- Quick Newbie questions
- Can you replace just an AC Compressor Clutch
- ML350 ride comfort vs GX470 (experienced driver's only to comment)
- Squeaky A/C blower?
- Thanks for the advice for the leather seats.
- 07 GX 470 please advise on noise
- 05 GX470 Suspension question with error codes
- 2003 GX470 ABS lights needs Accumultor/Booster?
- Rear Air Conditioner Control
- For what it's worth if anyone is looking to buy an '07
- warped rotors and hwy steering wheel play
- Warped rotors
- Total Loss of Electrical
- 08 GX470 Vibration
- Running lights
- Aux audio input on 2003?
- New 2005 owner, manifold leak question
- 2005 GX 470 IPod Adapter
- Thinking of buying 05
- New Member - 2007 GX470
- Re-Locating oil filter
- PROBLEM: Rear Window Tint Film
- Thinking of upgrading w/questions
- Gas grade difference on GX? 87 v.s. 93
- 2005 GX470 Original Tires ?
- 2004 GX470 owners manual needed
- shock replacement
- Those who have converted the air suspension, please chime in
- Beautiful white lines on black paint
- Swaying Problem on 200,000 miles GX
- front axle boots
- dvd audio
- Gx470 2004
- rear mud flap
- Hitch-mounted cargo carrier?
- Adjusting headlight aim
- Inquiry on headlight
- 05 GX VSC OFF & Center Differential Lock lights on
- Transfer case leak
- Possible shock issue
- Outside rubber window seal replacement...
- Tip for fixing heat shield rattling on the muffler
- FS and WTB posts go in the classified forums only
- New member with a VX Prado not a GX
- Do I have KDSS?
- Towing hitch receiver
- 05 GX 470 95k- OBDii Fuel Economy Check
- 05 GX 470 - Android Bluetooth Playlist
- rear running board light loose?
- Is there a way to tell whether mt timing belt/water pump was changed?
- Value of 04 gx?
- Doors stuck in rear entertainment console GX470
- GX470: Tires, Wheels & Gas.
- Aftermarket rear camera issues/reverse light wiring
- Clunk when braking/accelerating
- Got Notice Mail /anyone class action suit ?
- Dac????
- Rear Door Door Stopper!!!!!! Haha!
- 18 F-sport wheels
- Passenger door lock not unlocking
- Loose brakes
- GX470 Power Stop Brake Rotors
- Suspension Problem
- Toyota Oil Filter Diameter for GX
- Found great deal on OEM rear shocks
- GX 470 Warning Lights VSC OFF, VSC TRAC, Anti Skid, Check Engine
- Overhead console sunroof homelink is not working anymore !!
- Shopping for a GX
- New GX club member
- What first generation gx has Bluetooth and Rear Camera
- Adding factory Nav and Mark Levinson to a non factory Mark Levinson Only
- LED DRL and fog lamps
- timing belt
- Bluetooth Audio Streaming
- Is there a negative impact on engines driven for long periods?
- i got an error mesage on my cd
- Borla exhaust direct fit, anyone tried it?
- Violent brake vibration
- value of KDSS when buying pre-owned
- Replacements for Amber Interior Lighting
- How high am I
- Fender Bender Question
- 2006 127k or 2004 85k? Same price, options, condition
- Question
- OEM Cup Holder Divider is available- Do not buy on eBay w/o reading this first!!!
- 2004 GX 470 rear shocks and brakes
- Immobilizer/security indicator light flashes
- Post Toyota Compatible Parts list & Pics?
- Anyone else's HVAC system just quit and then start again...
- '04 GX470 owner!
- Installing rear cargo door glass chrome molding
- New shocks/struts and mild lift question
- VAIS or Costal for iphone?
- K&N Filter on older GX
- Wheel bearing on 2006 GX470
- New GX Owner - Oil Filter Relocation Question
- Gx 2007 Laptop Mount
- Factory Rear Seat Entertainment
- Proper Brake Bleed Process
- GX 470 Air Suspension Problems
- Grease driveshaft
- 04 GX Navigation freezes up
- DIY Lexus GX470 Beat Sonic Double Din aftermarket stereo install
- 2007 GX 470 Starter
- LED daytime running lights strip
- 04 gx navigation upgrade
- HELP, no 4th gear!
- No power, ECU problem?
- Interior wear items/repair?
- South Ontario is calling for up to a foot of snow!
- GX 470 2003 Paint Issue? (Northern Virginia)
- Sd card reader
- New Battery Issues
- 2004 gx470 radio issues
- New Owner OF GX 470, Need Help !
- Maint. Reqd Light???
- GX470 Pintle Hitch with Factory Tow Package
- Double Din Dashboard Kit for 2006 Lexus G470
- Suspension - Bottoming Out
- Is this a 08 model?
- Looking at GX470's and Sequoia's.
- 2007 GX470 Black Wood Trim
- Skid plate bolt
- Driver Seat Replacement
- Rear heat blows cold
- Scheduled Maintenance for GX470
- GX 2006 Cold Air Intake (CAI)
- Tranny service
- Speedometer faceplate
- Any invisicord users with GX470 ?
