View Full Version : Suspension and Brakes
- Anyone know if z32 rims will clear bbk/tt?
- sc300 upper and lower control arm
- Rear spindle carrier bushing
- signs of bad coilovers
- How to tell if my springs are TT springs?
- 92 sc400 abs light on?
- Rattling noise when i hit bumps
- Help with Supra parts for my 92 sc400?
- Ksport Pillowball top mount are they avail on Lexus sc400
- How do you guys feel about JIC coilovers?
- Broke a balljoint while driving yesterday.
- suspension problems
- Need to replace 1995 SC300 suspension
- Is anybody here running this megan tie rod kit?
- DIY: Front and rear UCA and LCA Bushings, BV Toe, Traction, Subframe and Steering
- Daizen question
- Clicking/Scraping in front-right axle area
- Hey cl! Need a question answered asap
- Supra/sc300
- Stance SS?
- Knocking?
- rear sway bar bushing size question
- Who sells Megan coilovers cheapest?
- sc300 feels squirmy at high speeds
- Wheel play
- Suspension
- new to the forums, what coils to get?
- I need front camber adjustment and nobody sells a kit anymore?
- Soarer Brakes
- pics supra agx adjustable shocks supra eibach springs
- vendor/coilovers
- Strange suspension noise. Anyone up for a guess?
- Chassis Stiffening,NOT suspension
- Passenger wheel play
- I just got my BC racing extenders
- $2,000 to spend, what coilovers? SC300
- tein hr..help
- quick question about lx450 brakes
- Shocks
- Rack bushing
- anyone running a 205-55-16 on the front?
- Drilled/Slotted and Small Calipers
- VERY loud clunk/pop in the front end
- Curious if these rear upper control camber arms will work on my SC?
- another ls400 bbk
- what happens when you swap perches from supra strut to sc400
- SC400 springs
- Supra TT Koni Struts on SC400 Eibachi Pro kit Springs???
- Coilover springrate upgrade
- need your lexus sc advice
- Need help with my power steering..
- I got a STUPID BBK upgrade deal at Revolution Brake
- Changing my rotors- What size in the hub nut?
- EBC brake pad review
- Brake Rotor Replacement
- Eibach Pros - front sits too low (V8 swap). Suggestions on something 1" taller?
- Rear alignment Question/help
- Front upper strut bushing replacement?
- help!!!!!
- which bushings for Supra control arms
- is300 front calipers on my sc300, sc400 rear rotor on sc300
- Strange pop/clunk while driving.
- steering issue
- Question for those who have installed prothane rear bushing kit
- What are the odds of busting a balljoint when I got lowered?
- 98 lower control arms noob questiom
- Ls400 caliper helppp....
- Kontrol pro's
- Best performing shock for 99 LS400?
- Rear Upper Control Arm Bushing Options
- whats the difference?
- i need low
- please tell me i suck at searching
- Is my sc lowered?
- SS Lines and New Master Cylinder Installed WTF!
- Camber correction kits
- Traction arms
- Steering Bushing Help
- lowering spring quest?
- SC300 Lowering springs options? Comfort enough?
- 97 SC400 Lower control arm bushings
- Does anyone know where this part goes?
- odd issue
- Changed 1 of the front struts now i hear a noise?!
- best bang for buck
- slammage!
- Shopping for a suspension set up and could use help
- blown strut??
- Steering clunk
- no coilovers today
- Smooth driving to violent shaking and back. What's going on?
- Eibach/Tokico vs. Megan/Tokico
- I need rear struts. 93' SC400
- car is jerking violently while in reverse
- LS400/MK4 calipers on rear
- ls400 calipers vs supra tt calipers
- brake warning light
- Help! Where are the Trac components?
- Swaping out my Rear struts tomorrow Need some help!
- There another substitute for rear camber without the bushing kit?
- anyone try sc400 calipers on sc300s?
- Thread Pitch
- Considering brake upgrade on 92 SC400
- bad axle
- Tein flex coilovers vs tein comfort sport
- suspension overhaul
- got angle
- Good economical LCAs?
- 93 SC400 Power Steering issue ***PLEASE HELP***
- Help!!!
- will older model front lower control arms fit 97sc
- 1997 Supra TT springs and struts on My 1997 SC400
- Broken Lower Shock Mount Bracket
- New steering column
- are these LCA bushings shot?
- will camber and lowering fix this? or am i going to have to pull
- Wheel still isint straight what can it be?
- Sc400 w/ Tein CS Coilovers! How can i go lower????
- Steering rack bushings
- stock radio code
- shifty sway bar help?
- GT Spec Front Strut Bar
- help removing LCAs please
- Spacer size
- I have a quick question...
