- Anyone played with backspacing?
- Ali SC3's 2003 GX470 build thread
- Putting GX on a lift, does air suspension need to be turned off?
- GX470 Exhaust Rattle - Heat Insulator $5 Repair DIY
- Adjusting rear ride height - instructions?
- Looking To Purchase GX 470 - Need Advice!
- 2003 Air Suspension Intermittent Problem
- Wiper Arm not working well
- Was my diff fluid really changed?
- Need Review on Sport Package Replica Headlights
- TPMS Question (Is Relearn Necessary)?
- How to tie Down to Trailer 07 GX 470
- 03' GX470 Transmission Cooler
- About to pull trigger, Ready, Aim, Now which one...
- Rear Wiper Mod
- Tire questions ...
- CEL- P1442, 1445--Should I do an SAIS bypass?
- A little Lexy adventure, getting high up.
- How to place Floor Jack for jack stands?
- Vcs trak ??
- New GX owner! Few n00b questions:
- GX470 -How to Troubleshoot Audio issues
- Anyone ever replaced the seal on the transfer case driveshaft?
- New GX 470 Owner
- 4-way flasher issue
- Our 2007 Lexus GX470 just got featured at TCT magazine, wooo hooo
- What is this humming sound.....?.
- Random Picture Thread
- What tires to get for mild off road use
- RDS Search
- Finally Joined the Club
- New to me GX, mild build
- Lexus GX470 noise after pushing brake
- instrument/gauge cluster removal
- GX470 suspension conversion questions
- VSC TRAC, VSC OFF, ABS indicators HELP
- Headlight assembly replacement
- Audio Roar with System on or off
- Front noise (air plane takes off)
- Rear suspension issue - air spring not seated
- Programming GX 470 Keys with Toyota Keymaker
- SewellParts.com closing
- Yes, our thermometers do show negative numbers
- Help getting heat to the back seats
- Touchscreen Nav and Bluetooth option for First Gen
- Window switch bad? only one wondow?
- rear suspension conversion
- AVS - Is it Working?
- Almost finished with the Hydrographics...
- Window Sweep Replacement
- Brake service
- Lexus Suspension Alternatives
- GX470 Suspension issue
- RSES DVD replacement...
- New NAV Map dvd not reading 2008 lexus gx470; gen 5 14.1
- Lexus Link Error
- Immobilizer Issue with Key Programming
- My rear tailgate glass spontaneously exploded!
- StopTech Slotted Rotors - Has anyone installed them?
- Transmission fluid service for a 2006
- Black rims
- External mirror command and seat memory dont work
- Can't Get The Rear Air Bags Out
- What's this noise? Need your help.
- Timing Belt / Water Pump
- Replacement Windshield
- Auto windshield wiper malfunction?
- Battery issue while having dash replaced...2004 GX 470
- Anyone happen to know if the ML subwoofer contains it's own amp?
- Should I replace all tired
- Just cleaned her up...
- Tire tread differences
- DIY - differential drop install
- So you drive a GX, what's your other car?
- Introduction & Plea for help..
- Best Diagnostic Scanner (code reader) for Lexus?
- Would you off-road it if...
- Screeching at start up
- Transmission shifts into drive twice!!!
- Dangerous and Unsafe Vehicle after emissions failure or gas cap
- Valve Cover Gasket Replacement
- Rear Entertainment DVD GX470
- Air suspension compressor
- Check your spare tire carrier
- DIY - 2" ironman lift - rear
- DIY - 2" ironman lift - front
- Lifted - problems now...
- Throwing the truck into 4wd
- Battery 1 year old / giving issues 2004 GX
- The $tealer$hip and their assessment of my CV boot
- Don't know who to believe? GX470 windshield
- New to clublexus and need some help
- Rake?
- Odd Issue: Interior Lights and Door Ajar Light comes on During Acceleration
- WeatherTech cargo mat
- Install LED strip in footwell
- 04 GX470 DVD Player
- Gx470 Seat Belt Receiver does it light up
- Car Bobs up and Down
- Fun in the snow with Lexy
- Where's the TPMS Reset Button?
- Price Check on an 08 GX470
- Freezing wiper fluid nozzles
- Locking console
- Gx 470 - Scanner Won't "talk" To Ignition/fuel injection computers
- Weekend trail run
- DIY - Front license plate side mount
- Morimoto HID's installed.
- windshield wiper fluid frozen
- Warranty Enhancement - Cracked Dash Replacement!
- Steering shimmy when warm only
- 2005 GX470 lopsided when in comfort settings
- DIY - Running Board Removal with Pics
- new GX owner here, coming from a 4runner, have a few questions
- '05 Navigation Slow To Update
- Remote Start
- 12 volt switchable source for DRL?
- power steering grinding noise while in drive..
- 04 ML+Nav Audio Solutions
- Does anyone have a PET diagram?