- GX 470 for parts
- 107K needs some mantanance!
- New to Me GX 470 & Audio Advice
- Interior Lights Randomly Flash On?!
- Rear door inside handle p/n?
- Need help - thanks
- what to do??????
- Vsc..trac off..engine light..damn it.
- my windshield washer sucks.
- Fog Lamp DR Replacement (HID)
- Step Bumber Hitch for GX (bike rack) - Will this work?
- UPDATE: On pitting rims
- Audio Problem
- Want to buy used GX470
- Check Engine light, VSC light, TRAC Light...fixed!
- kdss problem
- How to activate voice command?
- Rear differential whine TSB
- GX470 vs. Sequoia race. This is NOT your average poopy doopy racing clip. :)
- Radiator leak, what should I do?
- Spare stolen. Now what?
- Scary noises during GX search
- Anyone replace a rear seat belt retractor yet?
- 2006 gx470 rear door hinge to strut conversion?
- Looking for a 1st gen GX. How common is rust?
- Anyone replaced a fender flare themselves?
- Help with diagnosis of electrical issue in 2007 Gx 470
- Pillar covers - Where to buy
- Glendemon
- Check Engine, Traction control, anti skid...
- VSC trac, VSC off, check engine light, and car skidding out light on help!!
- Diff and transfer case fluid
- Land Cruiser for Christmas
- Did Lexus Replace Engine on Used Lexus GX?
- gx470 with nav options for new system
- CV Boot Question
- My wife's 2004 GX470 *freshly washed*
- Red light with key logo blinking on dash
- Dome / Map lights compartment removal
- NAV DVD Player & Passenger Seatbelt Warning
- 07 GX470 convienence feature
- Lights stay on after turning engine off
- Replacement Kits Rear Shocks/Suspension
- Radio wont turn on.
- Convert power ports to always on
- Airbag light on only when sitting in drivers seat
- Gen5 Navi Question
- Low Tire Light On, Tires fine?
- Question about Transmission fluid?
- Lexus GX470 paint code - dark graphite
- Stuck rear armrest cupholder
- Headlamp Lens Clean - Cheapest Way i assume
- Looking for a GX
- Silverstar ultra headlight bulbs
- bought the extended warranty but I wanted...
- rear shocks on 04 gx
- Any snowboarders? I need a good rack.
- Cleaning Throttle Body and removing battery "I'm Scared"
- New owner with a few questions
- Warning lights: VSC OFF, VSC TRAC, Anti Skid, CEL - P0456
- Advice on 04 GX Purchase
- painting headlights
- 90K Mile Service
- Owned it a week and then the alternator fails.
- Front license plate mounting holes
- Seems to have no power to the wheels on a hill.
- iPhone 5 Connector in GX
- Part # for Running Board Clips?
- Low beam issues. Any advice appreciated.
- Muffler replacement stock or performance?
- Nav Override in GX 470 2007
- Driver side heat, passenger side cold air
- sound system advice needed
- Can I replace my lights with Hella modular lights?
- Power Mirror Motor Write up (Picts)
- stuck center cup door lids???
- Changing Seat Warmer light
- Lexus gx470, 2004, running board light drivers side not working
- '07 with bad front wheel bearing - warning sign or normal wear and tear?
- Hello from another new owner
- changing serpentine belt, how hard to do?
- Used Gx 470 or Used Land Cruiser
- Emergency Brake does not lock into place, any tips?
- Mats or Floorliners??
- QUESTION: Dashboard indicator light meaning
- Will Navigation work in Mexico? 05 update unknown
- VSC OFF, VSC TRAC, CEL but no SKID Light
- New Gx470 owner right here thanks
- Drivers Mirror Motor
- Rolling back in Drive
- 07 GX NAV DVD removal question
- interior parts
- Best hitch? Curt or Hidden Hitch?
- Repair manual
- Rear air suspension.
- Chrome Tailpipe
- Engine/Transmission cooling issue
- License Plate and Reverse Lights
- Mirror started wigging out
- What should I know before diving in?
- Navi not working on newly purchased GX
- Rubber weatherstripping needs replacing on all 4 windows...
- Help rear airbag suspension airbag replacing
- New GX member...need key, nav discs, etc
- DIY Front Wheel Bearings
- Thanksgiving turkey or am i getting stuffed?
- USA Spec ipod adapter
- New guy - 05 gx470 - few questions
- DIY Brake Rotor - Brake Shaking/Vibration FIX - Warped Rotor FIX
- 06 GX470 serpentine belt noise
- 200,000 mile club
- 2004 GX 470 Heater Problems
- Whooshing Hiss Air Noise Under acceleration load with video/audio. Help!
- Heat shields
- Rim Width on GX470
- GX460 wheels on a GX470
- Do I need Resistor for LED Signal Lights
- Help with fan problem
- Always safety first
- Squeaking Rear Hatch/Interior Rear Hatch Panel Disassembly