- Camber and Tire Wear Problem
- Supra TT vs SC300 Knuckles
- Those of you with steering or ride issues, Replace the rack bushings FIRST
- SC Brake booster delete?
- Suspension
- Questions before purchasing coilovers
- Pillow Ball Upper Mount feedback?
- Suspension wear and tear
- unfamiliar with sc suspension
- Annoying brakes
- help with supra tt brakes
- will s14 5-lug fit SC
- LS400 dust shields fitment and caliper decals
- Drifters chime in. (hydro handbrake + ABS delete)
- LS400/Supra TT Reman caliper??
- "Best" LS400 rotors (new)
- Getting rid of Rubbing
- strut clearance??
- anyone rocking Megans or Ksports?
- LCA failure
- air suspension install for sc?
- air bags from a lincoln navigator?
- What strut mounts?
- SC300 TRD Strut bar
- Anyone know where i can get Stiffer springs for my coilovers?
- christmas present help
- Brake caliper broke that easy?
- LS400 & SupraTT caliper upgrade
- Stiff Steering wheel
- Is There A Way To Adjust Brake Sensitivity?
- Lower my SC400
- Dropping on springs
- Questions before I replace stock struts...
- Hit a Big Dip going to fast!
- SC angle mods!
- GI: Poly bushings
- Vibration, rumbling noise at 40 mph
- Supra lower front control arms?
- wet brakes = cruching noise
- shocks from a camry?
- searched: so are 97 front arm bushings the same as 92-96?
- Weird steering problem
- sticky calipers, even after buying new ones
- Aftermarket shocks & struts
- ABS Module Question
- Cheap Coilovers
- Just did a custom alignment and this is like a new car!!
- Has anybody successfully installed any of these rear bushings in a 97+
- Supra factory Bilstein same as Bilstein HD AK124X?
- Steering Rack
- SS braided lines w/ ls400 bbk
- Bushings questions!
- Installed new supra arms...car still rides like ****
- Slammed SC Problems-Getting Stuck Backing Out of Driveway
- Toms ADVOX Coilovers???? Please offer advice if you can.
- SC300 F+R Camber
- Supra LCA's
- are these the same thing?
- Wobbles
- Rear suspension fustration
- Lower Control Arms..replace or new bushings?
- NON Solid Subframe Bushing Options?
- Are Ball Joint Dust Boots Available Seperately?
- Are SC Control Arm Cam Adjusters Same As Supra?
- Struts for 98 SC400
- Popping Noise In Rear When I Brake
- Just got LS400 calipers!
- Quick braided line question
- steering rack question?
- Rear Upper Ball Joints? And Lower Control Arm Joint?
- LS400 calipers not bolting up, help
- Car feels sensitive on the road..
- Post pic of your ls bbk with after market wheels
- 92 rear lower control arm??
- help sc400 possible wheel bearing
- Post Up Your Weird Brake Caliper / Car Combo.
- ideal suspensions set up?
- Ksport W/ Custom Sprint Rate (Worth it?)
- Suspension set up
- Trying to fit BBS LM with LS400 brakes
- my shocks blown or control arm bushings....maybe both?
- SC Rear Tension set?
- Suspension Question
- Lookin For a Racing Cage
- Where to buy LCA for '98 sc300?
- 92 SC400 Front Shocks
- Dual Calipers
- Strut Bar
- Very, very loud squeak from driver rear wheel
- Noise on tohe highway
- ls400 bbk calipers
- Coil Over help??
- sc300 espelir springs.
- Lower control arm labor
- Has anyone successfully replaced a lca ball joint?
- How do you tell if LCA bushings are shot? Steering is sloppy...
- Looking for Daizen sway bars
- 97 sc300 break upgrage
- Major lower control arm woes with pics...
- Replacing major suspension parts when switching to coilovers?
- Press needed for lca bushing replacement??
- Sketchy Problem....
- Anyone on UAS with stock shock?
- Should I swap Coilovers off to sell my car?
- Rear Strut Tower bar for SC's I made another one...
- Best Rotors for sc300
- help with espelir springs
- Big Problem Need Some Help Please!
- Question on parts for rear LCA's
- Sway bars - 2011
- alignment maxed out?
- 1992 SC400 Rear Brakes Problem
- Lower control arm rebuild??
- Question on supra NA suspension set up
- newSRspecial Shocks w/ Dowmax springs
- Well this is interesting...
- Question on Rear Brakes for SC400
- Help with Supra TT Front Brake Conv. on SC300 (Shim and Fitting Kit?)
- Is it a good idea to do the ls brake upgrade without the ss lines?
- Oh my god ny i can't do it anymore
- Coilovers for my Soarer. Which ones are compatible?
- Noobs & Novices: Suspension & Alignment 101
- What suspension to go with?
- ABS module replacement
- Need some help freshening up my suspension!