- Need Console bin dimensions
- Catalytic converter problems
- Introduction and My New GX
- Castrol GTX SynBlend 5W-30
- how to replace wheel cap
- Need some help identifying this part...
- 2003 Auxiliary Audio Input
- Dashboards to be replaced?
- Can someone explain this?
- GX470 - How to replace Front Wheel Axle bearing and Seal replacement
- Reasonable offer from carmax? 08 GX470
- tow hitch help please
- Kdss 2005 gx470
- Those Crazy idiot Lights
- The GX demonstrating it's climbing ability
- Shifter feels strange
- Is KDDS Good or Bad if going to lift GX?
- Do you notice 35 hp difference - 2004 vs 2005
- Rear wheel bearing replacement.
- 06 tape deck lights?
- Clutch Fan Noise?
- Please help the GX n00b, I will be in the market very soon.
- Child seat question
- Vibration around 30mph
- Tire and wheel size questions
- 07 GX470 Height Adjust Q
- No Volume from Radio
- Screen above engine air filter ?
- 2006 rear bumper cover oem or aftermarket
- Leather Seats
- HID Lights
- Rotated Tires, now steering wheel vibration
- Rear Air Suspension
- shaking badly after replacing brake pads
- extended warranty on 2004 GX470?
- Brake Recomendations
- GX470 Air Suspension conversion
- Airbags
- New Dashboard
- Glove compartment hook
- Power Outlet Control Button
- Anybody switched from auto wipers to interm?
- 2007 GX Fair Deal
- Frame rust... Opinions needed
- VSC and Airbag lights (no Check Engine) and other electrical issues
- Build Thread Index
- "Blinking" Tire Pressure Light
- Vais sl3b bluetooth
- TYTO-01 Harness Troubleshooting- Pioneer Avic 7000NEX
- Transmission surging in 3rd - Scary!
- 2005 gx470 rear bumper step question
- Driver's and passenger side floor wet during car wash
- Trip to the Shop Today!
- Crankshaft Main Bearing Seal
- 04 gx470 MASTER CYLINDER/BOOSTER
- Dash Cracks and Air Bags
- 2005 GX470 TPMS flashing
- Controls under nav are out - map|dest|menu|display|info|audio|climate
- Driver/Passenger seat straps impede foot space for second row
- Trailer Mirrors?
- Hard wiring radar detector into map light circuit?
- Air Suspension Question (another one...)
- Telescopic steering column squeaking
- Silver wheel touch up paint....please help
- OPOR GX470 slider sale from MetalTech!
- Rear wheels "warm" after rotors/pads replaced
- My Lexus GX 470 Demo HD
- Mileage and How Long You Anticipate to Keep
- Short video of "Lexy" in Baja Mexico
- CV Boot Estimate
- Rosen DVD Payer Issues
- 2004 Lexus GX 470
- Shopping for Used Model
- New set of Headlights for my GX....
- MPG Crappy
- Could someone confirm this part and catalog #
- Recirculate servo motor
- Thinking about new rims
- DIY 90k mile service write up?
- Nav disk 06
- Mouse, diagnosis
- Nitto Terra Grapplers G2
- Wiper Blade Replacement
- Battery replacement
- wheel sets
- Getting new tires today!
- Running Board removal with a few pics
- New 2005 KDSS, Common Mods?
- 4.7 crazy problem
- Trade my 2004 on a 2009 CPO?
- Stock air compressor
- Edith all clean...
- Brake fluid flush
- TPMS Question
- My new to me GX has been at the dealership all week…
- Engine immobilized light
- 2004gx flasher
- Aftermarket running boards / step bars?
- Rear wheel still spins in one direction with parking brake engaged?
- Advise on shocks replacement please...
- Getting stuck in snow in GX 470???
- Found my coolant leak . . .
- TPMS went from blinking to steady
- Foggy Back Up Camera
- Fuel guage and range readout not working intermittently
- What happens if no TPMS installed?
- Wood trim 2003-07 versus 2008-09
- Heatshield on GX470 necessary?
- Wallet key
- Front wheels get stucked
- A/C Diagnosis on Nav Screen
- rear suspension
- Lexus GX470 Light Bulb Reference Chart
- Navigation/ Mark Levinson Audio Package
- Need advise and parts
- Anyone in Seattle who might want a nice Winter wheel/tire setup?
- Arnott Introduces New Rear Air Spring for 2002-09 Lexus GX 470
- Tune-up Checklist
- Happy trails
- New GX 470 owner - pics and questions
- New to Forum and GX470s
- Suspension Conversion Questions
- clunk when stopping and starting and uneven tire wear
- 60k miles transmission changed or flushed
- 110v Outlet in the cargo area - Tailgating?
- Cepek Tires
- Turn Signal/Daytime Running Lights
- Please Help...Rear towing relay not fitting
- GX470 engine noise when decelerating... RPM drops
- Sewell Parts
