Sd card reader
Old Feb 6, 2013 | 06:48 AM
chrisvr6's Avatar
chrisvr6
Default Sd card reader
How does one install an sd card reader with the factory ml system with nav screen?
Old Feb 6, 2013 | 09:37 AM
chrisvr6's Avatar
chrisvr6
How about just a usb? So could plug in a thumb drive. All i see are the ipod/aux adapter.
Old Feb 6, 2013 | 12:15 PM
bauer26's Avatar
bauer26
Could this be what you are looking for? Looks like its compatible with factory Nav as long as your truck is an 04 or newer.
http://www.gromaudio.com/store/usb_a...#compatibility
Old Feb 6, 2013 | 11:13 PM
danmm7's Avatar
danmm7
I wonder if this USB adapter will "remove" the CD-changer. Looks like it will plug to the same port, so the CD-changer will become useless.
Ideas?
Old Feb 7, 2013 | 06:00 AM
chrisvr6's Avatar
chrisvr6
Perfect! Exactly what i was talking about. Cd changer going in the garbage.
Old Feb 7, 2013 | 06:51 AM
Mparent's Avatar
Mparent
The product write up says you can plug an external cd/dvd player into this device (via RCA plugs, I would imagine - it must have a 2nd set of inputs in addition to the 3.5 mm cable that would go to your iPhone or similar device). So, why not just plug your factory cd/dvd player that is already in the glove box right into this new adapter? This shouldn't interfere with the ability to plug in your smartphone or, if you go wirelessly, it should not interfere with either. Am I missing the 'big picture' here? Mike
Old Feb 7, 2013 | 08:20 AM
bauer26's Avatar
bauer26
Back to the original question about the sd reader. I wonder if once the grom was installed if you could use an sd reader that would normally plug into a computer's usb port. I think ive seen sd readers that can read several different types of cards and came with like a 3-6ft usb cord. That way you could run the cord to the back of the grom unit but still have easy access to the reader.
Old Feb 8, 2013 | 01:50 AM
Mparent's Avatar
Mparent
Yes, according to page 8 of the GROM user manual:
http://gromaudio.com/docs/GROM-USB.pdf
3.2 Supported USB Storage Devices
All FAT16/32 formatted storages:
- USB sticks/hard drives
- SD/CF/MMC cards with card reader USB interface
The GROM USB supports only FAT16/32 formatted storages. NTFS is not supported!
Mike
Old Feb 8, 2013 | 07:20 PM
chrisvr6's Avatar
chrisvr6
What's ntfs?
Old Feb 9, 2013 | 08:03 PM
lakewaylex's Avatar
lakewaylex
ntfs is another windows file system, but fat 16/32 is more backwards compatible (going back to win95 and dos)
a usb stick or flash drive could be formatted with either, so just make sure you choose the right one and you are good to go.
elmerrox
Mar 1, 2008 08:18 AM
infa_red
15
Jan 15, 2008 12:46 AM
ecoastborn
Dec 7, 2007 04:34 PM
