Help with Trac/ABS delete
Old Aug 14, 2012 | 02:22 PM
ihiryu's Avatar
ihiryu
Default Help with Trac/ABS delete
So I finally decide to do it, the biggest reason why I'm getting rid of ABS is because it's no longer working, and hasn't worked for awhile anyway.
So I've gotten two M10x1.0 T fittings, and I'm looking at the ABS/Trac modules on the right side of the car, and I see they are kinda listed, but they aren't.
https://www.clublexus.com/forums/att...e-dscf0491.jpg
On KC's thread I'm looking at the pics, and I can't really tell which one is which.
Also I was hoping for anyone who had some clarification on the master cylinder lines. I can't really see where it's going to the modules.
Any help would be greatly appreciated!
What I'm looking for is a "Pin Out" of the brake system so I can figure out what goes where.
Old Aug 14, 2012 | 04:28 PM
charley240's Avatar
charley240
I havent done it yet, but memory tells me that the rear port of mc is for front lines.
I too would like to do this just for the sake of simplifying stuff and uncluttering the engine bay.
Soo... Im not sure what youre wanting with that pic, but it seems like all that is need is
1) 1 t, inlet is from rear port of mc, 2 outlets are going to left and right calipers.
2) front port of mc to connect to rear line( i believe there is line that runs back and t off at the rear)
3) remove abs/trac modules and units
Also, will you please document this, as i find kc95 thread to be a little confusing and cluttery.
Hope this helps.
Old Aug 14, 2012 | 05:06 PM
ihiryu's Avatar
ihiryu
Right, I'm aware of the master cylinder lines, but what I'm looking for is the lines from the ABS/ Trac. I need to identify what lines go where
Old Aug 14, 2012 | 05:15 PM
over40driv's Avatar
over40driv
Dosent it say which line is which on the ABS unit?
Old Aug 14, 2012 | 06:11 PM
charley240's Avatar
charley240
Understandable, but why wouldnt you just go through the 1-3 steps i listed above. That seems to make the most sense. But i have yet to do it, so there maybe a few other things not listed.
Charley
Old Aug 14, 2012 | 06:35 PM
ihiryu's Avatar
ihiryu
It's listed weird, but it only shows the lines to the calipers. The ones I'm needing to find are the ones from the Master Cylinder to the ABS/Trac unit
Charley
I'm not trying to make new lines. I'm going to bend the stock lines to the metric T's instead.
So the Tee's will be located on the passenger side where the abs/trac USED to be
Old Aug 16, 2012 | 03:02 PM
over40driv's Avatar
over40driv
Wasnt there another guy that took the stock lines unhooked from the ABS unit and joined the o.e. lines together. The plan with that idea is to get rid if the accumalator and trac motor under the master cyl. as well as the ABS pump, but not run all new lines.
Old Aug 16, 2012 | 06:13 PM
ihiryu's Avatar
ihiryu
Yup KC95SC400
I've looked at his thread a million and one times.
Old Aug 16, 2012 | 06:41 PM
over40driv's Avatar
over40driv
So what do you think of that option?
Old Aug 16, 2012 | 07:49 PM
ihiryu's Avatar
ihiryu
LoL, I think you misunderstood me, that's actually what I'm trying to do, however I don't know which lines go to where.
Stupid V8 being all big and hugging the firewall
Old Aug 18, 2012 | 05:18 PM
over40driv's Avatar
over40driv
We need a good DIY on this.
KC95SC400
Nov 28, 2021 05:16 AM
DRFT103
Nov 17, 2015 05:55 AM
LayedOut
Jun 10, 2015 06:17 AM
oldManTan
Jun 6, 2014 01:32 PM
AMSMIKE
Suspension and Brakes
Jun 24, 2010 11:52 AM
