LS400 Calipers or Supra TT?
- SC Rear camber kit
- problem with fitting supra tt rims
- Any word from Bilstein or shox.com?
- Wheel Question about Offset...Already saw the Tire Fitment Guide
- Lowering Springs for (92) SC400... Need some suggestions for purchase
- rotor question
- Questions for anyone who installed Espilir springs..
- need your opinions!!!!!!
- need help on finding spring plz! :]
- Preloading Coilovers
- screeching noise when taking off from a stop...
- Eibach lowering springs? plz hlp
- newly installed TRD strut bar
- TT Sway bar bushings.
- Putting Supra Suspension on a SC400
- Please give me info on E-brake Adjustment
- Control Arms....
- Help I'm rubbing!
- LS Big Brake Question
- Does anyone run 245/45/18 up front?
- Control arms giving out?!?!
- How to set up your suspension
- IS350 calipers on the JZZ??
- Tein SS too much wheel traval?
- What is required to install Supra (mk4) struts/springs?
- need front camber kits for my 98 sc300
- Rear Spring And Strut Install
- tokico rear struts doesn't fit Tein springs....
- Need some quick LS400 brake swap help, where does this part go?!?! (see pic)
- Another What caliper color?! Need Opinions!
- LCA's
- size of front and rear sway bars
- SS brakeline problem, PLEASE HELP!!
- SC and Supra ABS
- Best use of money toward Suspension upgrades
- Squeaking, creaking, what?
- Can the SC be a great handling car?
- n/a supra rear rotors/pads compatible with sc300 rear calipers?
- labor pricing
- Braking System Toyota Supra Turbo 93-98 at the Lexus SC 300-97.
- Difference between MK3 W58 and SC300 W58
- Strut tower bar option??
- Cheap BBK? Xendo?
- Shocks and Struts...
- Tundra's TRD BBK?
- brake master cylinder(Traction control)
- 0* rear toe?
- Out With The Old In With the New, What Did You Do With the Old?
- Supra Calipers
- SC400: Price on used coilovers?
- To buy or not to buy
- Is my caliper seizing up?
- Considering TT Sprints and KYB's
- Espelir rear springs and clunking on bumps
- TRAC OFF blinking and ABS light ON- please help
- Suspension Question
- can you install the front Daizen Camber kit by myself?
- Supra NA Shocks VS Supra TT Shocks
- ls400 calipers on sc400.
- Cant Decide, Hypermax III's VS JIC FLA-FAS
- Tanabe NF210 Lowering Springs, Anyone using these?
- Brakes
- Rear brake clicking noise after changing brakes
- Clicking noise in rear brake after changing brakes and rotors
- Negative Camber...
- Lower Control Arm DIY
- Best coilovers for sc300 daily driver
- *FULCRUM* SuperPro Polyurethane Bushings
- TT upper shock mounts really needed?
- Who else makes camber kits for the SC??
- sc300 break pads and rotors
- The appliance, maintenance, repair Lexus SC300-97.
- How long are the factory studs for the SC400?
- Soarer - Supra compatible suspension parts questions. Please help.
- DIY - Brake Pad Replacement
- Front and rear brake pads SC300
- Red LS & TT TRD style -- PICS --
- Lower control arm ??
- Camber and Espelir Springs?
- Supra Brakes Vs. LS400 Brakes
- LS calipers: Where does this retainer go?
- Help!!!!!!!!!!
- Looking for a Stance Dealer or shop...
- Lower Control Arms!
- Random brake pics...
- Swaybar end link ????
- My gixxer_drew Bilstein Hypercoil Review
- Spare wheel to clear Supra TT brakes
- do is300 coilovers fit on an sc?
- shock and strut question
- steering rack sensor
- need polishing experts
- Factory chrome wheels
- Lowering SC300 question?
- TT front calipers
- Who actually has the "gixxer_drew" Bilstein / Hypercoil setup?
- how long til you received you rack bushings
- can anyone help me with lowering the SC400
- Tread life longevity on a lowered SC and the settings to assure it
- TT sway bars on SC...
- whistling noise!!??
- Coilover Setup...How do you have your set?
- UPS dropped off some suspension goodies
- Tanabe Sustec Pro FIVE
- Need recommendations on rotors for LS setup
- Speedbleeders
- Should my tie rod ends rotate freely by hand?
- Need help Asap
- Supra Lower control arm
- Line Lock (roll control) with anti lock help
- Balljoint Test Procedures...DIY balljoints ball joint
- Poll: Lowered, closest to stock, + inexpensive
- Pls close
- ebrake
- Lowest, Comfy, Sportiest Ride - Springs/Struts
- How to Adjust ride hight on coilovers?
- Supra UCA?
- Part 1: Complete suspension rebuild/replacement
- Please help my rear wheel is turning
- Anyone check ebay lately?
- Trac light + Check engine light on?
- I Want To Go Lower
- Will 245/40/18 tires fit on 18x7.5's?
- 93 Soarer build update
- D2 racing coilovers from Hop Up Racing...
- Where Can i buy replacement brakes for a Decent/low price?
- RotorPros? Good Cheap Rotors?
- Daizen Steering Rack Bushing Problems?
- Where to buy Swift springs?
- E-brake light problems when turning
- Big Brake Upgrade Myths and Fact *LONG Discussion*
- LS & TT caliper hardware: What's missing?
- Faint Squeeky Noise... Possible Bearing Failure?
- lookie how many rod i bent :p
- where to get rack bushings...
- My car's not handing right...
- ride comfort
- Front SUPRA LOWER CONTROL ARMS or front and rear?
- Is this bollocks?
- 275х40 R17 tyres on the rear axle on the Lexus SC 300-97.
- NF210 springs questions...
- carbing strut tower bar
- will ls400 rear brakes fit a sc?
- Does Stance sell indivual coilovers? Mixing Coilovers?
- Look what came in today! JIC FLT-TAR coilovers
- Shakey Front End
- control arms (bushings)
- Supra TT Springs Discrepancy?
- Ball Joint thread pitch and size confirmation
- Steering rack bushings
- Brake lines: What, where and how much?
- brakes for sc300
- Santa was late :-)
- Megans vs. H&R vs. Tein CS
- E-Brake shoes
- spring & shock install ?'s
- Shock/Strut Differences
- JIC FLT-A2's For Drifting??
- ABS/Engine light on constantly
- Need some quick help
- tokico illumina adjustment knob broken!
- R1 rotors
- What's the deal with DAIZEN???
- TT rotors with LS400 calipers?
- Squealing Noise when STOPPED and applying Brakes
- Coilovers vs lowering springs combo
- JIC FLTA2 vs TEIN CS(T)
- Control arm difference
- Brake Leak
- Replaced ps return hose and now it feels overboosted..
- Master-cylinder?
- Zeal coilovers
- Steering Problem
- Wheel Bearings Hub Assy.
- Suspension gurus need info and pics please! TEIN SS and D2s or CS
- Shave the rotors or upgrade?
- How much does your LS400 rotor weigh?
- stabilizer/sway bar link
- Front-end jerks and clunks when cold
- diagnosis needed
